Old 01-06-2020, 02:12 PM   #1
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
DIY LS3 swap kit - long term testing & improvements
Hi at all,
I want to give a short overview of my current swap project on a 2013 Toyota 86. I decided to design/develop the mechanical swap components myself. I want to develop a "as complete as possible" HowTo once the project is finished. As well I develop all custom parts using free CAD software. When all components are tested, I´m planing to upload the data to a public CAD sharing platform, giving companys and individuals the option to reproduce, modify and improve my kit. (work in progress)
A short introduction of myself: I´m a 35 year old projectmanager and former mechanical engineer living in east Germany. I´m into cars since I was 18 and did nearly everything, from hifi build over turbo kits, paintjobs and engine swaps on my own. For sure with changing quality of the result.
The Kit shall include engine and trans mounts, AC line adapters, acessory idler pulley bracket, ignition coil relocation brackets + valve cover liners, air filter connector with MAF flange, air filter box and cold air intake. On side of the electronics the AGT engeineering CAN Translator will be used. This translator is made by @toddy101 , who is also active in this forum with a engine swap thread.
Credits also goes to @spitsnaugle , who gave me some great ideas for my build with his documented LS swap-thread.
Currently the first version of all basic parts is under production. Not yet under manufacturing is the airbox, which is already prepared in CAD. Some parts of the CAI, which will be located under the bumper, still needs to be modeled.
The car before the swap (even if this will not really influence the body):
Everythings takes place in my private garage without lifter/ramp:
Current status of CAD-development:
After those pics of the status of non-physical swap parts, here are some impressions of the current "real" progress:
The layout of the transmission and axle:
I decided to buy a slightly crashed 2013 Camaro SS to get the engine and some other parts. Initialy it was my intension to use also the Camaro TR6060 trans for the swap. Since I learned that this would mean essential metalwork on the tunnel due too the wide forward receptecle of the remote shifter, OR a significant mod of the trans endhousing, I changed plans and will use a T56 Magnum F for my swap. This also makes things easier for the driveshaft.
Nevertheless, since the prices for LS Engines and all the other US car parts are very high here in europe, the decission was still OK. Overall I will have the engine, harness and ECU as well as some other stuff for zero cost after seeling all other parts of the camaro as well as the no longer needed parts of the 86. Only thing missing is the transmission. Ofcourse all components which are not OEM will be additional costs. Overall this swap is pretty much 25% higher in costs compared to any swap made in the US due to import/customs and the fact, the 90% of the necessary parts need to be shipped. This being said, even with shipment and customs added, many parts are cheeper when I ship them compared to the price I get at local store/seller.
For sure its also possible to use a GM crate engine with the swap kit components. But I also hope to gain some advantages by using an engine out of car with all official documents in matter of the legal approval (especially in matter of environmetal safety topics) we have to gain here to be allowed to bring such a modified car onto public roads.
Just for fun, here are some pics of the Camaro:
The HowTo will be finished once I´m close to the end of the project. I have a prallel thread in the german 86 forum where also some more development steps are descriped more detailed. Since I dont have the time to tranlate everything, I will only update this thread in longer time steps.
For now, here is the parts list I used for my swap, acessory setup and so on:
EDIT - 05/05/2020: Update of the parts list, still not complete but getting close. Most custom parts not included yet. Some listed items are sourced at German companys, but should be easy to find in US/North America/Australia.
Engine:
LS3 from Camaro SS 2010-2013, E38 ECU (alternatively GM crate engine 430HP version, some parts for belt drive may already be included when using crate engine)
TREMEC:
Gearbox - TUET16362
Clutch bell - 1386-212-005
Slip Yoke - SDH-2-3-6041X
Clutch Bell Screws - ICB-551684
Radiator:
I have to correct myself concerning what I stated here before. I had to learn that the 86 chassis has simply to small space for a radiator with integrated water to oil cooler and dramatically lacks of airflow through the engine compartment with a big LS block fitted in it. The additional heat load of the oil system exceeds the already poor cooling capacity of the relatively small radiator.
