Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
04-06-2018, 01:53 PM | #29 | |
Loading...████████] 99%
Drives: #0517
Is there any downside to the Exedy Stage 1 clutch over the OE replacement aside from cost? And should I go ahead and purchase a replacement flywheel or see first if I can just have it resurfaced? My planned list is currently:
Any other suggested parts to add to this list or any upgraded bushings I should look into while getting this work done?
R1 3 5
╘┼┼┤ . 2 4 6 |
04-06-2018, 03:36 PM | #30 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Depends on your purpose of the vehicle and how many miles you have. I'll lump it into one of two categories: 1) daily driving/ occasional spirited driving or 2) autox/trackday car.
If you are tracking/autoxing, I'd say replace the flywheel with a lighter one. Keep in mind there are various weights of flywheels. Too light, you will need to rev the engine higher and you will need to change your driving style to get moving so do your homework on what suits your needs. The clutch type depends on how crazy your car is. Look up how much torque each can handle. If you are staying NA, anywhere from OEM to stage 2 is fine. The clutch feel will be affected the higher stage you go since it requires more bite (stiffer pedal). If its just daily driving/occasional spirited driving resurface flywheel should be fine. I've heard there isnt too much of a difference between OEM and stage 1. Stage 2 is still very manageable but slightly more noticeable with the clutch pressure, but overkill IMO (assuming you are still NA). It all depends on what you are looking for... soft cushy pedal for DD or something to hold up to the added power.
The Following User Says Thank You to hyper4mance For This Useful Post: | asdf (04-06-2018) |
04-06-2018, 04:16 PM | #31 |
Maybe the MTec spring
The Following User Says Thank You to gravitylover For This Useful Post: | asdf (04-06-2018) |
04-06-2018, 06:15 PM | #32 | |
Drives: #0517
Exedy has a "lightweight flywheel" at 13.8 lbs which is lighter than the stock 20.x, but not as light as the ~10lbs ones out there. Just not sure if it's worth the $400 price tag! Good call, I have them sitting in original packaging in the garage and never got around to installing them... this would be a good time to throw them in!
R1 3 5
╘┼┼┤ . 2 4 6 |
04-08-2018, 02:54 PM | #33 |
Drives: FR-S,GTI
I finished changing my TOB and clutch and it was super easy. The TOB change took about a minute and the clutch change took maybe 15 minutes.
Now removing the transmission was a BITCH. Took two days. But a lot of the problems were because I didn't really know what I was doing. And I did take my time. The hardest part was breaking loose the bolts. They were torqued down like you wouldn't believe. Especially the drive shaft. It felt like those bolts were welded on. But you get a long enough breaker bar and something is going to give. There's no way anything was torqued to spec. But my transmission was replaced BY THE DEALER GORILLAS when the car was new. (Came with a bad 5th gear syncro.) They probably set the impact wrench to 100 Lbs/In and went at it. I haven't replaced the transmission yet because I really need the proper jack to get it back in place. I went to Harbor Freight this morning to get a crawler and a jack, but the jack I wanted was out of stock. They said they're getting 5 in tomorrow. The thing goes from 2 inches to like 26 inches. For $99. That's 80 bucks with the coupon. Should be perfect for the job. And many other things. So I think I can probably get the car back together and running in maybe 2 or 3 hours. Taking my time, not forgeting anything. (Like putting the oil back into the transmission). I have some pictures to share. I'll try to post them now. We'll see how that goes. |
04-08-2018, 03:02 PM | #34 |
Drives: FR-S,GTI
This is the melted TOB.
04-08-2018, 03:13 PM | #35 |
The Following User Says Thank You to humfrz For This Useful Post: | WNDSRFR (04-08-2018) |
04-08-2018, 03:13 PM | #36 |
Drives: FR-S,GTI
This is the new clutch vs. the old. For a clutch with 129,000 miles on it, it looks pretty good. Probably could have gotten another 100,000 miles out of it. Also the flywheel is pristine. So I'm not going to touch it. I'm debating whether to change the little bearing on the flywheel or not. It came with the kit but I don't know if it is pressed in or not.
The Following User Says Thank You to WNDSRFR For This Useful Post: | trvth (04-10-2018) |
04-08-2018, 03:29 PM | #37 |
Drives: FR-S,GTI
This is what I used to drop the transmission. I borrowed this little POS jack from my neighbor and had to fabricate this crazy adapter. Luckily I just bought a welder recently to fix my exhaust problem and learned to use it. My old aftermarket resonator got noisy because all the glass pack was gone allowing the screen the rattle like hell. So I bought a new glass pack resonator and welded it to the pipes cut off from the old one. The adapter is made from the old resonator I used for welding practice.
There's no way I could get the transmission back with this POS, That's why I'm waiting for Harbor Freight to come through. The problem with this jack is it won't go low enough. I could remove the transmission with it, but it was still too high to roll from under the car. I ended up getting a big thick blanket, laid it on the ground and rolled the transmission off the jack and on to the ground. It "only" weighs 86 lbs. |
04-08-2018, 03:33 PM | #38 |
Drives: FR-S,GTI
I got this on day 2. I should have gotten it 30 years ago!
Well it's time for several beers. I feel good. I did it! |
04-08-2018, 03:46 PM | #39 |
義理チョコ
You caught it
just in time. Bearing had failed and was heating up. Temp went past the drop temp of the bearing lube and you changed it before it melted the plastic guide bushing.
04-08-2018, 04:16 PM | #40 |
Drives: FR-S,GTI
Yeah I got really lucky that it failed so close to home. I just pulled off the interstate and depressed the clutch and I could feel it start to melt. And smell it. This is the damage done after maybe 7 clutch engagements after the failure. Yeah, I was lucky. There was no other damage done other than the bearing.
04-08-2018, 04:19 PM | #41 |
Drives: FR-S,GTI
Oh
By the way, this is the OEM clutch. It's an Exedy |
The Following 2 Users Say Thank You to WNDSRFR For This Useful Post: | asdf (04-08-2018), zc06_kisstherain (04-10-2018) |
12-15-2020, 07:49 PM | #42 | |||
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
Got the OEM Throwout bearing & OEM Pilot bearing. How do you guys feel about the pilot bearing that comes with the Exedy Stage 1 kit, is it basically an OEM? Quote:
BTW I just picked up both OEM bearings, and waiting on a rear main seal, planning to decide on a clutch and order it soon.
NARFALICIOUS
Noob Poster 1988 | 2016 |
