11-10-2019, 05:32 PM | #1 |
Drives: LS3 Dry Sump BRZ
Hydraulic Steering Swap
I have been contemplating moving to a hydraulic steering rack, and I need some help from people who have done it before. I use my car for drifting and run partshopmax angle kit, also have an LS engine swap. After 1 or 2 runs while drifting, my steering loses all power steering while drifting.
I need to know if anyone has done a swap to hydraulic (alot of pro drifters have done it), what they recommend, and a little more knowledge about the install. |
11-13-2019, 02:53 AM | #2 |
Anyone?
11-13-2019, 06:39 AM | #3 |
TRACKBREAD
Forum has been down for 3 days, so not many may have seen your post lol.
The Following User Says Thank You to Yoshoobaroo For This Useful Post: | DarkPira7e (11-13-2019) |
11-16-2019, 05:09 AM | #4 |
Drives: 2015 frs
I have seen people go to a Nissan hydraulic rack from s14 Silvia or 240sx. If I went hydraulic I would get a electric power steering pump from a Mazda to keep a pump, and pulley off my accessories drive. Still hydraulic it would just be pumped with an electric motor instead of driven by the crankshaft.
11-16-2019, 05:53 AM | #5 |
Drives: Subaru BRZ
Ole @humfrz has a really neat solution, currently residing on a Deer tractor..
The Following User Says Thank You to JD001 For This Useful Post: | humfrz (11-16-2019) |
11-16-2019, 08:03 PM | #6 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
Is your power steering motor overheating and going into protection mode?
Work Hard. Play Hard.
2016 Oceanic |
11-16-2019, 09:31 PM | #7 |
Drives: Q5 + BRZ + M796
If this then some have added cooling fins to the motor with success, if I remember correctly.
11-18-2019, 11:40 AM | #8 | |
The Following User Says Thank You to ka-t_240 For This Useful Post: | JD001 (11-18-2019) |
11-20-2019, 11:36 AM | #9 | |
but would love to hear how you can use electric motor for hydro rack. I don't believe so. I have 0 warnings on my dash about the steering failure. |
11-20-2019, 12:21 PM | #10 |
Drives: 2015 frs
This link should explain it.
11-20-2019, 12:30 PM | #11 |
Drives: 2015 frs
Swaped in unit explained.
11-20-2019, 03:46 PM | #12 |
So I think I have figured out the problem. I am running PBM angle kit, which works for really lowered cars. As my car is higher than the typical car running the PBM angle kit, when I apply lock, the ball joint on the control arm maxes out earlier than it should as they are made to work with the car being much lower. Not sure if any of you have heard of this before. I can easily send some pics if you guys would like to know more.
11-20-2019, 07:58 PM | #13 |
Drives: 2015 frs
Yes I would like to see some pics.
Similar Threads | ||||
DIY - Swap clutch slave cylinder and hydraulic line for improved feel and control | Ultramaroon | DIY (Do-It-Yourself) Guides | 452 | 02-18-2023 09:58 PM |
Steering Wheel Replacement / Swap | CorranFox | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 07-24-2015 10:22 PM |
Steering wheel controls swap brainstorm | KenTK808 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-20-2015 01:13 PM |
Steering wheel swap questions | firl21 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-02-2014 08:27 PM |
AT Steering Wheel Swap | peri.Laynz | Engine, Exhaust, Transmission | 5 | 11-11-2013 08:53 AM |