As well, the radiator desgin of the skunk2ultra I used is very poor. The fins are much to big and therefore the row count is very low what means an overall small surface for heat exchange, even while beeing hell of a big beast to fit in the available space.
Another thing I learned: DO NOT BUY A MISHIMOTO FAN SHROUD!!! The shroud itself isnt bad, but the fans used are the biggest crap you can get. The only thing they are able to is creating enormous noise, but the airflow is way below the factory fan set. I disassembled one of them partly and found out that they are very cheap noname chinese fans. They can be ordered on aliexpress for below 10 bucks. That also reflects the performamce you can expect.
I finally went with a Koyorad aluminium radiator and the factory fan shroud. The result was far better as with the setup of the skunk2ultra and the Mishimoto. Better air flow, more space for the air to escape between radiator and engine, better overall fitment, less noise and lower coolant temps.
To take care of the oil temps I additionaly installed a Setrap Slimline oil cooler and an inline thermostat. The thermostat is underneath the air box, the cooler itself is installed under the front crash bar.
For reliable coolant temps under all conditions still a vented hood will be needed. Otherwise overheating might still be an issue if ideling or stop&go traffic with AC switched on at high ambient temps.
A further improvement might be the verus radiator and as well a radiator scoop to prevent any hot air beeing pushed back out of the engine compartment and infront of the radiator. Thats also important for Installation of any aftermarket radiator and Fan shroud: Make sure to seal the radiator to the vehicles frame as good as possible so that no hot air can flow back from the engine compartment (pressurised by the fans) and infront of the radiator!
GM:
Alternator bracket ZL1 Camaro - 12578550
Air conditioning compressor bracket ZL1 Camaro - 12622243 (must be reworked for oil dipstick)
Air conditioning compressor ZL1 - 22785352
Poly V belt A/C compressor ZL1 - 12622244
Alternator ZL1 Camaro - 23482914
Crankshaft damper / harmonic balancer Corvette C6 - 12560115 12674582
Water pump Corvette C6 - 89018052 (alternative: 12681186)
Belt tensioner Corvette C6 - 12569301
Plug for cooling water port LS3 block - 12561663
Exhaust manifold gasket LSx (2x) - 12617944
Crankshaft damper screw LSx wet sump - 12557840
Water pump gasket LSx (2x) - 12630223
Gasket engine front cover - 12633904
Oil filter - 6437462
Thermostat kit - 89018168
Thermostat seal - 12587397 (Attention: A 1mm NBR seal is also required!)
Thermostat housing - ????????
GTO - Shifter Cup - 92147292
GTO - Shifter - 92177175
Clutch actuator / slave cylinder - 24264182
Pilot bearing - 14061685
Clutch master cylinder - 92199594
Melling:
High Pressure oil pump – 10295
Improved Racing:
Note: It is fully intentioned that I the actually “wrong” oil pan (or oil pan kit) is given here. The oil pan mentioned has a “housing” contained in the casting of the pan, which houses the pressure relief valve for the oil supply for VVT/DOD. This valve and housing is not required and must also be removed as it would collide with the steering rack. Also if the actually "correct" variant of the oil pan, without the housing, is ordered, the identical pan with the housing will be supplied because GM only produces the version with the additional housing for cost reasons. The said valve is only screwed into the pan anyway. On the version for vehicles without the relief valve, a blind plug is simply installed in its place. Since both versions have to be reworked anyway in order to not collide with the steering rack, the additional housing to be removed is hardly significant. Everything needed is an additional standard screw plug. The use of the pan with the pressure relief valve is recommended, since it only costs about half (!!!) of the pan without the valve, which is in fact identical due to the change in production.
