09-26-2013, 09:09 AM | #1821 | |
Drives: FR-S Firestorm 6MT
What suspension are you on? |
09-26-2013, 09:16 AM | #1822 |
Master Troll
Drives: 2013 BRZ Limited
Are 17" wheels with 245/40 tires so much larger than stock to cause the speedo to be off? I haven't noticed a difference but I figured someone here knows.
Sent from my XT1080 using Tapatalk 2 |
09-26-2013, 09:28 AM | #1823 |
The Following User Says Thank You to Slick For This Useful Post: | Thongpocket (09-26-2013) |
09-26-2013, 09:37 AM | #1824 |
Master Troll
09-26-2013, 12:46 PM | #1825 |
Wasian Ninja
Drives: 2013 Crystal Black Silica BRZ-L
damn I meant to put that in the post I'm running stock struts with Eibach pro kits will I still be good?
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold) |
09-26-2013, 12:53 PM | #1826 | |
18x9 +35 with Eibach ProKit and camber bolts, 245/35R18 tires. Looks fantastic (IMO). You'll be fine, and the 245 tire has a slight stretch on that rim, could fit a 255/35 if needed, but its probably too much tire for stock power. |
09-26-2013, 01:23 PM | #1827 |
Just a dude
Drives: Scion FR-S 2013
Here is a question and I've looked back at least through 20+ pages lol. More directed around front camber, as I know what wheels I am looking at and know they fit. but....
I will be dropping 1 to 1.250 inch max drop. 18 x 9.5" (40) offset is the wheel size, looking at using 255/35/18 MPSS tires. Does one NEED to run camber in the front to -2 if only dropping that much? Every example I have seen or that's been discussed with this size the people are running quite low, say 1.5" or greater so I fully understand in needing camber from -2 or greater with slamming the car down to seeing no gap. But given if one was leaning to less extreme drop would say -1.0 be just fine up front and have no rubbing or issues? Reason I am asking as in the final dilemma, I like the idea of rotating tires at a min front to back depending on tire. But if the car is primarily street and hwy driving the benifit of rotating simply may not be there as to regarding the amount of tire wear on the inner edge at running a big camber up front... Down to where I have to make order soon because wheels I want will take months to get and I'd like to get my alignment within a useable spec here this weekend when I install my KWs and Vorshlaggs on my car. Thanks if someone can chime in. Currently I am on a staggered set of Rotas and running -.4 up front and -2.5 in back. Going to bring backs in by using LCAs to around -1.8 ish and fronts are unknown as I'll decide based on what I can gather here... I know many folks running -2 or greater up front but I think with most of my driving I am abit concerned about dramatic tire wear and how it will handle when its 95%+ street and HWY.
The Following User Says Thank You to OICU812 For This Useful Post: | Dan@AWD (09-27-2013) |
09-26-2013, 02:31 PM | #1828 | |
Proud of BOXER
Drives: Subaru Boxer
I'm about to do 17x9 +45 with 245/40. Will try a 3mm spacer in the front and hope for the best. RCE Yellow springs.
09-27-2013, 02:02 AM | #1829 |
Drives: 2013 Argento FR-S
I just ordered some Enkei RPF1 18x9.5 +38. I'm trying to order some tires ASAP. What is the widest I can go up front and in the back without hitting anything on the suspension? I am dropped on Hotchkis Springs, which are about 1" all around. I also have SPC camber bolts if that helps any.
09-27-2013, 09:37 AM | #1830 |
Drives: scion fr-s
guys someone is selling me xxr527s 18x8.75 +20 XXR 527
"5x114 And I believe 5x100 for the other" he trew me off on "5x114 And I believe 5x100 for the other" what does this mean? also my ride is completely stock so what else would i need in order to make them fit. i plan on droping it soon but i want to get the wheels first. |
09-27-2013, 11:43 AM | #1831 |
09-27-2013, 11:45 AM | #1832 | |
Rears should be okay up to 265 wide |
09-27-2013, 11:49 AM | #1833 | |
Your fitment will poke out, pretty aggressive. You will need lots of camber to pull it back in. Not at all an optimum offset for our cars. +30 to +40 for that width is closer to what you need. |
09-27-2013, 11:52 AM | #1834 | |
Drives: scion fr-s
Tags |
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
Similar Threads | ||||
Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 02:31 AM |
Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
