Old 10-15-2019, 01:35 PM   #1
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Ultimate Racing Turbo Kit Sorta Review
I just wanted to post a rough draft of my experience with the Ultimate Racing Turbo kit.
Let me preface this with this; my girlfriend paid for the turbo. I have to get that out of the way because she loves to blurt that out every chance she gets, lol.
I was looking at a couple of cheaper turbo kits as I didn't want to pay 5-10k for a kit. Initially I was looking at the SBD kits, and I followed them for a while. They always sounded like a great option and they probably are. I haven't seen anything bad about them still. Somehow I came across the Ultimate Racing kit after purchasing their exhaust parts. I didn't realize they had a kit, but once I had their other products I was impressed and decided I would look into theirs. Part of my goal was to recreate the sound of my old 07 sti, or the iconic Subaru sound. The SBD kit required that I use their manifold, as did most of the other kits. I think there was a JDL kit that allowed any headers, but regardless, the Ultimate Racing kit didn't require me to purchase a specific manifold, but instead I was able to keep my UEL catless headers. This was no brainer at that point! It's perfect for that distinct Subaru sound.
I toyed with the kit and added and removed multiple upgrades, and finally figured out what I wanted. It was a bit over $4300.
I had reached out to the UR team a couple times and they suggested which upgrades to get based on my needs and they did a great job. I asked for quickest spool. I ended up upgrading to the Gt3076r. It's very quick 0-90, but nothing to write home about above 100.
I got it around xmas 2017. Initially I got it and it was missing the turbo from the box. It was pretty lame. I got everything but the turbo. I was pretty p.o'ed. I had to wait another week or two for the replacement. I finally got it and was able to get everything installed pretty easily. There are some pretty tight spots, but I managed to get it done.
Overall, I love it. I've had some issues here and there, but I think it is installer issues, and nothing that turns me off. The car is perfect now, and there is still room for improvement with built internals. I don't I need to build the engine, but I may just because project car. I was able to install an aftermarket BOV. I didn't like the sound of the one I upgraded to. It was a flutter and I preferred a gust of air. I don't know if that's an added feature compared to others, but it's nice that I am not limited to one setup. I can make changes as I need and retune where necessary, which btw, I have been using this turbo on an etune for a couple years now and my car is still in one piece. No mechanical issues so far. I hit boost all the time and am not nice to the car. It has handled all my abuse so far. I did get in a wreck in March, 2018 and the car was off the road until like June'ish, but I've driven it plenty to get a good feel for the kit.
Also, I wanted to point out that I have not installed an oil cooler yet. I wanted to and planned to, but just haven't yet. I was considering the radiators with built in oil coolers, but haven't decided yet. My temps probably average about 230f after driving for about 30-60 minutes (mind you I don't drive nice for the car, constant redlines in first and second). I've seen it as high as 247f, but above 230f it doesn't update often, or the temps stay put around there, I'm not sure. I'm using OBD fusion to track my temps, etc.
I would recommend this kit regardless of any issues I've had, which I will highlight, hopefully not discouraging anyone, as I bet it's just me who caused the issues.
List of issues I've had:
gasket between headers and turbo down-pipe get's blown out like nobody's business. I had to get grimmspeed gasket to fix the blow outs as it would literally blow the normal gaskets to pieces!
Oil return line is in a very tight space. If you don't get it right the first time, it's painful squeezing hands and tools in there, but again, I don't blame the kit, just me and doing stuff wrong or not well enough the first time. I've since fixed the line with lots of knuckle skin, but it's hangin in there quite well since then. Wurm clamps > zip ties, haha.
My turbo filter broke off, but this could be due to me making the wurm clamp too tight, as that is what it looks like. I just squeezed what's left of it back on and reclamped it, and it seems to be doing just fine. Again, probably my fault. I have been tightening the clamps with a drill, so in some cases I may have over done. Either way, not a big deal. It still works, and I wanted to get a newer, prettier one anyway, but I still haven't had to.
Lots of tight squeezes, but this is the car and not the turbo, but still can be painful getting it installed with all the tight spots.
You need to either re-route the battery to the trunk or opt for a smaller Optoma type battery, which I love. UR crew recommended against the small batteries, but I went for it anyways and I prefer it over running the full size battery to the trunk. One battery bubbled so I replaced it and the new one is great!
Those are the issues I can think of. None of them would persuade to go another route.
I don't know what hp I am at, but probably near 300 as someone else with the same kit and upgraded turbo was pushing 293 whp, so I will assume it's somewhere between 250-300whp somewhere. It gets it pretty well, especially second gear. I think it can hit 0-60 in 5 or less depending on the driver, but who knows, just assuming.
This was a rough draft word vomit review. Sorry if it's all over the place. I just wanted to share and recommend the UR kit and get some eyes on it for anyone looking. I'd recommend it 10x over!