Front Sump LS1, LS2 GTO / Commodore Oil Cooler Adapter – EGM-107
Baffeled oil pan kit, EGM-403, including:
Oil pan GTO LS2 – 12599397 (GM)
Baffle for oil pan – EGM-204
Pickup tube GTO LS2 - 12572654 (GM)
Dipstick GTO LS2 – 92067147 (GM)
Dipstick tube GTO LS2 – 92066941 (GM)
Gasket and small parts for assembly
JustDifferentials:
Pinion and crown gear set i = 3.58 - TV6-358-29-NG
Bearing and sealing kit for pinion - PKTV6-B (contains bearings and shims for pinion shaft but not for differential cage, bearings for differential cage can be reused if only the ratio is changed, as shims for the differential cage DIN988 in the appropriate size can be used as a cost-effective alternative to Toyota OEM -shims)
29-tooth differential flange - YOKT35100-MULTI
AGT-Engineering:
Plug&Play GM to BRZ/86 CAN-Bus Translator
Continental:
Poly V belt - 6PK1880
Note: The poly belt for the ancillaries is meant to be used with the custom-made pulley bracket. (ZN6-020-000-05c) This bracket is also part of the A/C system and carries the A/C line with the high pressure service port for R1234yf. This HD service port is taken over with the OEM A/C line fitting of the GT86.
A/C lines:
Below are the individual parts of the A/C lines. For better allocation, each with start/end point of the respective line. The components are listed in the order in which they are installed from the specified start to end point. Parts of the lines, which are taken from the original lines or which are self-made, are shown in green letters to illustrate the complete line construction.
Cold Hose/custom manufactured:
Hose 1 - Expansion valve to A/C compressor:
Adapter expansion valve– ZN6-020-000-02b
# 10 90 Degree O-ring Fitting - BL1323
# 10 (1/2") Standard Barrier A/C Hose XXX ft - BH10
# 10 (1/2") Inline Splicer 7/16" R-12 or Switch Port - BL6103-1 (Adapter for R1234yf needed!)
# 10 45 Degree O-ring Fitting – BL1313
Connection to A/C compressor – ZN6-020-000-???
Hose 2 - A/C compressor to bracket for pulley (ZN6-020-000-05c):
#8 90 Degree O-ring Fitting - BL1322
# 8 (13/32") Barrier A/C Hose XXX ft - BH8
# 8 Straight O-ring Fitting - BL1302
Hose 3 - holder for pulley (ZN6-020-000-05c) to air conditioner:
OEM Toyota fitting with high pressure service port, removed from OEM line by cutting the ferrule/press sleeve
# 8 Ferrule/press sleeve for Standard Barrier Hose - ATC3008L
# 8 (13/32") Standard Barrier A/C Hose XXX ft - BH8
Adapter upper connection to kondenser– ZN6-020-000-01b
eBay:
Retrofit adapter R1234yf low pressure service port to 1/4" SAE thread female
Vacuum connection brake booster:
ebay:
Board outlet 1/4" for 10 mm hose AISI 316 stainless steel Board outlet 8688 - Connection for brake booster to intake manifold. To do this, drill a hole in the rear of the intake manifold, to the left of the original connection. The original connection must be removed to connect the heating heat exchanger.
V2A pipe 10mm, approx. 30cm
Turbozentrum:
2x silicone elbow 90°, 10mm, black
Fuel lines:
Pneumatikshop:
Distributor block, PN 16, aluminium, 2xG1/8, 2xG1/4
Threaded nozzle with cylindrical thread, with NBR O-ring, nozzle, up to PN 30, Dm 8mm, G1/8
Screw plug with elastomer seal (G thread) 400 bar Plug galv., G1/4
Elbow screw-in fitting for fabric hose TX, up to 10 bar aluminum, Dm9, G1/4
AN-Fittings:
AN6/Dash6 Fitting straight
GM Quick disconnect adapter 9,5mm AN6
Turbozentrum:
06 AN / Dash 6 Viton hydraulic hose nylon - E85 capable - 60cm
Oil lines:
AN-Fittings:
2xORB to AN8
3x 90° AN8 fitting
1x 180° AN8 fitting
Miscellaneous:
AN8 nylon braided hydraulic hose, 2m
Cooling water lines:
I recommend using Heat Shrink Clamps for all connections between the individual components of the cooling water lines. These do not have a larger diameter than the hose itself at any point, which is a great advantage given the sometimes very tight space conditions. Only at the "ends" of the lines, e.g. at the connections of the water pump and radiator, I recommend to use conventional spring or bolt clamps, in order to be able to loosen and reinstall the hose if necessary without damage. An exception is the connection of the hoses to the heater core. In this case the Heat Shrink Clamps must be used due to space reasons. The connections of the heat exchanger protruding from the fire wall must be shortened by about 2 cm before installation.
