Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-09-2022, 01:20 PM | #1 |
Drives: SSM BRZ
Oil Fill Cap Broke
Hello,
While changing my oil today on my 2013 brz. The stock oem plastic oil fill cap snapped and a piece the size of a finger nail broke into the fill hole. Any suggestions and anyone know how bad this will effect the engine?? Thanks
10-09-2022, 02:33 PM | #2 |
義理チョコ
Tough call. Would be captured by the pickup screen but might hang up in the pickup tube itself. If it doesn't come out draining the oil, drop the pan and remove it to be safe.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
10-09-2022, 03:19 PM | #3 |
ProCrastinationConsultant
but then the fill opening is above one of the cam shafts. do the cams drain directly into the lower pan?
10-09-2022, 06:31 PM | #4 |
義理チョコ
They do. That's the main reason for all the shit in the screens from the j02 recall. I could see it being chewed up on the way down, but
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (10-10-2022) |
10-10-2022, 12:38 AM | #5 |
i'm really more curious how a hand-tightened plastic cap on a machined aluminum surface cracked enough to fall apart...
10-10-2022, 01:44 AM | #6 |
Rust bucket enthusiast
I'm betting it was over tightened and they used vice grips or something to get a hold on it
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | soundman98 (10-10-2022), x808drifter (10-11-2022) |
10-10-2022, 05:05 AM | #7 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
The Following 2 Users Say Thank You to 22R For This Useful Post: | DarkPira7e (10-10-2022), x808drifter (10-11-2022) |
10-10-2022, 09:44 AM | #8 |
Drives: 2017 BRZ w/PP
10-10-2022, 10:26 AM | #9 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Very strange. Impossible to cross thread. It's like a Playskool motor skill, eye-hand coordination toy. Need the full story.
The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | DarkPira7e (10-10-2022), soundman98 (10-11-2022) |
10-10-2022, 04:40 PM | #10 |
Drives: SSM BRZ
The cap was too tight so I used pliers to clamp the insides of the handle(where theres a U shaped space on each end)and after getting it off. Rested it on the opening and didn’t know one end was cracked so once i lifted it up, the piece fell right in…. Rookie mistake.
Sadly, drained the oil and nothing came out but ive driven it for around 100kms and no issues so far. Will probably change the oil again in a few days just to be safe until my mechanic is free to pull the oil pan. He did say there shouldn’t be too big of a problem bit better safe than sorry
The Following 5 Users Say Thank You to congee For This Useful Post: | Sapphireho (10-11-2022), soundman98 (10-11-2022), Tcoat (10-10-2022), Ultramaroon (10-10-2022), x808drifter (10-11-2022) |
10-10-2022, 05:29 PM | #11 | |
義理チョコ
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | congee (10-10-2022), x808drifter (10-11-2022) |
10-10-2022, 06:46 PM | #12 |
Drives: SSM BRZ
Hoping its just sitting at the bottom of the pan or lodge into something but it should fit through the drain hole. i suspect it’s probably somewhere in the oil fill area since theres a bunch of random gears/mechanical parts near the opening. Probably trapped inbetween something. My biggest fear is that it breaks down into smaller pieces or melts and then somehow gets through the pick up screen and filter. Going to put in new oil again and then again in a month or so just to be safe.
10-10-2022, 11:01 PM | #13 |
義理チョコ
Meh.... Don't waste good oil.
10-11-2022, 07:02 AM | #14 |
¯\_(ツ)_/¯
So to clarify size, it is this piece?
Similar Threads | ||||
Rocker arm broke and broke my valve cover... | j0hnnykthx | Issues | Warranty | Recalls / TSB | 9 | 08-07-2020 08:12 AM |
Over fill oil | Halo_2 | Issues | Warranty | Recalls / TSB | 14 | 07-18-2020 09:18 AM |
Is it necessary to pre-fill the oil filter? | lupindub | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 27 | 06-07-2016 03:58 PM |
Fill and paint? or PDR... | rhythmM | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 02-12-2014 09:36 PM |
First fill-up... | mit_peid | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 01-20-2013 05:46 PM |
