Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
10-17-2018, 03:11 PM | #15 | |
Drives: FRS
Agreed, however he already owns this amp, also amps that are 15A that work in this application are somewhat limited. If I was looking to LPF the speaker, I would use 2 coils inline with the output side, or replace the speaker with something that has a desirable natural rolloff. or both. @LimitedSlip s point is valid though, using a real crossover would accomplish the goal better than cutting out the tweeter. a .398mH inductor on each output would give you a 800hz 1st order lpf on each of the doors. you can get things like this from digikey. be sure to select parts that can be ordered individually, there are things on there with min order sizes of 1000 for example. link to a first order crossover calculator http://www.erseaudio.com/CrossoverCa...st-Order-2-Way
10-17-2018, 05:34 PM | #16 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
Yeah I have those. I used the white PVC adapters that someone makes, I forget their name. I think you need spacers regardless of speaker selection pretty much, right? They are cheap.
10-18-2018, 09:50 AM | #17 |
Drives: FRS
Bc I'm curious, are you running it on any crossover, or are you feeding it full range and letting it roll off naturally?
10-18-2018, 06:49 PM | #18 |
The amp has a high pass filter built into it for mids/highs. For the mid-range (RS180), I am using a coil enclosed in a radio shack project box which acts as a low pass filter, creating a bandpass filter.
10-28-2018, 11:47 PM | #19 | |||
ProCrastinationConsultant
i've got a better question. why the hodge-podge of equipment? infinity, alpine, and jl all have drastically different sonic signatures, and i suspect part of the issue is the intermixing of those signatures. there is absolutely nothing wrong with mixing speaker brands, but doing so requires forethought and planning with each brands characteristics in mind.
later you mention that the oem tweeters are still installed with the implication that they're still powered? what crossovers are being run on the alpine tweeters, and how are the jl mids wired and crossed over? Quote:
10-30-2018, 10:14 PM | #20 | |
Drives: Burz
All speakers are using the oem wiring, with the exemption of the re-pin to use the Alpine amp. Never once did I think about low pass filters through the whole process, just high pass filters. Honestly never even knew they were a thing. The other learning curve was that some low pass filter is used with the original amp, which is why I thought "no worries, swap speakers, install amp and send more juice to the speakers". That combined with component door speakers really fudges up all the positives I have done and what it can be. Always learning |
10-31-2018, 09:14 PM | #21 |
if you're using the factory wiring, how did the alpine get wired in?
11-01-2018, 03:41 PM | #22 |
Drives: Burz
11-01-2018, 05:18 PM | #23 |
Drives: FRS
It's a fairly common mod, a few people on this forum have done it.
Running along a similar path to @daskaman I was running The 445u bridged running into a pair of cdt ex-30 with the woofers and tweeters from alpines spr-60c along with dayton audio 4 in in the front of the car as well as infinity 3.5 coax speaker's in the rear of the car. I ran that set up nearly 2 years before replacing it recently
11-02-2018, 07:21 PM | #24 |
so my recommendation would be re-wire the amp.
change the amp so the rear channel is going to the door drivers, using the subwoofer output of the radio to enable the in-deck low-pass x-over. ditch the door tweeters and crossovers. shoot for 200hz crossover. then alter the amps front output to go to the dash speakers, connected to the 'front' output. this would allow you to tweak the levels between the door and dash better, as well as enable the high-pass for the dash. so the doors become more of a sub. the dash should be high-passed around 150-200hz. it can go lower, but free air dash speakers don't really reach that low, especially automotive-grade drivers. the rear output of the deck can still go to the rear speakers, if you feel you need them. i haven't ran rear speakers in over 15 years, so i don't.
11-02-2018, 07:30 PM | #25 | |
that might be. i'm not very up to date on the platform at all. i only recently stepped back into here because other forums i frequented are getting quieter, and it's cheaper to sit around and talk on forums than mod the car. though it does nothing for the ideas i constantly have.
Similar Threads | ||||
VIDEO GUIDE - Build your own door speaker mounts using the factory speaker shells. | The Sentinel | DIY (Do-It-Yourself) Guides | 3 | 01-28-2016 05:39 PM |
FS: PVC Door Speaker spacers / brackets for 6.5" speakers | Kayzer Soze | Audio/Visual, Electronics, Infotainment, NAV | 1 | 08-25-2014 09:05 PM |
Auto Door Lock When Out of Range Option | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-27-2014 01:08 AM |
Door speaker question | BlackyRose | Electronics | Audio | NAV | Infotainment | 2 | 07-26-2013 10:45 PM |
Are the door speakers full range or just "subs"? | f0rge | Electronics | Audio | NAV | Infotainment | 6 | 07-22-2013 03:14 PM |