Cooling water lines to heater core and steamport:
The hose on the right-hand side in the direction of travel must be extended by using an aluminum hose connector. Turn the reattached section by 180°. The left-hand hose in the direction of travel must be disconnected before the first bend on the fire wall and then reconnected after rotating it by 180°. The OEM bleeder valve of the Toyota 86 must be installed in this hose after the 90° hose elbow attached to the heater core in order to be able to bleed at the highest point of the system.
Mackay:
RUBBER HEATER HOSE KIT COMMODORE VE L76 L98 6.0L V8 06-10 – CH4201/CH4227
Alternative to Mackay the following OEM GM parts can be used if available:
Hose heater core (engine side) – 92281853 (92233978; 92233977)
Hose heater core (heater core side) – 92266388 (92233974; 92184038)
Turbozentrum:
3x silicone elbow 90°, 16mm, black
Schlauchland:
Pipe connector aluminium Dm=16mm l=80mm - AR_V500_8cm_16mm
Miscellaneous:
18mm water temperature display adapter tube / cooler sensor adapter GT
hose connection 6mm 1/8" NPT black
Cooling water lines -> water pump to radiator (lower line, described as A/C lines):
Schlauchland/Turbozentrum:
Silicone elbow 90°, 38mm, black
Aluminum elbow 90°, Dm=38mm - AB90_V100_38mm_Elox-black
Tube connector aluminum Dm=38mm l=600mm - AR_V500_60cm_38mm_Elox-black
Tube connector aluminum Dm=38mm l=80mm - AR_V500_8cm_38mm
Cooling water lines -> filler neck to water pump (upper line, described as A/C lines):
Silicone elbow 135°, 38mm, black
Silicone elbow 45°, 38mm black
Silicone reduction elbow 90°, 38 - 35mm, black
Air filter:
Turbozentrum:
Silicone elbow 90°, 102mm, black
2x HD hose clamp, black, 87-112mm
AEM:
DryFlow Air Filter – 21-2058DK
Clutch-system:
Earls:
Clutch adapter 4AN “late version” - EAR-652504ERL
Clutch adapter 4AN “early version” - LS641001ERL
Tilton:
Cover- TIL-74-207
Clamp – TIL-74-208
Mount – TIL-74-212
Reservoir – TIL-74-202
Filter – TIL-74-210
SpeedwayMotors:
Braided Stainless AN 4, 12 Inch Brake Line - 91031842-4
GM T56 Release Bearing Remote Bleeder Kit, 12 Line, LS1/Corvette/GTO - 5151399-12
Speedway Removable Brake Line Hose Retaining Tabs - 91031309
Spark plug wire:
Scott Performance:
Scott Spark Plug Wire Kit w/Sleeve - LS Coil Pack (Plug Boot Angle: 45°, Color: Black) - CH-K03
Schlauchland:
Heat protection hose 2m, Dm=15mm - HSS-FITEX_V100_15mm
Miscellaneous:
Self-adhesive heat protection mat 100x100cm - HSM-AlFi-sk_V100_1.0x1.0m (for installation in transmission tunnel)
TRS is offline   Reply With Quote
The Following 18 Users Say Thank You to TRS For This Useful Post:
BertoFT (04-28-2020), BigTuna (01-09-2020), Boccaccio (01-08-2020), brianbui23 (02-01-2022), Dadhawk (01-06-2020), HawaiianMike (01-08-2020), jcw99 (01-08-2020), JeremyR (01-09-2020), jflogerzi (01-07-2020), korhun (01-11-2020), Lonewolf (02-17-2020), mrg666 (02-15-2020), new2subaru (07-02-2020), sato (07-02-2020), ScoobsMcGee (01-09-2020), venturaII (02-17-2020), Zer0 (01-07-2020)
Old 01-08-2020, 10:42 PM   #2
LSX_Corolla
LSX_Corolla's Avatar
Drives: 1983 LSX Corolla Wagon; 2017 86
Wow, Cant wait to see what you end up with. I'm about to start on my 2017 86, but I think I'm leaning more towards a Toyota motor swap. So many decisions!
