08-24-2013, 09:30 PM | #225 | |
Yea, a minimum of 30 hp more if NA would be a good, but 45+ hp if its forced induction. It would absolutely awesome. Also maybe by 2015 there will be advancements in better and cheaper sound deadening so the car will be that much more livable.
08-24-2013, 09:35 PM | #226 | |
08-24-2013, 10:32 PM | #227 | |
Drives: '21 Civic Type R
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram! |
08-24-2013, 10:45 PM | #228 |
Drives: lexus
what he said
08-25-2013, 01:01 AM | #229 | |
08-25-2013, 01:44 AM | #230 | |
Drives: Firestorm 6MT Scion FR-S
2013 Firestorm 6MT Scion FR-S |
08-25-2013, 08:46 AM | #231 | |||
Drives: 2013 DZE/01 (sold for MX5 ND1)
Just found this thread due to being on the front page. Perhaps it could be combined with the BRZ doomed thread? As I mentioned in my post over there, the Drive article is sensationalistic.
This is obviously speculative, but based on Subaru's 2L vs 2.5L H4s (and weight differences between the Impreza, Forester, and Legacy), I'd expect a ~12-18% drop in fuel efficiency with a 2.5L engine in a 6MT FT86. For purposes of comparison, my 6MT BRZ is rated for 22/30 MPG, but actually gets 25-28 MPG in town and 32-38 MPG highway.
08-25-2013, 08:36 PM | #232 |
Drives: Over the hill WRX
They should just install the V6 in the Camry or the IS 3.5 V6 into the twin, problem solved.
08-25-2013, 08:48 PM | #233 | ||
Drives: '23 BRZ
When I went from 2.4 L6 to a 3.1 L6 in my 240Z, weight gain was essentially zero. If the engine can be bored/stroked to 2.5 liters without becoming physically bigger, and if there's enough margin in the existing drivetrain, there shouldn't be much if any weight gain. Quote:
08-25-2013, 09:52 PM | #234 | ||
Right, that's one of the reasons why I put in a range for my guestimate.
The Following User Says Thank You to Deslock For This Useful Post: | strat61caster (08-26-2013) |
08-26-2013, 03:05 AM | #235 |
Drives: 2013 Scion FR-S Argento
so if 147kw is equal too 200hp, then 197kw should equal 258hp. They have to be thinking turbo/SC or V6 option...I can only imaging how much they will try and charge for that.
08-26-2013, 09:45 AM | #236 |
That was my big concern. If I wanted to pay for an S2000 I would have bought an S2000. This was 10 grand cheaper (new for new). A power boost is definitely going to push it into a higher price bracket.
08-26-2013, 06:28 PM | #237 | |
X-Lurker
Drives: 2zz MRS
Another, if they want to make a new block for the 2.5L then the weight difference should still be significantly lighter comparing to adding turbo, pipes, intercooler etc. |
08-26-2013, 06:54 PM | #238 | |
Drives: '13 FRS - STX
Not much room to bore out. Maintaining square bore/stroke means adding another 6mm diameter to each cylinder (~93mm) or very nearly 1/4". I guess it boils down to what you think a "noticeable" weight gain is, I typed out a long paragraph and ballparked 50+ lb. increase and realized that meant nothing to many people if it resulted in another 20 hp. Edit: and that doesn't factor in the bloat as the model ages, heated seats, nicer plastics or satellite radio or knob gobblers or whatever they do to milk the everyman. |
Similar Threads | ||||
Toyota Supra Alleged Revival: 2015. | 2jz-gte4life | Other Vehicles & General Automotive Discussions | 939 | 08-03-2019 10:43 PM |
Vortech Supercharging System Update - More boost, more POWER! | Brian@Vortech | Forced Induction | 337 | 03-12-2016 03:42 PM |
Will the 2015 get this power boost? | Sport-Tech | BRZ First-Gen (2012+) -- General Topics | 101 | 05-21-2014 10:43 PM |
Toyota confirmed to be exploring forced induction for GT86 mid-cycle refresh | AZOOZ_95 | Scion FR-S / Toyota 86 GT86 General Forum | 79 | 03-12-2013 10:40 PM |
