Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-05-2019, 12:00 PM | #15 | |
Slight correction, Motul is sold by the half liter. It's still cheaper than SRF, but it's not 1/4 the price. Buying by the half liter can be handy though if you just need to top up slightly when bleeding. I won't use fluid that was opened previously, so if you're needing to bleed frequently then it can be a bigger savings by using the smaller bottles.
03-05-2019, 12:07 PM | #16 |
Drives: Subaru BRZ
You save money going with Castrol SRF. You pay more upfront but the fluid lasts much longer. So far, I have nine hpde weekends on the current Castrol and will finally bleed the brakes just in case but the brake pedal still feels good.
The Following User Says Thank You to Code Monkey For This Useful Post: | wparsons (03-05-2019) |
03-05-2019, 12:26 PM | #17 |
Drives: BRZ 2018
According to most brake fluid comparisons the SRF gives the worst pedal feel among all racing brake fluids, on the other hand Endless has low Ph which MAY deteriorate hydraulic brake system and Projectmu isn't suitable for low ambient temperatures!
03-05-2019, 12:40 PM | #18 |
Drives: Subaru BRZ
Can't beat that wet boiling point though!
03-05-2019, 12:53 PM | #19 |
Drives: 2013 WRB BRZ 6MT
My anecdotal experience, I've only run OEM, RBF600 and Castrol SRF.
OEM: Does not hold up to extended lapping sessions. I got HP+ before my first ever lapping session. My first ever event was in the pouring rain so I never felt any fade but my 2nd event was dry and I had to do time-attack style sessions to keep brake temperatures in check. 1 out lap, 3 hot laps, 1 in lap, then let car cool down because pedal was too spongy to be comfortable to continue. Spongy pedal feel would return after everything cooled down though. RBF600: Got this for my 3rd HPDE and ran it with my HP+. Held up on the day of the event very well but the pedal would be spongy after the event and would remain until I did a partial fluid bleed. There was never any air in the system, just dark brown fluid near the calipers. Ran this for the remainder of my first year of track. SRF: Did the initial flush over 2 years ago now and I was still running that flush just fine until last fall and the only reason I did a bleed was because I took my BBK off to sell it. I would have been completely fine continuing to run this fluid. Ran it with EBC Yellowstuff and Winmax W5. I'll also note that I've run all 3 fluids in Canadian winter and the SRF is by far the best. The other 2 fluids get really thick when the temperature falls below freezing and seriously increases brake pedal effort but the SRF doesn't do this and the fluid moves as easily in the dead of winter as it does at the height of summer. |
The Following User Says Thank You to Lynxis For This Useful Post: | J1Avs (03-05-2019) |
03-05-2019, 01:19 PM | #20 | |
Drives: Subaru BRZ / Toyota 86 Experts
Pads wise, if you have never used track pads before and are afraid of the track pad life, we have prescribed various brake setups to tailor the driving experience per driving application. While our CSG pads are superior for track and racing purposes (shameless plug), not everybody can truly appreciate the consistency of the pads. The ones who are incredibly impressed with our pads are those who have experienced different compounds and just lacked the optimal bite, the control, and the level of consistency lap after lap. Obviously, looking forward to your impressions on them...so far everyone has had the same response. To the OP, please PM us if you got any questions on what you're looking for. |
03-05-2019, 02:29 PM | #21 | |
Drives: 2018 BRZ tS
The Following 2 Users Say Thank You to J1Avs For This Useful Post: | CounterSpace Garage (03-05-2019), Tristor (03-05-2019) |
03-05-2019, 03:45 PM | #22 | ||
I know it's sold by the half liter, it's $10/500ml on Amazon (you can sometime gets it for around $8/500ml) or $20/liter give or take. Endless RBF650 is also sold by the half-liter for about $47. ATE Type 200 and Castrol SRF are sold by the liter. Multiplying the half liter price by 2 to get an aligned comparison isn't a complicated thing... just saying. Quote:
Yep, I am switching to Castrol SRF myself for 2019. But it wasn't clear from OPs post whether he was intending a couple of HPDEs a year with 90% street driving or if he was going to consistently track. It's not a huge cost difference, but it is a cost difference that may be unnecessary. I did 8 track days last year and am planning 15 this year, I think for me Castrol SRF is a fair investment. I just bled my brakes every time last year, started out with Motul 5.1 and ended using Motul RBF600 which is what's in it now. If it's not a significant cost to the OP, the better fluid certainly won't hurt, but I don't think it's a mandatory change. It is mandatory to not use the stock DOT 3 fluid, but cheaper options will hold up to a single track day just fine. |
03-05-2019, 04:23 PM | #23 | |
Around here type 200 is about the same price as RBF600, but for twice as much (~$26/L of type 200 or ~$26/500ml of RBF600).
03-05-2019, 04:49 PM | #24 |
Generally speaking, Super ATE and RBF600 is a great starting point for those who have never used anything better than the DOT3 fluid. Once you gain a little pace and put a little extra heat, you're going to want something better. We do have RBF600 and RBF660 brake fluid on the shelf, but our clients generally need something more consistent like the Project Mu, Winmax, and other fluids.
03-05-2019, 04:52 PM | #25 |
Drives: BRZ 2018
@CounterSpace Garage, may I ask the low Ph (acid) of the Endless brake fluid could cause brake system problems in the long run?
03-05-2019, 05:01 PM | #26 | |
03-06-2019, 08:48 AM | #27 | |
Mind sharing where you're seeing it for $10/500ml on amazon? Best I can find is $19/500ml.
03-06-2019, 11:57 AM | #28 | |
https://www.amazon.com/Motul-Brake-f.../dp/B00CMZQMKS $9.99 w/ Prime Shipping, ships from and sold by Amazon.com |
Similar Threads | ||||
Carbotech XP8 Track Pads | Keenercarguy | Wheels and Tires | 1 | 07-19-2018 09:13 PM |
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 02:31 PM |
WTB: Track Pads | Whooosah | Want-To-Buy Requests | 3 | 05-03-2016 06:09 PM |
FS: Hawk Hp+ Track Pads | NorCal_Guy | Brakes, Suspension, Chassis | 3 | 09-08-2014 02:05 PM |
Track pads available? | ubersoph | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-18-2012 12:20 PM |