1983 Turbo LS Toyota Corolla wagon - Sold / 2017 86 - Turbo LS underway!
LSX_Corolla is offline   Reply With Quote
The Following 2 Users Say Thank You to LSX_Corolla For This Useful Post:
Old 01-11-2020, 08:11 AM   #3
TRS
TRS's Avatar
Edit: More manufactured parts arrived, still only testing fitment, but already close. Next version could be already final and welded + coated:
Edit: And some more pics of everything assembled and test fitted into the engine compartment. Most parts are pretty close, but version 2 for some of them are already ordered.
The Following User Says Thank You to TRS For This Useful Post:
Old 01-21-2020, 05:02 PM   #4
TRS
TRS's Avatar
Can't believe it myself, I just installed my 15 buck Camaro master cylinder adapter and it fits great. This was one of the most ambitious and risky designs in that swap kit. I was giving it a max 25% chance to work and was close to order a Tilton MC, but it seems to be almost perfect.
This beeing said, the installation is a little challenging since you have to loosen the clutch and brake pedal assembly as well as remove the gas pedal to get the adapter installed under the pedal assy frame. But after I'm fished its even not to hard if some sticking points are noticed. Will write this down in my documentation later.
I removed a part of the master cylinder since I was fearing it would not fit, but now I See that even this wouldnt be necessary. Also the Camaro's sealing to the firewall could have been reused. Only the adapter bolt to the 86 clutch shaft is missing, I will try to get one made shortly. Maybe I will exchange the Master cylinder once everything is tested with clutch and trans installed. But for now I dont See any reason why this shouldn't work exactly as in the Camaro. Also the necessary space in Front of the firewall is a dream. I would tend to say that this is one of the shortest master cylinder options you can have for a 86 LS swap. Here are the pictures:
The Following 3 Users Say Thank You to TRS For This Useful Post:
Godzilla35 (01-28-2020), Zer0 (01-25-2020)
Old 02-12-2020, 04:46 PM   #5
TRS
TRS's Avatar
And here the first overview pic of the nearly complete kit. Still test Phase, but getting close.
brianbui23 (02-01-2022), spitsnaugle (02-12-2020), Zer0 (02-12-2020)
Old 02-12-2020, 06:59 PM   #6
Zer0
Drives: 2015 frs
Looks like a very complete kit with the A.C. line adapters. Excellent job.
Zer0 is offline   Reply With Quote
Old 02-12-2020, 10:05 PM   #7
vijay.dy06
Drives: Red BRZ
I'm interested in the ac adapter. Price?
Sent from my SM-G950U using Tapatalk
vijay.dy06 is offline   Reply With Quote
Old 02-12-2020, 10:24 PM   #8
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Can you tell me how many MM in total that master cylinder setup protrudes out of the firewall after connecting lines?
I dont think that'll clear for sikky users.
Also, curious, what distance do you have between the cylinder head and firewall? trying to gauge how far forward/aft your setup is vs CX/Vorshlag/Sikky.
Looks like a VERY well done setup. Congrats.
... using an engine out of car with all official documents in matter of the legal approval (especially in matter of environmetal safety topics) we have to gain here to be allowed to bring such a modified car onto public roads.
I can only imagine getting approval for this kind of swap isnt easy. I've heard quite a few stories about not having TUV approved parts.
spitsnaugle is offline   Reply With Quote
Old 02-13-2020, 01:30 AM   #9
TRS
TRS's Avatar
Thanks folks for that great Feedback!
@vijay.dy06: There is no pricing, as I said Im not a Company. Furthermore Im locate in Germany. WE dont have a big enough market for such stuff to make a business. There are very few people here willing to do such swaps, and those few we have tend to dont Do things on their own but to go to a tuner and let him Do the complete Job.
