Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
04-25-2014, 04:14 PM | #71 |
Drives: 2013 SWP Limited BRZ, MT
You aren't the only one, this is maybe my 4th manual car? And I still can't get the hang of it. What helped a little was lowering the clutch to be flush w/the gas pedal. I still have to slow everything down...
The Following User Says Thank You to Indestruct For This Useful Post: | Slysdexia (09-20-2014) |
11-17-2015, 04:22 PM | #72 |
Drives: 2015 Halo FR-S
I'm not sure if this has been seen here, but here is the patent:
http://www.google.com/patents/EP1457702A1?cl=en Quote from the patent: "Such vibrations, which are called herein after "pulsations" make the diver irritated." Diagram: Essentially it's like putting a spring on the end of the slave cylinder; you are never going to get accurate feel out of the clutch as long as that damper is there. I went through this with my 2006 Civic Si. Turns out 90% of the issues people were having with the transmission were eliminated by swapping the master cylinder with a damper-less one. The 86's design is an integrated unit like the below. I'm wondering if the port leading to the damper could be drilled, tapped and plugged?
I trac off too much
11-18-2015, 12:10 PM | #73 |
Drives: 2016 Hyperblue Brz
That looks interesting. Subbed for updates
Similar Threads | ||||
Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 09:42 PM |
Will adding options at the port delay delivery? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 05-20-2012 06:34 PM |
Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 07:21 PM |
ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
