Old 01-31-2013, 05:32 PM   #43
Hawk77FT
Drives: GTS 86
Originally Posted by F1point4 View Post
Post_break was right, I decided not to use both pieces together. I gave the part to my colleague to use in his BRZ.
I agree with this statement.
Boring out the whiteline part to make the perrin piece fit is the solution to making these work until one vendor decides to change their piece. Personally I wasn't comfortable modifying a part where much effort was spent doing R&D; felt like I was undoing all of that.
Putting them together does remove all the play in the gearbox mount IMO. To truly do it right you would want to stiffen up the engine mount and diff mounts as well.
More NVH is expected as the the gearbox is so close to you and there isn't much sound insulation in the gearbox tunnel.
Interesting...well as I said they both have different purposes and yes they will remove the play in the gearbox and also it will require stiffening the engine mounts as well...but it will happen I guess at some point. i dont see anything wrong with modifying one part to fit other. If you think about it Perrin modified the factory stify to a better one too. yes, maybe there should be a bit of a play in the perrin part when inserted through the Whiteline. One millimeter would probably be enough rather than having it tight. That is what the original part was in comparison to Whiteline...so this might be a solution. I will investigate more over the weekend.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
ProjectD (01-31-2013)
Old 01-31-2013, 05:57 PM   #44
Hawk77FT
Drives: GTS 86
Originally Posted by stevo_12v View Post
I'd tend to agree with the above post.
Hence why I went with the CUSCO/Perrin hybrid myself. Slightly MORE noise, but LESS vibration(more 'give' in that cradle brace assembly) - which I think is a good thing.
Driving it with the WL KDT926(alone by itself) for me just didn't feel right... or maybe I'm just getting too old and don't like the shakes.
Yeah you might be gettign too old buddy! How did it feel with the Whiteline it self? I would think that the noise is generated more because of the Perrin part rather than the Whiteline.
Old 01-31-2013, 06:19 PM   #45
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Whiteline was fairly quiet. I had switched the transmission mounts 3x times.
1) Whiteline KDT 926 by itself. - quietest of the three combos, but more pronounced vibration.
2) Cusco by itself - quite noisy
3) Cusco/Perrin combo - slightly less noisy
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
Hawk77FT (02-01-2013), jliongh (09-27-2016), normancw (01-14-2014)
Old 02-16-2013, 01:09 AM   #46
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Just finished mine. Crispier shift! also installed perrin rear shifter bushing. Noise is there but got used to how noisy the car already even before the install. Thanks for the write up! Clean and clear!
tintumz22 is offline   Reply With Quote
Old 07-07-2013, 03:44 PM   #47
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I put bushing word "Whiteline" facing front.
does it really matter? if it is, i am just going to change it again when i do my oil change.
too tired to fix it now since i installed front pipe with it.
Old 07-08-2013, 10:10 AM   #48
zc06_kisstherain
Drives: SWP BRZ
ok. i just went to whiteline homepage and their installed picture is what i have.
http://www.whiteline.com.au/product_..._number=KDT926
I guess it doesnt really matter where word goes to either front or rear
Old 07-09-2013, 07:20 AM   #49
jdm-az-fuk
Drives: 2013 Fr-S
Doing this swap this weekend
jdm-az-fuk is offline   Reply With Quote
Old 08-01-2013, 04:30 PM   #50
zc06_kisstherain
Drives: SWP BRZ
Originally Posted by Daniel TongTechnical Sales SupportRedranger USA/ Whiteline USA
Thank you for contacting Whiteline. I apologize your email was not replied to in a timely manner. The KDT926 will work effectively regardless of which direction the word WHITELINE can be read from. The orientation facing front or rear is cosmetic. Once again, we apologize for the delay. Please do not hesitate to contact us via phone or email, if you have any additional questions. Thank you for your support.
ok. I just received confirmed e-mail back from Whiteline and install from front or rear doesn't really matter. hope this helps for many memebers who is going to install bushing.
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
normancw (03-07-2014)
Old 09-20-2013, 11:10 AM   #51
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
When you guys say this style increased noise how so? I'm asking cause I'm about to remove the Perrin one I have as it has this annoying whine. I figured this whiteline one being poly and lateral style would eliminate that, am I incorrect in thinking this?
I like what the Perrin T did to tighten up feel however at cruise speeds the faint but consistent whine when accelerating in well..not cool for me at least.
Old 09-20-2013, 11:19 AM   #52
zc06_kisstherain
Drives: SWP BRZ
you don't have to pm me for this. i visit forums everyday.
I never heard your issue and i never noticed any sound after installation as well. hope this helps.
few members already reviewed both whiteline and perrin's.
I don't remember quite but heard whiteline's cover sides movement more than Perrin's. Perrin does cover front and back but doesn't cover sides as whiteline's. by looking at both designs, you know.
Old 09-20-2013, 11:23 AM   #53
OICU812
Just a dude
OICU812's Avatar
Ok sorry to have bothered you I don't know who visits daily and who doesn't.
Thx for answer none less that you didn't notice nvh differences.
Old 09-20-2013, 11:31 AM   #54
Lakers86
Lakers86's Avatar
Drives: Asphalt FRS
Awesome write up and photos!
Lakers86 is offline   Reply With Quote
Old 09-20-2013, 11:33 AM   #55
zc06_kisstherain
Drives: SWP BRZ
I hope you don't feel i offended you in anyway.
reason for for i installed whiteline instead of perrin is that installation is little bit easier and filling that empty spot seems much better than perrin's.
OICU812 (09-20-2013)
Old 09-20-2013, 11:47 AM   #56
OICU812
Just a dude
OICU812's Avatar
No worries at all. Will be installing my WL one soon I've had a good feel for what the Perrin one does and should be interesting to see,feel differences.
bushing, diy, positive shift kit, whiteline
Subaru Dealer Whitelist (positive experiences, truthful dealings) Deslock BRZ First-Gen (2012+) -- General Topics 285 05-15-2023 05:35 PM
Whiteline Positive Shift Bushing? wootwoot Engine, Exhaust, Transmission 20 11-05-2012 07:45 PM
IN STOCK!!! Whiteline FR-S/BRZ Positive Traction and Shift Kits! 10k Redline Brakes, Suspension, Chassis 6 10-16-2012 05:32 PM
which one is positive and negative frs Scion FR-S / Toyota 86 GT86 General Forum 1 08-04-2012 10:42 PM
Speaker wiring. Positive or negative?? |-Goku-| Electronics | Audio | NAV | Infotainment 9 07-28-2012 10:24 PM
