Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
03-10-2015, 10:59 AM | #15 |
Just before track days, I swap pads and do a full brake fluid flush. The pedal is nice and firm on the street after that.
Since those are pretty cheap/simple changes, I'd start there.
2022 BRZ Build 2013 FR-S Build |
The Following User Says Thank You to DarkSunrise For This Useful Post: | Hyper4mance2k (03-10-2015) |
03-10-2015, 01:14 PM | #16 |
Is there a reason why you would not want to change to the appropriate brake pads and brake fluid for your driving application? Dust? Noise? Zero babygurl factor?
The Following User Says Thank You to CSG David For This Useful Post: | Hyper4mance2k (03-10-2015) |
03-10-2015, 01:28 PM | #17 |
Drives: 2013 FRS Whiteout
OP- i have the same situation, is not horrible or drastic but i do feel that after the first pump it stiffens up. This is weird and normally this would indicate some sort of issue but being that my car is fairly new i left it alone. I bleed the brakes almost every two months, i find it it helps but maybe its all in my head. Maybe its got something to do with the engine vacuum or something around those woods. I've started to wonder if SS lines would help or maybe even upgrading the fluid but being that you get this with all stock components and i get it with upgraded ones, it seems as if its a car issues(not a problem).
I even removed the speed bleeders i had and went back to stock thinking those guys had something do with it. Odd but i think there's nothing wrong, just something related to engine vacuum or something being that the power brakes work with the brake booster. @Hyper4mance2k
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post: | Hyper4mance2k (03-10-2015) |
03-10-2015, 02:51 PM | #18 |
I also notice the first pump feels a little soft, second pump feels really firm and responsive.. I am inclined to blame brake booster, but that's only because I can't figure what else might cause it. I have the Grimmspeed MC brace, and I still notice it.
The Following User Says Thank You to wheelhaus For This Useful Post: | Hyper4mance2k (03-10-2015) |
03-10-2015, 04:19 PM | #19 | |
Shadetree Project Ratchet
Drives: series.Blue
Kidding, but to be honest. If there is a problem, I want it warranty fixed, and replacing fluid or swapping pads could void the brake warranty if the dealer decides that they were the cause of the issue. I'm was also thinking the booster could have a slight leak.
The Shadetree Project: I turn wrenches
03-10-2015, 05:06 PM | #20 | |
The difficulty is proving that there's a problem in the first place. "Does the car come to a stop and can you activate ABS?" "Um, yeah, but it just doesn't feel ri.." "Then there's no problem. Kthxbye." |
03-10-2015, 05:19 PM | #21 | |
I've never heard of warranty being voided because you bled your brakes. Since you've experienced brake fade in the car, it's probably safe to assume you've degraded your brake fluid, especially since the symptoms you describe exactly describe air in your brake system. I'd recommend you bleed your brakes with a quality DOT4 once a year, and call it a day. You've been around race cars long enough; this should take you under an hour. |
03-10-2015, 09:59 PM | #22 | |
Drives: series.Blue
Thanks everyone. I think I'm going to bleed it this weekend and replace my fluid with some Torque RT700 and see how it goes.
The Following User Says Thank You to Hyper4mance2k For This Useful Post: | wparsons (03-11-2015) |
03-11-2015, 03:15 AM | #23 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Hampton Downs has two long straights and also two hard braking zones into hairpins. Turn one is a 3rd gear 70mph corner coming out of 5th gear at 105mph. Turns four and five are hard braking into tight hairpins, one flat but the second one falling after a crest. I first took instruction from a professional and his advice on these corners was "put the nose on the deck!!". I've taken that advice to heart at every track day I've been to since. The car has an aftermarket MC booster. I just noticed my right rear caliper has a dirty greasy residue on it after the track day (Toyota Festival 2015 BTW). I've just noticed it today. I'm still not driving the car as I blew up the rear right shock coming out of turn 3 and ran out of rumble strip - dropped it into a hole at 75mph. I've attached a photo - its the black crescent shaped mark on the bottom of the caliper. Any thoughts from the experts? I'm thinking this might be brake fluid.
BRZ001: Peace Love and Wheelies @metabrz on IG
03-11-2015, 11:09 AM | #24 |
Impossible to tell from the picture, but unless there is A LOT more of that on the inside of the caliper, it's not break fluid.
The pistons are on the inboard side of the caliper, so fluid would have to travel a long way to get to that part of the caliper carrier.
The Following User Says Thank You to wparsons For This Useful Post: | Metabrz (03-11-2015) |
03-11-2015, 11:47 AM | #25 |
SPACESHIP
Drives: BRZ Ltd 6MT WRB
You say you blew up your right rear shock, I'd assume that and the fluid are related.
The Following User Says Thank You to Tgionet For This Useful Post: | Tcoat (03-19-2015) |
03-11-2015, 08:43 PM | #26 | |
001 of 012
I was thinking the same thing 10 minutes after posting. Thanks for the input people.
The Following User Says Thank You to Metabrz For This Useful Post: | Tcoat (03-19-2015) |
03-19-2015, 05:26 AM | #27 |
Drives: 2013 FRS
Pedal feel is typically determined by rear brakes. With a floating caliper, the biggest cause of this issue is called pad kickback. Basically, while you're driving, the small amount the rotor moves, and the motion of the caliper while you're driving actually pushes the piston back in a small amount. Once your pads wear to say 60% or less, it's easier for the caliper to "walk" and push the piston in. That's what gives you that dead space.
In my experience, toss a set of pads on it, and you'll be good to go. |
03-19-2015, 12:15 PM | #28 |
Drives: '13 FR-S
Brakes on my car are pretty good. Not Porsche good (I drive a 964) but not squishy like you're describing at all.
Similar Threads | ||||
New Ferodo Brake Pads Feel Sticky | kodyo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 04-30-2018 03:22 PM |
How to fix light feel with the clutch pedal? | hot86lova | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-04-2014 01:06 AM |
Disappointed brake pedal feel, what am I doing wrong | ZionsWrath | Other Vehicles & General Automotive Discussions | 12 | 11-15-2013 02:03 PM |
why does the BRZ's brake feel firmer after a hard stop? | chenshuo | BRZ First-Gen (2012+) -- General Topics | 12 | 05-29-2013 05:32 PM |
Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 09-11-2012 12:29 PM |
