09-21-2021, 08:44 AM | #23367 |
Drives: 2013 Scion FRS, 2012 Tacoma
So usually UPS drops off in my neighborhood between 6-8PM, meaning I expected to receive the rear sway bar yesterday and install it today. Luckily, UPS showed up around noon yesterday so I got the sway bar in (as well as the MXP catback). Great timing since as soon as I got the car back on the ground the sky opened up.
Took it for a quick drive to the store this morning, and I'm 99% sure the previous owner had a similar drop on it before it was traded in. The alignment was kind of funky before, but now it tracks straight and the steering wheel is no longer canted. |
The Following 2 Users Say Thank You to SportyTaco86 For This Useful Post: | soundman98 (09-21-2021), Wally86 (09-21-2021) |
09-24-2021, 01:59 AM | #23368 |
Drives: Subaru BRZ
New wheels. Copies of Work Meister 3 piece.
Sent from my SM-G973F using Tapatalk |
The Following User Says Thank You to Purist For This Useful Post: | RToyo86 (09-27-2021) |
09-24-2021, 10:34 AM | #23369 |
Drives: 2017 Toyota 86 (860 SE)
Paid it off.
The Following 16 Users Say Thank You to Cephas For This Useful Post: | ACT86 (09-24-2021), BAM_Nyblodx16 (09-27-2021), Dadhawk (09-24-2021), DarkPira7e (09-30-2021), Jdmjunkie (09-24-2021), jflogerzi (09-25-2021), KMA KiCKz (09-24-2021), MJones_RB (09-24-2021), NLSP (09-27-2021), NoHaveMSG (09-24-2021), Overdrive (09-29-2021), Purist (09-24-2021), RToyo86 (09-27-2021), soundman98 (09-24-2021), StraightOuttaCanadaEh (09-24-2021), Ultramaroon (09-24-2021) |
09-24-2021, 03:15 PM | #23370 |
1st86 Driver!
+5HP and +2MPG for not dragging that loan around any longer!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 7 Users Say Thank You to Dadhawk For This Useful Post: | bcj (09-25-2021), Cephas (09-27-2021), MJones_RB (09-27-2021), NoHaveMSG (09-24-2021), Overdrive (09-29-2021), soundman98 (09-24-2021), Ultramaroon (09-24-2021) |
09-25-2021, 03:55 PM | #23371 |
Because racecar Flat under panels from Verus and I already had the OEM JDM under panels. Turned out really good. Now just need Front Splitter and rear wing.
2013 Series 10 FRS #553
The Following 13 Users Say Thank You to jflogerzi For This Useful Post: | bcj (10-01-2021), boy_racer (10-23-2021), Cedric (09-30-2021), Cephas (09-27-2021), DarkPira7e (09-30-2021), kevaughan (10-16-2021), MJones_RB (09-27-2021), new2subaru (09-25-2021), NLSP (09-27-2021), Overdrive (09-28-2021), RToyo86 (09-27-2021), soundman98 (09-25-2021), wolffbite (10-06-2021) |
09-27-2021, 04:59 AM | #23372 |
Drives: 86 GT
Gave it some exercise to a local dam today. Played about with the camera settings.
The Following User Says Thank You to Compelica For This Useful Post: | NLSP (09-27-2021) |
09-27-2021, 10:52 AM | #23373 |
Drives: 17 Asphalt 86
Swapped in a AGM battery. I knew the old one was on its last leg but damn.. it practically fired up on the first half crank after install
Then gave it a bath and snapped a pic as it starts raining. |
09-28-2021, 05:01 PM | #23374 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I've got this same plan. Looks great.
-O/D
2016 FR-S, Hot Lava |
09-28-2021, 05:07 PM | #23375 |
Sittin' Sideways
My driver's door lock actuator has been on its way out for a few months now, getting worse daily. I was having to manually lock and unlock the door just to ensure that it was secure. I'm surprised it didn't even last 5 years. The passenger one never had a problem but would occasionally make a strangled puppy noise during actuation. So, like almost anything you've got pairs of on here, I bought replacement parts for both and a buddy helped me install them (did the real work, really), made it look like child's play. Had a while-we're-in-there moment and put in my black door opening handles since the door panel was off. Installed the center console and steering wheel black trim pieces too since we were on a roll, so now I've got working door locks and as blacked out an interior as I can get with OEM pieces.
-O/D
The Following User Says Thank You to Overdrive For This Useful Post: | Wally86 (09-29-2021) |
09-30-2021, 10:07 PM | #23376 |
Rust bucket enthusiast
Finally started it after a year or two.
The Following 8 Users Say Thank You to DarkPira7e For This Useful Post: | Cephas (10-06-2021), DarkSunrise (10-01-2021), kevaughan (10-12-2021), MJones_RB (10-06-2021), RToyo86 (10-04-2021), soundman98 (09-30-2021), villainous_frx (09-30-2021), Wally86 (10-01-2021) |
10-01-2021, 10:49 AM | #23377 |
Drives: 2015 Scion FR-S
I finally got around to installing a cover for my steering wheel which has been peeling for a few years now. I went with a Loncky cover. It took several hours to sew it on. I didn't do a perfect job, but it's an improvement.
I also replaced the faux carbon fiber two-piece dash trim with the BRZ single-piece leatherette with red stitching. I wish it was suede with red stitching, but it's still a lot better. |
The Following 5 Users Say Thank You to obscene_gesture For This Useful Post: | DarkPira7e (10-05-2021), MJones_RB (10-06-2021), pope (10-01-2021), RToyo86 (10-04-2021), Wally86 (10-01-2021) |
10-04-2021, 05:26 PM | #23378 |
Drives: 2016 FRS
Well, with FB and IG down, it's World Productivity Day.
Got these in the mail, so got them installed. Yes, I know brands don't match, -15hp. :/ |
The Following User Says Thank You to BigHugeFatGuy For This Useful Post: | MJones_RB (10-06-2021) |
10-04-2021, 06:07 PM | #23379 |
10-04-2021, 08:11 PM | #23380 |
Drives: 2016 FRS
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