Picture fest...er, link fest cause I'm having trouble uploading images >: |
https://imgur.com/4J9R7LM
https://imgur.com/iyA7dsr
https://imgur.com/C3LqReO
https://imgur.com/MZ8Cj4k
https://imgur.com/1W0a9wZ
https://imgur.com/5G5kB2Z
https://imgur.com/ciMASA9
https://imgur.com/xjQSGk5
https://imgur.com/P551urR
https://imgur.com/iAFnAm8
https://imgur.com/pOFZiH2
https://imgur.com/7tp3rka
https://imgur.com/G6S7eoC
https://imgur.com/DniU5dD
https://imgur.com/CnvOkdc
https://imgur.com/pMgdRsz
https://imgur.com/YpCyWa9
https://imgur.com/PAJd8lg
https://imgur.com/FW8bydD
https://imgur.com/cB4Uip2
https://imgur.com/zd2Tes9
https://imgur.com/ZSdH4V3
https://imgur.com/mIUOMrJ
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Last edited by Strife26; 10-16-2019 at 10:43 PM. Reason: Added images per responder's requests
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
Joveen (10-15-2019)
Old 10-15-2019, 01:40 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Awesome. I've been looking at this kit for awhile. What did you do about battery placement and how is getting cold air since the turbo is in the corner? You might have won me over because I really dont feeling like getting rid my header and starting over.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 10-15-2019, 01:43 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
And what BOV did you get?
Old 10-15-2019, 11:15 PM   #4
Strife26
Strife26's Avatar
Well I've been driving it for about 2 years now, so wherever the filter is, it hasn't appeared to be an issue. I've had little issues here and there (None related to the filter, hell the car ran fine when it was just hanging off for the 2 days I drove it that way, : ( ), but pretty sure they are all me, and this is an otherwise solid kit so far. And as much as I told myself to respect the car and be nice to the (because it's an) aftermarket turbo, I've been pretty brutal in my opinion. I redline it through first and second any chance I get an open lonely road, and constantly rush to 70-80 on the freeway and maybe some other naughty things...I'm just not that nice to it. Tbh, idk where my temps should be, but afaik they have never hit 250 no matter how hard I ran the car. So oil temps <250, and coolant temps, I think are 209'ish? Idr them being all that high, unless 210 is high. Regardless, car is running better than ever after fixing a loose clamp.
Synapse BOV:
Synapse R35V Trident Blow Off Valve (R35V001A.012)
w/ HKS SSQV BOV Flange
Was pretty easy to install. Mind you, I'm not a mechanic and have only really worked on this car, so I guess it's easy to the "normal Joe," if you will.
I have it coupled with their full exhaust too. I went with the single exit exhaust.
I have some videos up with sound, etc.
https://www.youtube.com/channel/UClH..._as=subscriber
Let me know if you have any other questions.
Joveen (10-15-2019)
Old 10-15-2019, 11:26 PM   #5
Joveen
Joveen's Avatar
Drives: Bone stock
I'm in the CT so I'm worried about the battery tbh. Any tips for that?
Old 10-16-2019, 12:23 AM   #6
Strife26
Strife26's Avatar
What's the concern there? If it's cold weather, it's sat through a couple winters with below freezing temps. It's been through rain (get's in my Seibon hood vents), some below freezing weather, and snow and it's still kicking. My first battery I think blew because of heat, but can't be sure. The battery I have now is already night and day difference. I have a small sub/amp thing, footwell lights, and some and the battery handles everything I throw at it (probably not the best idea). I'm willing to drop 100-150 a year on a battery if it's that or running a full size to the trunk, haha.
Old 10-16-2019, 01:03 AM   #7
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
PulsarBeeerz (10-16-2019)
Old 10-17-2019, 09:59 AM   #8
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Don't mean to hijack your thread, but I just wanted to clarify about the JDL kit, it comes with a very strong mandrel bent UEL manifold by default and has great rumble, without the need for support brackets like the lower quality manifolds from SBD and others. The JDL manifold provides a front mounted turbo/downpipe location which makes the install a bit easier without all the tight fitment of the rear mount.
[ame]https://www.youtube.com/watch?v=zyNcw8jRnJs[/ame]
Sorry to see the failure in the support bracket, but it looks like they took care of you with a replacement.
Glad you're happy with your UR kit.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Joveen (10-17-2019), Strife26 (10-17-2019)
CX Racing Turbo Kit - Owner Review (results unsurprising) BRZoomTX Forced Induction 29 02-27-2020 05:39 PM
Ultimate racing turbo kit brzy007 Forced Induction 49 12-17-2015 10:31 PM
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Meguiar's Ultimate Compound, Ultimate Wax, and more review radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 06-09-2014 06:44 PM
