Old 01-15-2019, 11:07 PM   #2381
Aluma007
Drives: 2017 Brz
Originally Posted by ILLSMOQ View Post
Different kind of meat.
17x9 +40 Konig Ultraform - clears 345mm rear brembo GT Brakes
275/40R17 Hoosier DR2
that is NICE!!! do these clear the stock suspension?
Aluma007 is offline   Reply With Quote
The Following 3 Users Say Thank You to Aluma007 For This Useful Post:
JD001 (03-05-2019), JMon85 (01-16-2019), yberther (03-07-2019)
Old 01-16-2019, 10:21 AM   #2382
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Thanks. Are you asking about the fronts or the rears?
The 17x9” wheels with drag radials in the rear would clear stock suspension (in the rear)
But the 18x10” with 285/30/18 up front will not
ILLSMOQ is offline   Reply With Quote
Old 01-16-2019, 10:29 AM   #2383
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What offset are your 18×10 wheels? Im looking at ones that are +40.
Thanks!
I LIKE TIRES!
Old 01-16-2019, 11:38 AM   #2384
ILLSMOQ
Thanks!
+40
Also needed to narrow the track to tuck them under the fenders.
http://www.ft86club.com/forums/showthread.php?t=122384
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
Leonardo (01-16-2019), phunky.buddha (04-01-2021)
Old 01-16-2019, 12:36 PM   #2385
ILLSMOQ
Thanks!
18x9.5 +40 would give you the same look with out having to do all the extra stuff to tuck the 10’s
Here is how mine looks with 18x9.5 +40 and 285/30/19. They would poke out a touch more without having narrowed the track.
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Leonardo (01-21-2019)
Old 01-20-2019, 09:35 PM   #2386
Aluma007
Drives: 2017 Brz
i thought the fronts were the same as the rear...:P
been thinking of going to wider wheels and tires, without having to get coilovers, but dont want to have to get 17x9 +35 offset to clear stock spring perch at needed camber for autocross.
Old 02-27-2019, 01:18 PM   #2387
maplemylife
Drives: FRS
hey guys, having a hard time deciding what to do with my camber setup.. my wheels are 17x9 +38 255/40/17 and my fronts are - 1.6 and rear is - 2.9
current setup are just tein street flex.. I'm looking at getting lcas to dial down my camber most likely spc but I don't know whether I need aftermarket toe arms or not.. car is meant for daily / autox do you guys think - 2/1.5 front and - 1.5/-1 rear can be achieved with jsut lcas?
maplemylife is offline   Reply With Quote
The Following User Says Thank You to maplemylife For This Useful Post:
Alastor (11-21-2019)
Old 03-05-2019, 01:42 PM   #2388
jslack
Drives: 2017 Red subaru BRZ Limited
Ok this seems to be the right forum to ask. I just got a set of SSR wheets at 18x9.5 with a +44 offest. The tires on it are a 235/40 on it. I currently have stock strut with an Eibach lowering spring that drops the car just about an inch and a 25 mm spacer on it. Sooooo group. Taking the big spacers off, will I be able to run this set up without having to buy coilovers. I have bought 5 mm spacers and the camber bolts to bring the camber in some on the front. I can also buy a different size wheel too. I was looking at least at a 245/35 wheel. Will this all be possible. Thanks group.
jslack is offline   Reply With Quote
Old 03-05-2019, 01:47 PM   #2389
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
No
Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 03-05-2019, 01:50 PM   #2390
jslack
would you be able to elaborate on the no?? is this just solved by a coilover then? They were on a FRS previous to my car.
Old 03-07-2019, 01:45 PM   #2391
Leonardo
Country Boy 4 Life
Leonardo's Avatar
With the wheels and tires you have, you can add a 10mm spacer and No camber, and your wheels will "fit" without rubbing. (they will poke a bit)
Your wheels will touch the spring perch without a spacer. With a spacer added you will have some poke. And if you want to get rid of the poke, you will need camber. To add camber, you will need room between the tire and spring perch. To get room, you will have to add coilovers.
With coilovers you can easily run a 255/35. (and even wider with minimal mods to the car)
I LIKE TIRES!
Old 03-07-2019, 02:10 PM   #2392
Roadcone
StreetKart
285 will fit square with the correct offsets and fender rolling
The Following User Says Thank You to Roadcone For This Useful Post:
Leonardo (03-07-2019)
Old 03-08-2019, 07:38 PM   #2393
jslack
Thanks for the information. I’m going to at least see if 8-10mm spacer with the lowered springs at about .8 of an inch with some camber bolts will run the 235/40 for now and when I upgrade the tire to a 245/255 I’ll get some coil overs for it.
The Following User Says Thank You to jslack For This Useful Post:
Leonardo (03-08-2019)
Old 04-02-2019, 08:15 AM   #2394
jslack
Allright group. I ended up buying coilovers to fit the wheels on the car. I'm looking to do 255/35/18 up front and 265/35/18 in back. I was just wondering how that affects my speedometer when driving. Or will it be negligible. Also running right now with no spacers and still seem to have room, but would the 265 be an issue on the rears?? Thanks.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
