Old 12-23-2011, 05:01 PM   #57
mike2100
mike2100's Avatar
Drives: 23 BRZ
Originally Posted by BeachNative View Post
I'm thinking an upgrade to the Brembos (w/steel lines) is going to be a must...
Why is it a must? What is the fascination with upgrading the brakes on the car? Especially since nobody here has driven it yet and has no idea how much it will take to fade the brakes.
mike2100 is offline   Reply With Quote
Old 12-23-2011, 05:25 PM   #58
Z.Tune
Drives: E46 M3/Z34
hell yeah, very good info
Z.Tune is offline   Reply With Quote
Old 12-23-2011, 05:57 PM   #59
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
Originally Posted by bFreed View Post
Any info on diff ratio?
GT5 says 4.10
goldenfri is offline   Reply With Quote
Old 12-23-2011, 07:33 PM   #60
Leeky
3S-GTE Junky
Leeky's Avatar
Drives: Toyota Celica GT-Four ST205
Errrrrrm.... is it me or are those front hubs lifted straight from the Impreza and have holes for front driveshafts
Boosted 4WD 86 anyone? GT-486
Leeky is offline   Reply With Quote
Old 12-23-2011, 08:14 PM   #61
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Originally Posted by Leeky View Post
GT-486
GT-Pentium or GTFO.
old greg is offline   Reply With Quote
Old 12-23-2011, 10:19 PM   #62
Steve
Steve's Avatar
Drives: 6MT
Originally Posted by old greg View Post
GT-Pentium or GTFO.
..........lol
Steve is offline   Reply With Quote
Old 12-23-2011, 11:24 PM   #63
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
AWD won't happen with the engine where it is unless they shove a diff in front of the engine
Homemade WRX is offline   Reply With Quote
Old 12-24-2011, 03:23 AM   #64
TheRoadWarrior
Much damage?
TheRoadWarrior's Avatar
Drives: Renaultsport Clio200
Yes that was the first thing I noticed lookin at those pictures! it's surprising if true. I would have expected the car to have its own knuckle design. I have no interest in 4wd but I wonder if greddy could have swapped them in from the Subaru for some reason.
Edit
You can clearly see it in this picture
Good article I thought, not edited together very well as lots of stuff gets repeated but there is some interesting insights.
Edit2
He goes on about how the struts are quite far inboard giving a high leverage ratio, if the hubs are lifted from the scoobie that could explain it as I imagine it has wider/different offset wheels which need to clear the struts.
TheRoadWarrior is offline   Reply With Quote
Old 12-24-2011, 10:55 AM   #65
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's not. That's been my point for awhile
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-24-2011, 02:09 PM   #66
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
It's only for looks at this point because it doesn't make much sense to use brakes designed for a car that's 500 pounds heavier with a 60/40 weight distribution. I think it would be wise to wait until someone can test a BBK with the proper rotor diameter and piston sizes, especially if looking to track the car.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 12-24-2011, 02:51 PM   #67
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
This actually makes me wonder if the front hub design is similar to the rear hubs on 90's Nissans. If they're a bolt on design as opposed to a press in design, then the 5x114.3 hub swap that everyone is clamoring for should be pretty straightforward.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 12-24-2011, 04:15 PM   #68
Homemade WRX
Originally Posted by TheRoadWarrior View Post
Edit
Looks like a bolt in wheel bearing to me
Old 12-25-2011, 05:34 PM   #69
Leeky
3S-GTE Junky
Leeky's Avatar
Edit
Edit2
I pointed the Impreza front hubs out on the concept car (old thread somewhere on this forum) so i was totally surprised to see the hubs still from the impreza on the road car!
Im positive we'll see somebody do a total WRX Engine/Drivetrain swap shortly after the car is released meaning a Turbo'd 4WD GT86
Old 12-25-2011, 06:19 PM   #70
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
I would be in for that
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
fr-s brakes, fr-s differential, fr-s forums, frs brakes, frs differential, frs forum, frs forums, scion fr-s brakes, scion fr-s chassis, scion fr-s diff, scion fr-s forum, scion fr-s forums, scion fr-s suspension, scion frs brakes, scion frs chassis, scion frs differential, scion frs forum, scion frs forums, scion frs suspension
MOTOIQ A Tech Look Under The Scion FR-S poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 0 12-23-2011 03:45 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
Stretched FT-86 chassis to spawn next generation Lexus IS Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 17 12-02-2010 02:27 PM
Brakes, track set up? CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-29-2010 08:16 PM
