07-25-2018, 11:27 AM | #379 |
Drives: 2013 FRS DIRTY ASPHALT
07-25-2018, 11:31 AM | #380 |
Drives: 2013 Subaru BRZ
I'd just swap them from Left to Right. If the code changes from P0018, it's most likely that sensor that's bad. Just do the sensor first. If nothing changes, try the OCVs.
07-25-2018, 11:32 AM | #381 |
08-07-2018, 04:08 PM | #382 |
I know I've been quiet for awhile but my issue hasn't resolved itself. I'm thinking my only solution is buying another ECU, unless someone can enlighten me otherwise.
Assuming I need to go that route, for a 2013 Subaru BRZ Premium Manual, what ECU would I need to buy? |
08-07-2018, 06:34 PM | #383 | |
義理チョコ
https://parts.subaru.com/p/Subaru_20...2765AG511.html
08-07-2018, 09:16 PM | #384 | |
Do you have a flash device like tactrix or know someone with one. If so you can buy any secondhand ecu and just flash in the correct calibration. The hardware is all same auto manual and different years. Theirs dozzens of them on ebay for arround $100 usa |
The Following User Says Thank You to steve99 For This Useful Post: | Sportsguy83 (08-08-2018) |
08-08-2018, 10:18 AM | #385 | |
Drives: BlueBurz
Sent from my SM-G930V using Tapatalk |
08-08-2018, 11:35 AM | #386 | |
You could get a Tractrix for 179 and do it yourself and then have a good tool for flashing, Techstream and datalogging. |
08-08-2018, 01:49 PM | #387 | |
This worth looking at? I don't want to buy another OEM ECU to just have the same problem I'm having now in another few months. |
08-08-2018, 02:25 PM | #388 | |
I Love custom Turbo kits
Drives: Limited BRZ
11-16-2018, 10:04 PM | #389 |
@steve99 @Ultramaroon
Update time! I've procrastinated heavily on this due to frustration, travelling, etc. I finally took the time and met up with a local guy that tried to diagnose wtf is going on with my car. He tested camshaft sensors, OCVs, VVT angles, wire harness, etc. Took us a good 6 hours. In the end he couldn't pinpoint exactly what the issue was but he thinks it may be either: 1) Oil Pressure is low. Mechanically he says the car is perfectly fine. No knock, angles are perfect, etc. But if the oil pressure is too low, it could be causing the code to be thrown (P0016). How could it potentially be low? The camshaft oil filter. (Does our car have one of these?). He didn't have the tool/sensor to measure this, so we're just spitballing this idea right now. 2) ECU is gone bad again. I know I replaced it, but I'm being told since everything has been checked, it may be possible it went bad after 9 months. I'm looking into maybe borrowing one from a buddy for testing. Can I do this? If not, I may look into a cheap solution and buying a used one. |
11-16-2018, 11:21 PM | #390 | |
義理チョコ
The filters are here
11-19-2018, 08:51 AM | #391 |
When I rebuilt my engine I replaced those filters. Mine were clean but I could easily see these getting sludged up and restricting pressure. Unfortunately they aren’t easy to get to.
11-19-2018, 10:01 AM | #392 |
Going to see if I can find a used ECU to test first. If the code doesn't throw, that's the issue. If it continues, then I'll need to look into the filters. Crossing my fingers. Unless anyone here has an ECU I can borrow?
Similar Threads | ||||
P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
