Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-07-2018, 11:59 PM | #1 |
Drives: 2012 Toyota GT86
86 gear lever play
Hi. The gear lever on my 86 has a lot of side to side movement when in gear. It moves about an inch and a half on each side in all gears. Any advice on how to rectify this issue
12-08-2018, 12:06 AM | #2 | ||
義理チョコ
You never answered my questions in the first place.
The Following User Says Thank You to Ultramaroon For This Useful Post: | JohnJuan (12-11-2018) |
12-08-2018, 01:02 AM | #3 |
Sorry. Couldn’t find the original post. Getting into second is a bit difficult when it’s cold. It does not rotate
12-08-2018, 01:37 AM | #4 |
義理チョコ
Do you mean that it vibrates excessively, or that it's loose and wobbly?
The ability to get it into first and second gear is important, as is the question of rotation. If neither of those have changed then it points to an issue inside the gearbox itself.
12-08-2018, 02:22 AM | #5 | |
(but, that don't take much - ) So, what's the fix? humfrz |
12-08-2018, 02:12 PM | #6 |
義理チョコ
Look at the exploded view of the gearshift parts. I dunno but there ain't much that can go wrong on the outside without affecting alignment between the first and second gear gates, and the lockout plate.
12-08-2018, 02:29 PM | #7 |
Frankly I don't see how you could have that much movement anywhere inside the tranny and have it still functioning.
12-08-2018, 02:37 PM | #8 |
12-08-2018, 02:38 PM | #9 |
義理チョコ
Right? I've never had mine apart. Still can't picture how the thing works.
12-08-2018, 03:05 PM | #10 |
Drives: 16 FR-S Raven
12-09-2018, 12:09 AM | #12 |
Can’t seem to get the video uploaded. It’s basically when in gear , if you move the lever left to right it has a lot of travel. So I took it apart yesterday And found that the bushes were worn. Replaced these and the problem is gone
The Following User Says Thank You to Salim For This Useful Post: | JohnJuan (12-11-2018) |
12-09-2018, 02:10 PM | #13 | |
I don't follow the bolded part, but that's OK. Glad you got it fixed - humfrz |
12-09-2018, 03:19 PM | #14 |
義理チョコ
fake news
Similar Threads | ||||
Gear lever rattle - fixed | sav | AFRICA | 16 | 01-30-2020 09:22 PM |
STI GEAR SHIFT LEVER (ST35010AS000) unpacking | Trap63 | DIY (Do-It-Yourself) Guides | 50 | 04-26-2016 05:25 PM |
Gear lever rattle | Freedom | Engine, Exhaust, Transmission | 18 | 11-10-2015 11:17 AM |
Ferrari like gear lever ? | mashal | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 10-20-2015 02:03 AM |
Gear lever rattle | Freedom | AFRICA | 0 | 05-25-2015 04:17 AM |