So, current Plan is sharing the data once everything is finished. But its still test phase. There needs to be one more Adapter (For compressor terminal) which is not modelled jet since I had Material to weld this one instead of milling it. Bur I plan to have the kit complete and so I will create also a plug and play version of this one. It will also included a switch port where the GM A/C sensor can be adapted, which is needed for a/c to work if you are using the E38 ECU.
ETA for finished a/c line kit including parts list, line length and clocking is 1-2month from today.
This being said, as I was standing infront of the kit it came to my mind to maybe Team up with a manufacturer in the US since I believe its not everyones business to CNC' such parts. But just thinking currently...
@spitsnaugle: When take out the engine next time I will do some measurements. If I had to guess I would say its between 30 and 40mm out the Firewall, but didnt measure jet.
Overall Position is not fixed jet, since Im waiting for my New trans for weeks. I decided to use a new magnum F instead of standard T56, but those are backordered currently and leadtime extends. I hope that I now found a way to get it quicker from Grannas racing.
I need the trans installed to get the exact Overall Position, since the set angle makes a huge difference in clearance to Firewall and latch support.
So compared to sikky it will definately be more forward, I would guess arround 35mm, since sikky testfitted LS' with vortec/Truck spacing pulley which creates a virtualy 38mm longer engine compared to the Standard/corvette spacing my Setup is made for. But they pay the toll to hammer in the Tunnel for some inches to get this far back Position working and a Main goal of my kit was to avoid this type of modifications on the chassis.
Compared to vorshlag it should be slightly more back, since they needed to Trim the latch Support even while using corvette spacing. This makes sence in a way since they use a Magnum XL, which is much longer in matters of shifter Position compared to T56 f body or magnum f. If I done correctly my perfect shifter Position is arround 31inch from the engine flange. This means 2 inch back from f body receptacle or 2 inch forward if using T56 with GTO shifter, meaning there will be some kind of an shifter relocation made for this kit once I have the trans in hands.
The Design of the engine mounts is currently done for a Max forward position without need to cut the latch support while using corvette spacing. But I planed for the sheetmetal base joint to be the variable Part on that. So by changing the bore in this Part it is possible to adapt the kit for arround 1inch more backward Position. The Design of the trans mount is pretty variable anyway. This means, once I have the angle defined I can move arround a little to find the sweet spot.
I will go ahead and maybe Post some more pics of the first install of the kit's components later.
EDIT:
The expansion valve a/c adapter:
Pre-installed engine mount, without bushing yet since coating has to be done before bushing is pressfitted:
Condenser to expansion valve line Adapter, was made due to space restrictions, Standard Adapter to O-Ring fitting wouldnt work due to low space to crash bar:
Welded compressor port Adapter with a/c switch Port, will be done as milled screw-on Version later, but same layout:
All other a/c line stuff can be purchased at coldhose.com as long as you are using R134a. Since I have to use R1234yf due to local laws I have to use additional Service port Adapters for this refrigerant. (The high Port is reused from the OEM 86 line.)
The small (#6) line between condenser and expansion valve is the OEM 86 line, which is re-bent in the section above the Firewall. This process can be done with simple Tools, but needs some mechanical skills. Therefore the Design of the expansion valve Adapter is made in a way that you also have the Option to use an aftermarket #6 hose with standard O-Ring fittings and build a New line. In that case the OEM 86 a/c pressure sensor needs to be removed and the Contact at the plug to be bridged. With the OEM line its added safety to mesure the pressure twice, before and after condenser, while pre condenser is the GM Sensor (which OEM also was locted pre condenser) and post condenser is 86 OEM. Both Sensors are serial wired, so the refrigerant pressure is Controller to be within GM as well as in Toyota spec. (both Sensors have a defined low/high windows in which they activate the compressor, serial wiring means that both are needed to allow the compressor to Start)
Since R1234yf is a more critical refrigerant I decided to go this way. If you use R134a the OEM sensor can be removed. Also with R1234yf it is not 100% necessary, but I wouldnt recommend to take out that added safety.
