Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Engine Swaps
Old 02-20-2020, 01:59 AM   #43
Zer0
Drives: 2015 frs
Do you think you could get the fa20 ecu to run a V8?
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
solidsnake11 (02-20-2020)
Old 02-20-2020, 08:23 AM   #44
Ashikabi
Ashikabi's Avatar
Honestly if he can run an inline 4, I don't see an issue beyond needing 8 ignition signals. If you use a wasted spark method I guess you only need 4, just each one drives 2 opposing coils
Sent from my ONEPLUS A5010 using Tapatalk
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
solidsnake11 (02-20-2020), Zer0 (02-20-2020)
Old 02-20-2020, 08:45 AM   #45
solidsnake11
Drives: brz
Yes I'm sure it could be done.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
Zer0 (02-20-2020)
Old 02-20-2020, 02:00 PM   #46
redlined600
redlined600's Avatar
Drives: Fr-s
Impressive! Best of luck.
redlined600 is offline   Reply With Quote
The Following User Says Thank You to redlined600 For This Useful Post:
Old 02-22-2020, 04:18 PM   #47
solidsnake11
Drives: brz
More progress; factory port ratio.
It doesn't have any water in it so I can't run it long.
Sounds like a two stroke.
https://youtu.be/YELmh5ZJ-RI
A lot of extra wires.
Size:  790.7 KBName:  20200222_153230_resize_67.jpg
Size:  707.9 KBName:  20200222_153234_resize_47.jpg
The Following 2 Users Say Thank You to solidsnake11 For This Useful Post:
Calum (02-22-2020), ML (02-22-2020)
Old 02-22-2020, 05:23 PM   #48
PulsarBeeerz
Impressive!
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
solidsnake11 (02-22-2020)
Old 02-22-2020, 06:43 PM   #49
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by solidsnake11 View Post
Motor mount bracket version 1 .
1970 mopar dart swinger motor mounts. $6.99 a piece autozone part #2265 also used in my sr20 samurai.
PassengerAttachment 184560
DriversAttachment 184561
Ok, wait a second here. Are those $7 mounts as they come? They just bolt up perfectly‽
The Following User Says Thank You to Calum For This Useful Post:
Old 02-22-2020, 07:05 PM   #50
solidsnake11
Drives: brz
$7 mount is the rubber part not the steel. I ground one side of the stud off on the bottom to slide in the slot on the BRZ crossmember.
Calum (02-23-2020)
Old 02-22-2020, 08:20 PM   #51
solidsnake11
Drives: brz
Dtc turned off
Cam sensor codes exhaust : not used
Cam oil control valve code : not used 2-4
Direct injection 1-4 open : my injectors are high ohm direct is low.
Bank 1 injector driver code : high ohm vs low
Set direct injector scale to 4 in all cells.
I'm using ls3(same as ls7) deccaped injectors with direct driver.
I have no idea what size, i couldn't find any info on them decapped.
Have about 4 flashes worth of tuning.
Maf and port injectors were tuned on the fa20
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-21-2014 12:16 AM
Release Series 1.0 FR-S & FT-1 Pics from NYIAS (Warning: iPhone Pics) TM Photos, Videos, Wallpapers, Gallery Forum 26 04-30-2014 03:31 PM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 Photos, Videos, Wallpapers, Gallery Forum 6 11-12-2012 12:29 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
