BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
10-12-2014, 11:33 PM | #29 |
Drives: '13 FR-S Whiteout
Always in sport mode because i never drive it in auto mode
10-12-2014, 11:56 PM | #30 |
Always have Sport mode on (traction control off, stability control on) unless its raining.
I can't stand traction control when it starts nerfing my throttle inputs... Stability control is a lifesaver though. |
10-13-2014, 10:41 AM | #31 |
There are now 2 carseats!
Drives: 2013 DGM BRZ
The pedal dance
http://www.ft86club.com/forums/showthread.php?t=25494 |
10-13-2014, 11:15 AM | #32 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
VSC and Sport are never on together for me
Sport is rendered useless if you're in "M" VSC on during winter city driving (yes, it helps) Trac ON rest of the time road driving Trac OFF for AutoX |
The Following User Says Thank You to drewbot For This Useful Post: | Teseo (10-13-2014) |
10-13-2014, 12:49 PM | #33 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
Your information is incorrect.
-Jack Burton |
10-13-2014, 01:53 PM | #34 |
Drives: Toyota GT86 Coupe Red (UK)
Indeed it is. If he actually read the manual excerpts he posted he would know that.
When only TRC is disabled it re-enables at 31mph. If you disable both then they stay off. I believe the pedal dance is to turn off other auto braking of various wheels, such as the inside front in a corner. Not sure. I heard someone say that VSC Sport mode gives you more of a yaw angle, but that's not what I have felt so far. It feels like a delay to me. At both extremes, I have gently let the tail start to slip on a bend and when a very small slide developed the VSC collected it almost immediately, but not quite as immediately as the full on mode would have. Then when I stamped it in the wet on crap road at 5mph it went 90* before the VSC start to try and save it.... while I corrected so I didn't hit the railings now dead in front, when it did. ...and yes I agree the VSC collecting a slide can be a lot more violent than the slide would have been. thrrrurmMMP! Unless you didn't mean to slide...
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
10-13-2014, 03:24 PM | #35 |
Drives: 2013 GBS BRZ Limited
I think this thread proves one thing more than any thing else:
MOST people who are turning off the TC&VSC systems know very little about how they work, or WHAT they are actually disabling.... I know one thing for a fact: The car's systems nearly killed me once in the snow when they were disabled (by button holding) because they waited TOO LONG to re-engage then sent me into a snap-in oversteer to recover from a tiny slide that I had already compensated for. If it had been fully engaged or COMPLETELY disabled, I would have recovered perfectly. Instead I ended up backwards in traffic because the system did the exact opposite of what an experienced driver would do under the circumstances. Sure - CUE the "then you dont know how to drive" drivel. |
10-13-2014, 07:56 PM | #36 | |
http://www.fr-sforum.com/forums/fr-s...n-legnthy.html (Post #6 has the illustrations in place) this seems comprehensive. I'm going to go read it. |
10-13-2014, 08:01 PM | #37 | |
So elite I'm 1338
HINT: *1: If the VSC OFF switch (pattern select switch assembly) is pressed for about three seconds, VSC and TRAC turn off, and the VSC OFF indicator light and TRAC OFF indicator light illuminate simultaneously. This is just wrong period. Holding the VSC button does NOTHING. Other than take extra time to engage/disengage sport mode. Quit posting bad information.
-Jack Burton |
10-13-2014, 08:09 PM | #38 | |
Also, the manual says to hold down the TRAC button to turn both off. In the pedal dance thread many are stating that some VSC functionality remains. |
10-13-2014, 08:13 PM | #39 | |
10-14-2014, 02:42 AM | #40 |
What a fucked up way to drive. Trail braking to create a slide? Bizarre.
One would typically rock the car with the brakes to get a slide and that's only really in rally world. Custom brakes and custom brake balance, both things I'm sure the manual mentions (although not specifically) that will stop the VSC from working properly. So no surprise it did stop working properly. I do know, in stock, if you go into a corner way too fast and try and brake hard and turn hard the VSC can't help you with the understeer, you just have to unwind the steering and try again.
10-14-2014, 06:31 PM | #41 |
Drives: 2013 BRZ Limited
ON ALWAYS
10-20-2014, 05:24 PM | #42 |
Country Boy 4 Life
Only when needed. The mpg difference is noticeable on a road trip. I also drive with the traction control on, unless off of the Highway. (I own a parking lot)
Similar Threads | ||||
AT Sport Mode - What does it do exactly? | karbon | BRZ First-Gen (2012+) -- General Topics | 49 | 09-02-2014 02:40 AM |
DIY Auto VSC Sport and AT Sport Mode | Seattle944t | DIY (Do-It-Yourself) Guides | 0 | 09-08-2013 05:02 PM |
Cruise control with Sport or VSC Sport mode | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-29-2013 06:50 PM |
Don't forget about sport mode | xbiker | Engine, Exhaust, Transmission | 8 | 06-22-2013 11:52 PM |
sport mode... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 06-01-2012 11:50 AM |