The Following 2 Users Say Thank You to TRS For This Useful Post:
B T (02-13-2020), Zer0 (02-13-2020)
Old 02-17-2020, 06:11 AM   #10
TRS
TRS's Avatar
Reinstalled everything I have so far during weekend to Also check fitment of the last A/C adapter between condenser and expansion valve. Looks good so far, in matters of line routing even better than expected. Now only oil lines are missing...
Latest overview of the complete install. Airbox and Filter positioning still things to do, but this needs to wait Until engine and trans are finaly in place. Furthermore the last A/C line on passender side needs to be crimped. Also some brackets for that still missing.
I now ordered the Magnum F at grannas racing. Could arrive Until end of the week. Fortunately Joel has a couple of those transmissions in stock what allows to work arround the backorder on manufacturers side.
Old 03-28-2020, 08:15 PM   #11
TRS
TRS's Avatar
Still working, but mechanical the kit is almost ready. Air filter/intake as well as part of the exhaust (catalytic converters) and driveshaft are not ready yet. Air filter and driveshaft in progress, exhaust will take a while to be finished.
Up to here 100% DIY, own development, own kit. Will try to keep it like that. Let's see if I can make it through the TÜV as a privat individual anywhen in the future.
Grawlix (03-28-2020), Irace86.2.0 (03-28-2020), Zer0 (03-29-2020)
Old 04-07-2020, 06:35 AM   #12
TRS
TRS's Avatar
Want to come back with some answers @spitsnaugle:
I took some measurements on the Master. It sticks out a little less than 75mm including all lines. The heads have a distance to the Firewall of 88mm on the driver side, measured at the top of the rear face of the head. Due to the light angel of the complete Aggregat (the diff pinion sits not in the exact middle, it is arround 30mm to the right side of the car if I remember my numbers correctly) there is a little more distance on the passenger side. As well due to the tilt of the complete Aggregat the smallest gap is on the top side. So the distance is slightly bigger the lower you go. In a short, the 88mm is the closest spot to the Firewall.
The balancer clears the latch support by about 15-20mm. No trimming required. (Note: Corvette spacing used on the LS.) The only thing I didnt achieve is to avoid any deforming on the Tunnel besides the removal of the OEM trans mount. There is a Portion on the driver side where the Tunnel is asymetric. Its pretty much the same Spot @spitsnaugle discribed in his build. One sheet metal part needs to be flatened there by hammering. This part his reaching into the "normal" profile of the Tunnel and needs to be deformed so that it is flat with the actual tunnel. I would say it needed arround 10-15mm of deflection. As well I made a little more space for the reverse switch (arround 5mm), but this is only due to the fact that I wraped the complete tunnel with 3mm hear shield. Without that (and in this Position its actualy not realy needed) this can be left out.
As well I removed some unnecessary parts of the transmission housing arround the reverse switch and grinded down the housing arround one thread end by 5mm on the driver side. (also not needed Material)
With those measures the smallest gaps arround the trans is 5mm. Taking the heat shied into consideration its 8mm.
Old 04-13-2020, 09:25 AM   #13
TRS
TRS's Avatar
After some final wiring fixes there are some news about the swap project. The CAN Bus translator is working fine. All systems are running. (AC not tested yet since not filled) Driveshaft and a section of the exhaust still missing, so no drving or longer test runs yet, but very promissing for now...
Grawlix (04-14-2020)
Old 04-24-2020, 11:19 AM   #14
TRS
TRS's Avatar
Finally I had the chance to do a short walkthrough of my project and upload it to youtube. Here you go:
The Following 10 Users Say Thank You to TRS For This Useful Post:
BertoFT (04-24-2020), brianbui23 (02-01-2022), Copy (06-07-2020), Irace86.2.0 (04-25-2020), JoeC (07-02-2020), mrg666 (04-24-2020), R_E_L (07-02-2020), spitsnaugle (04-25-2020), Sportsguy83 (05-01-2020), Zer0 (04-26-2020)
cad, diy, ls swap, ls3
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members Cookiemonster Engine Swaps 18 05-25-2019 12:40 PM
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) -- General Topics 13 03-22-2016 03:07 PM
