Old 09-08-2014, 10:51 PM   #71
jflogerzi
jflogerzi's Avatar
Also has anyone mounted one in the bumper where the stock air box snorkel would normally be? Like a Perrin size cooler?
Old 07-05-2015, 05:28 PM   #72
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Model Citizen View Post
Wondering if you ran the heat on the car during the sessions?
Ive been running an implementation of my own using the gr sti oil cooler plate on a rotorex sced car.
I see roughly the generally recognized 10 degree drop, but more importantly much faster recovery times. Especially with the heat on full (side vents out window center closed). In new england (not sweat your balls off hot ambient) im seeing peaks of mid 260 range, typically in the mid 250 range and very quick drops into the 230s and below when letting up. Last week (thompson) by the time the cooldown lap was done my oil temps were into the 220 range pulling into the pit.
The oe plates are absolutely not perfect, but they do have a clear positive effect
and introduce less risk of hose issues or punctured cores.
Why the heat on full? Can't we simply put the fan to the max ?
glamcem is offline   Reply With Quote
Old 07-12-2015, 09:18 PM   #73
philooo
Drives: 13' Scion FRS Track car
I wanted to report my temp and pressure.
today extremely hot day in miami, around 90F
my car is stock with a mishimoto oil cooler
during the fastest lap, as fast I as i can be ...
oil temp max 255F, oil pressure between 45 to 55
philooo is offline   Reply With Quote
The Following 3 Users Say Thank You to philooo For This Useful Post:
DAEMANO (07-12-2015), Lonewolf (07-13-2015), zdr93523 (07-12-2015)
Old 07-13-2015, 08:15 AM   #74
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
What oil and filter are you using?
-mike
AZP Installs is offline   Reply With Quote
Old 07-13-2015, 12:00 PM   #75
philooo
I am running Motul 300V 0W20 and the HKS filter (pink one)
oil and filter brand new.
FYI:
starting temp in pit after 5 min warmup idle: 168
temp after sitting 2 minutes on grid: 190
5 minutes in: 224
10 minutes in max temp: 255
after one lap cool down: 233
by the time I pit in: 224
Should I be worried ? Brooklyn BRZ First-Gen (2012+) -- General Topics 8 03-12-2014 12:18 PM
No CEL Should I be worried?? Mr.Jay Issues | Warranty | Recalls / TSB 5 04-05-2013 10:51 AM
a bit worried MontrealFRS Issues | Warranty | Recalls / TSB 7 09-14-2012 06:46 PM
5k oil change, worried about changes.... bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 09-11-2012 08:23 PM
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 07:55 AM
