07-15-2021, 11:35 AM | #1 |
Drives: 2016 Subaru BRZ Limited
Clutch noise?
I have a 2016 BRZ and it’s got about ~75,000 miles on it. Recently I’ve noticed a grinding noise when on a hill and starting from a stop as I release the clutch to start moving. Is my clutch worn already? Do any of you know what this noise could be? Thank you
07-15-2021, 03:48 PM | #2 |
義理チョコ
If you put it in high gear at a stop and let go of the clutch, does the engine immediately stall? If not, worn clutch.
Otherwise, suspect worn TOB about to take out your clutch. Transmission comes out either way.
The Following User Says Thank You to Ultramaroon For This Useful Post: | jcw99 (07-24-2021) |
07-15-2021, 07:42 PM | #3 |
Ok I’ll give it a shot tonight. Thanks!
07-22-2021, 01:22 PM | #4 |
Drives: car
@jbarone96 its the throwout bearing. They get worn out, develop play and also scratch up the shaft they ride on. Worse case scenario they burn up and blow up. I'm on my third throw out bearing. I think the best way to test for the noise is on deceleration going downhill though.
07-23-2021, 11:29 PM | #5 |
Yeah I did a clutch test and it passed. It must be the TOB. I got a quote to just take the trans off from a local shop and it’s $957 in labor. I plan on adding boost in the near future so should I just have them install an upgraded clutch and clutch fork while they are in there? Seems logical to just do it that way and I don’t have the equipment to remove the trans on my own. Thanks for the responses!
07-24-2021, 12:28 AM | #6 |
義理チョコ
Stay with the stock clutch so you can't over-torque the transmission.
Similar Threads | ||||
Anyone know what this clutch noise is? | popsicle | Issues | Warranty | Recalls / TSB | 13 | 05-30-2020 12:54 AM |
Whirring noise on clutch | airrick | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 17 | 04-23-2020 03:32 PM |
Clutch creaking noise (not the clutch fork one...) | treminaor | Issues | Warranty | Recalls / TSB | 59 | 10-23-2017 01:53 AM |
Clutch noise new to-day | Skye | Issues | Warranty | Recalls / TSB | 16 | 11-19-2016 11:42 AM |
Clutch scraping noise | 8 six | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-05-2015 02:39 PM |
