04-15-2019, 11:56 PM | #10711 | |
Sent from my SM-G935T using Tapatalk |
04-16-2019, 12:33 AM | #10712 | |
Drives: 2017 toyota 86
But my supercharger is making max boost (11psi) as soon as I go WOT at anything over about 2500rpm. I think 10 is still on the lower side overall though. And the esc does lose efficiency/boost as rpm goes up. I think they make 5psi at 2,000rpm tapering down to 2.5psi at 7,000rpm? I wonder also if you could set it up so that under say 4,000rpm only 1 is blowing? Then at 4000rpm when they are really only making about 4psi each or about 8.8psi stacked the second one comes on. So it would be like 5psi 2k, 4.5psi 3k then 8.8psi 4K and tapering down to about 6psi at 7k. |
04-16-2019, 12:54 AM | #10713 | |
Sent from my SM-G935T using Tapatalk Last edited by BlOody_BoOger; 04-16-2019 at 12:54 PM. |
04-19-2019, 04:46 AM | #10714 |
Drives: Jaguar XJ, Mini 1000, Rover 25
Check on Instagram an electric supercharger setup.
They did it in parallel. https://www.instagram.com/p/BwMp6anpdVi/ About the twin charging in series. A compressor map shows the pressure ratio instead of boost pressure. So I expect when you put 2 in series you have to multiply the pressure ratio's. 1.4 * 1.4 = 1.96, so 0.96bar boost. This will nearly double the air mass flow and therefore I expect a drop in pressure based on the same compressor map. |
06-02-2019, 07:31 AM | #10715 |
Drives: 86 GT MT
I'd like a new motor. The input wiring has short circuited and burned. I'm after a new electric motor with or without the compressor.
See: http://www.ft86club.com/forums/showp...postcount=1177 |
06-24-2019, 12:22 AM | #10716 |
Does anyone have an extra throttle switch harness. For those running the procede controller and dont need the switch I'm looking to buy one
08-01-2019, 12:37 PM | #10717 |
Torqamp just emailed me, i have already purchased a sprintex so i wont be getting one at this time, but they are doing a kickstarter in the next 2 weeks, and offering the system at 18% off. so 2700$ normally 3300$ for the kit which includes the battery box. Looks a lot cleaner then the phantom esc. Should be slightly more powerful then the phantom at about 6PSI tapered to 2psi (vs 5.5-1.5)
They also have dynos of running two in parallel for more boost/power, as well as compounding with turbos to increase low end power, reduce turbo lag, as well as faster spool up. I would be curious if it could compound on a supercharger and actually offer some gains or if it would be a bottleneck. |
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Target70 (08-02-2019) |
08-04-2019, 05:53 AM | #10718 |
Drives: they all have 4 wheels
Subd
08-25-2019, 01:21 AM | #10719 | |
2013 Series 10 FRS #553
09-18-2019, 10:37 AM | #10720 |
They made it to actually launch their Kickstarter Campaign.
The video looks promising https://www.kickstarter.com/projects...ger?ref=cd16fi |
10-01-2019, 09:49 AM | #10721 | |
looks like the cheapest pledge to get the complete kit is 2350$ , not bad considering it comes with the "battery power back" |
10-02-2019, 05:07 PM | #10722 |
Drives: GT86 Toyota
as Super Early Bird it will cost €2150.- (+ tax and p&p), 9 sets left (11:04pm CEST)
Bye for now Fred |
10-06-2019, 06:29 PM | #10723 |
Drives: DGM BRZ 6MT
I'm thinking about selling my BRZ, so I am listing my Phantom ESC for sale, in case anyone is interested: http://www.ft86club.com/forums/showt...50#post3264450
10-14-2019, 08:58 PM | #10724 |
Drives: Asphalt FRS 2014
Sold my FRS so my kit is available: https://www.ft86club.com/forums/showthread.php?t=137335.
ESC+OFH | Borla Axleback | Helix clear side markers | Opti-coat | Beatsonic v2 Sharkfin antenna | TRD lowering springs | TRD sway bars | 18" Enkei Kojins + PSSs
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
