Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
02-12-2016, 07:59 PM | #1 |
Drives: Toyota
Winjet Projector Problem
So I have recently ordered some winjet headlight..
I have this weird beam pattern that I can't figure out what's causing it. I have tried removing the bulb, and putting it back in. Didn't work. This is the passenger side. As you can see there is a laser beam like light. |
02-12-2016, 08:23 PM | #2 |
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
It looks like a bulb seating issue, perhaps a crooked bulb.
Did the Winjet headlights come with their own bulbs? Or did you have to reuse your factory headlight bulbs? If you had to reuse your factory headlight bulbs, they might not be the correct bulb type for the Winjet headlights. However, since you only have the issue with one headlight, one thing you can try is switch bulbs with the other side, and if the problem persists, I'd say it's a defective projector/headlight. |
The Following User Says Thank You to Si_Chris For This Useful Post: | Cole (02-12-2016) |
02-12-2016, 08:25 PM | #3 |
Drives: Toyota
I'm using the bulb that came with the winjet headlight. At first I had HID Installed on it but the HID bulb did not work so I took it out and reordered HID kit.
Then I put back in the H7 halogen bulb that came with it.. I have no idea what is causing that to happen |
02-12-2016, 08:28 PM | #4 |
Drives: 2013 FR-S 10 series [755]
defected item?
02-12-2016, 08:33 PM | #5 | |
02-12-2016, 08:48 PM | #6 |
Drives: Toyota
Gonna do that first thing tomorrow morning. They are identical H7 bulb. Question is .. If the bulb is faulty, it is still the projector projecting the light ..
This is confusing |
02-12-2016, 09:03 PM | #7 |
Drives: JRSC'd Asphalt FR-S
its probably the bulb position? just play with it a bit
02-12-2016, 09:42 PM | #8 |
Maybe the lens on the projector is crooked?
02-12-2016, 09:54 PM | #9 | ||||
Looks alot like an upside down bulb issue, the little tab on the top of the bulb sits in the direction of the H7 hinge. Also it should be all the way in it's very easy for a wire to get caught between the prongs and bulb or vice versa and effect the seating of the bulb.
02-12-2016, 09:55 PM | #10 |
Drives: Toyota
Gonna put in a HID bulb tomorrow or swap another H7 bulb tomorrow.. If that doesn't work.. I don't know what to do
If the lens s crooked wouldn't it just aim somewhere else? I don't think the bulb is upside down.. I tried reversing it , but it wouldn't lock in. |
02-12-2016, 09:58 PM | #11 | |
Also shameless plug the diode dynamics or morimoto HID kits fit perfect at 5000k or 5500k in these headlights they may be expensive but are totally worth it.
02-12-2016, 10:01 PM | #12 | |
It's easier to do correctly on a table with the headlights off the car [ame="https://www.youtube.com/watch?v=khbLOrzAvA8"]Scion FR-S Winjet JDM Replica Headlight - HID Install Video - YouTube[/ame]
02-12-2016, 10:02 PM | #13 |
Drives: FR-S 2015
Did you try to adjust the headlight already? That little screw u see at the back of the unit, also dont use the bulb that came from the unit, mine only lasted a month, so i decided to change it with hid
02-13-2016, 10:11 AM | #14 |
Drives: Toyota
I swapped it out for a HID bulb and another H7 halogen bulb , and I still have the laser beam problem.. What's next ?
Similar Threads | ||||
*** Winjet Projector Headlights & LED Taillights - IN STOCK @ Sonic Motor *** | Sonic Motor | Exterior Parts - Lighting | 500 | 07-29-2016 02:15 PM |
For Sale: WinJet FR-S chrome Projector Headlights (JDM LOOK) Best Price $150 | taylorz | Exterior Parts (Aero, Lighting, Etc.) | 17 | 02-25-2016 07:24 PM |
Cosmetic Non-projector Headlamps? & Opinion on Winjet, others | SR5 | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 04-11-2015 03:08 PM |
FS: NEW Scion FRS FR-S Winjet Projector Headlights Black w/ 6k HID, DRL Mod & Relay! | STS-V | Exterior Parts (Aero, Lighting, Etc.) | 2 | 04-22-2014 07:34 AM |
