Old 05-09-2017, 12:53 PM   #15
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by venturaII View Post
This thread just jumped my shark.
ineedyourdiddly
Old 05-09-2017, 01:08 PM   #16
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
"Passed" means it was somewhere within the wildly variable range of allowable specs. Nowhere close to an optimum setup for handling. And if you changed springs and didn't get another alignment, then that's a fail as well.
The Following User Says Thank You to venturaII For This Useful Post:
#my86build (05-09-2017)
Old 05-09-2017, 01:11 PM   #17
strat61caster
Originally Posted by #my86build View Post
Are we talking about an alignment that differs from factory spec?
You can be within factory specs and have a 'good' alignment. You can also be within factory specs and have an objectively bad alignment for performance driving.
It'll go down the road fine enough, but you're losing a lot of feel and performance.
ineedyourdiddly
Old 05-09-2017, 01:16 PM   #18
venturaII
venturaII's Avatar
See, you can be positive. You "questioning" my experience/skill is better than children who assume. Are we talking about an alignment that differs from factory spec?
So the fact that you're asking these questions sort of proves out the assumption made by others (and myself, tbh) that your experience/ability to tell what's good or bad is lacking. Not a slam - just stating what seems to be obvious.
And yes, the factory alignment specs are decidedly less than optimum for handling. The tradeoff is better tire wear, less tendency to tramline, more braking stability, etc. But if you want a car that responds well to steering input, those other qualities will suffer.
Old 05-09-2017, 02:08 PM   #19
Icecreamtruk
Drives: Track preped NA FRS
This thread is good, keep it going guys
Icecreamtruk is offline   Reply With Quote
Old 05-09-2017, 05:21 PM   #20
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You have some homework to do. If you don't know what an alignment is, that's the first place to start. Look up camber, toe, caster, and how each one has an effect on the way a car handles. Do that, tell us what you learned, then we can move on to the next step. Don't even say a single word about your "next build".
The Following User Says Thank You to boredom.is.me For This Useful Post:
Cole (05-09-2017)
Old 05-09-2017, 05:29 PM   #21
strat61caster
meh homework is lame, either OP will spend two hours reading wikipedia articles about vehicle dynamics or he won't. Telling him to do so won't change that.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
boredom.is.me (05-09-2017), Cole (05-09-2017)
Old 05-09-2017, 05:50 PM   #22
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by dattran86 View Post
struts bar is really good when you hard park at the local car meet with your hood open to show off the engine bay, not sure if it actually made a noticeable difference in handling.
Uh-oh. I am going to open a subject that has already been done to death but you know, because internet.
I made fun of the rear strut bar BUT the front strut bar is a different matter. Myself and many others have commented on a marked difference in feel after having a front strut bar fitted.
This post sums it up well:
Originally Posted by Speedie View Post
Hi,
I recently received my GS bar, and was keen to see the difference this modification would bring to the feel of the car. With the help of my brother we came up with a homegrown blind test. (Both my brother and I have science backgrounds and could be fairly accused of suffering from mild OCD ).
The test was this, done five times.
A. My brother would toss a coin, heads the bar is installed, tails not.
B. In either case, step A would take fifteen minutes.
C. I am not in the garage and cannot hear what he is doing
D. My brother when finished step A and B would then pack up the tools, toot the horn and leave the garage.
E. I would take the car for a fifteen minute drive. Same circuit each time, I would note down whether I thought the bar was in or out.
F. When I returned, I would signal with the horn, leave the garage without crossing paths with my brother
G. At the end of five tests, we compared the results.
My brother had out, in, in, out, in.
I had out, in, in, out, in.
I don't want to scare anyone with how OCD I am, but the chances of me guessing correctly this sequence is one in thirty two, or a little over three percent.
Apart from having an enjoyable afternoon spent with my brother having some fun with cars, which we both have keen interests in, I am happily convinced this modification does make a difference for me.
For me it was clear very early in each drive whether the bar was in or not. The noise from bumps was subdued, the steering felt tighter and sharper and the car felt stiffer. I know these are all seat of the pants observations and hard to measure, all I can say is that for me I noticed differences that I liked and when I noticed these differences, it lined up with the bar being in.
So for what it's worth, I am satisfied that the bar makes a difference for me, which I very much like.
Ralph.
Old 05-09-2017, 07:01 PM   #23
Lust
Drives: 2017 Subaru BRZ
I do know what an alignment is, you silly rabbit you. I just didn't know the difference between the factory one and a more performance orientated one. I will take your suggestion about researching camber, toe and caster. However, If I feel I have something to share, I will. If what I share is not of use to you or you feel what I am saying is wrong, you are welcome to correct it, but, "don't even say a single word about your "next build", is a bit harsh. I'll make sure to seek your permission the next time I post.
Typically when someone reviews something they're somewhat knowledgeable about the item or subject...
Lust is offline   Reply With Quote
The Following User Says Thank You to Lust For This Useful Post:
Cole (05-09-2017)
Old 05-10-2017, 07:50 AM   #24
swarb
Thank you for your useful feedback. I did some of #5 on my new build. On my previous build, I was running 17x9 RPF1s with Hankook 245/40/17 RS3s, stock alignment and stock brakes. I'm planning on getting in some track time this summer. Agree, stiffer is not always better. Learned that the hard way, but at least I learned. My driving skill level, IMO is a 3/10, if 10 is pro.
You're welcome. We all throw money at the car buying parts. Although it is not always ideal, if it makes us happy...
Suggestion to get some decent(not entry level) brake pads and brake fluid, and add some camber(2++) up front with some camber bolts and you should have a good base for the track.
A review of my first engine setup. All the pros and cons. #my86build Engine, Exhaust, Transmission 4 05-01-2017 11:42 AM
N/A build pros and cons... TRD_Demon527 Scion FR-S / Toyota 86 GT86 General Forum 35 03-17-2015 08:41 PM
Pros and Cons of the Rocket Bunny Kit VroomVroom86 Cosmetic Modification (Interior/Exterior/Lighting) 28 11-07-2014 01:29 AM
Greddy vs avo stage 1 Pros and cons of each SliverBrz Forced Induction 90 04-18-2014 10:45 PM
KW V3's pros & cons Shaolin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 02-25-2014 09:58 AM
