Old 05-04-2018, 03:34 PM   #519
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
CSG Mike posted this on 3-6-18:
http://www.ft86club.com/forums/showp...&postcount=454
I was reading this today:
https://www.sema.org/files/attachmen...black-book.pdf
Once you have obtained satisfactory test results, the lab will prepare a summary report that reveals all the findings and indicates the necessary E.O. requirements have been met. It is at this juncture the ARB will either (1) conduct confirmatory tests to verify the lab’s data or (2) assume all results are conclusive and proceed to issue of the E.O. This latter step typically requires about 30 days of administrative time, on the part of the CARB. If you have not received any communication from the CARB in this period of time, it’s best to contact the staff person with whom you have previously been working.
I'm hoping it is the latter of the two possibilities, and that any day now we will get notification that the kit is CARB approved because it has been almost 60 days since the car was at the SEMA lab.
Old 05-06-2018, 12:40 AM   #520
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
That post is from 2015...
There have been more delays, and thats all I can really say.
The Racers Line is offline   Reply With Quote
Old 05-06-2018, 01:41 AM   #521
Irace86.2.0
Oh, sad, but thanks for the update. You meant CSG Mike’s post from 3-6-18 was of a pic from Harrop’s IG from 2015? I guess I missed that. Maybe he was subtly saying that they have been to the lab before with setbacks. Kinda crazy that they were at the lab in 2015, and it is 2018 now with no CARB. Considering they passed Australia’s emissions, the CARB standards must really be a jump in difficulty. Hopefully it won’t be another three years.
Old 05-22-2018, 02:25 PM   #522
Irace86.2.0
I am thinking of getting a Delicious Tune. I am going to run the 85mm pulley or 11-12psi, I think. In my research people are saying I need to upgrade my MAP sensor because DT uses the MAP to tune instead of the MAF, and the stock MAP sensor is apparently rated to 1 bar or 14 psi, but can't really manage that pressure. Is this true?
Old 05-22-2018, 03:37 PM   #523
PhyrraM
Drives: '17 BRZ PP, old Legacy SSs and SVXs
FWIW, I purchased mine as a complete kit (through The Racers Line), but it came with a Delicious branded map sensor. Still on the base Harrop pulley for now.
PhyrraM is offline   Reply With Quote
The Following User Says Thank You to PhyrraM For This Useful Post:
Irace86.2.0 (05-22-2018)
Old 05-22-2018, 04:43 PM   #524
Irace86.2.0
Meaning you purchased the Delicious tune/license/ecutek/etc with your Harrop tuner kit, and part of that setup was an upgraded map sensor?
DT sells a 10 psi MAP sensor and a 4 bar MAP sensor. I got an email back from DT which says I'll need the 4 bar sensor to cover the 85mm pulley, so I will have to buy that too when I get my license and tune.
Old 05-22-2018, 04:56 PM   #525
PhyrraM
I believe that Delicious tunes these cars using mostly speed/density and not primarily the MAF.
Here is a copy of the items I bought from Neil:
Harrop SC Tuner Kit
Harrop Australia Supercharger Kit (no tuning)-FRS/BRZ
*Delicious Tuning Harrop Tune Kit*
-Delicious Tuning Edelbrock Tune
-Delicious Tuning Flex Fuel Kit (OEM Fuel Lines)
-Delicious Tuning Flex Fuel Mounting Bracket
-Delicious Tuning Flex Fuel Badge
-Delicious Tuning Injector Hard Connector set
-Deatschwerks 700cc Injector
-Deatschwerks DW300c Fuel Pump
-EcuTeK ProECU Cable Kit
-EcuTeK ProECU License
-Quick Disconnect Fuel Line Tools
Delicious MAP
11 PSI MAP Sensor
Old 05-22-2018, 09:52 PM   #526
Irace86.2.0
Harrop SC Tuner Kit
Delicious MAP
11 PSI MAP Sensor
The Edelbrock tune? DT has a Harrop tune. Considering they both use the same supercharger and general setup I’m sure the tunes are identical.
Old 05-23-2018, 12:01 PM   #527
PhyrraM
I'm sure that's just the way that it was written on the quote. The actual tune file I received via email was named "Harrop". That tune was quickly revised with actual logs I sent Zach.
The only real differences between the Edelbrock and Harrop kits (that I can see) is the pulley size (effects boost level), the choice and location of the MAP sensor (effects scaling), the surface area of the air filter, and a possible difference in intercooling efficiency (effects?). So, I'm guessing the initial base map only differs in MAP scaling.
Irace86.2.0 (05-23-2018)
Old 05-23-2018, 12:48 PM   #528
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I would imagine the runner length differences between the two would also play a part in the tune.
MS, CSCS, TSAC-F, CPT
Old 05-24-2018, 03:28 PM   #529
johan
Drives: '14 981CS, '99 NB1
The MAF scaling will be dramatically different.
johan is offline   Reply With Quote
Old 05-25-2018, 05:27 PM   #530
sw20kosh
Drives: 2013 Black FR-S
16 psi with stg2 cams on E67
The Following 3 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (05-25-2018), CxG (05-28-2018), PR138 (05-25-2018)
Old 05-25-2018, 05:33 PM   #531
johan
I'd be curious what positive difference the cams made, if any. IME cams can actually hurt a PD blower's power output.
Regardless, looks like a lot of fun. Take care of those rods...
Old 05-25-2018, 05:39 PM   #532
sw20kosh
A friend who has the same built motor/head/supercharger with stock cams needed 20psi to reach ~400 whp. But different dyno and tuner so there are lots of variables.
Engines like flow. As long as the whole system is setup and tuned correctly, more flow will yield more power.
The Following 2 Users Say Thank You to sw20kosh For This Useful Post:
CSG Mike (05-25-2018), CxG (06-04-2018)
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 08:03 PM
JDL turbo kit owners thread yomny Forced Induction 1346 08-29-2023 11:07 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
