Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-02-2015, 09:33 AM | #15 |
Drives: 2013 SWP BRZ
Yep was going to say, upgrade the BOV spring.
Just for reference, ill be using the Boomba Check valve for my setup. |
The Following User Says Thank You to xxscaxx For This Useful Post: | drambo136 (06-02-2015) |
06-06-2015, 11:39 AM | #16 |
Drives: 2013 FRS
Hmm interesting. I have the catch cans here and haven't put them on yet but I can say that my idle is nice and strong w a 8psi spring w my bov being on the ic passenger side. I'll report back after the catch can install.
What kind of idling symptoms ? Stock injectors ? |
06-06-2015, 12:29 PM | #17 |
Drives: 2013 Hot Lava
Idle fluctuates any were from 2000 to 0 rpms. My bov is on the intake pipe so I'm assuming its that. I have a yellow spring on the way. I have DW 700cc injectors
06-06-2015, 01:15 PM | #18 |
Drives: 2013 FRS
06-06-2015, 01:21 PM | #19 |
I disconnected the ccs the other day to see if it would idle but no luck. I put the injectors in with the turbo so I can't comment on whether or not its that. My tuner said it wouldn't be that tho. I guess he can see that they r working.
If u haven't noticed I'm pretty new to tuning and fi |
06-06-2015, 01:26 PM | #20 | |
Drives: 2013 FRS
So disconnecting the catch can didn't help with idle. Have you driven the car for idling issues? For example if you rev to 3 k and let the idle come back down will it die and or if you're driving and push in the clutch at 3k and coast to a stop the engine will die ? Sent from my iPhone using Tapatalk |
06-06-2015, 01:29 PM | #21 |
Yes if the car is warm and I let the rpms drop to idle anytime it'll stall
06-06-2015, 07:19 PM | #22 |
Drives: 2013 FRS
06-06-2015, 08:36 PM | #23 |
It fluctuates anywhere from -0.8 to 5.5
06-07-2015, 06:13 PM | #24 |
Idk if this can help diagnose the problem, but heres a log i did yesterday. It has a couple 2nd and 3rd gear pulls. Please keep in mind that I need a new clutch(it's waiting to be installed).
http://www.datazap.me/u/drambo136/jd...og=0&data=6-30 Last edited by drambo136; 06-07-2015 at 06:36 PM. |
06-09-2015, 06:56 PM | #25 |
Ok im annoyed. I replaced the bov spring with a yellow one today and at first it swwmed fine, but then it started to stall again and I got the same code again.....fml
06-10-2015, 11:06 AM | #26 |
NASA SpecE30 Racer
Are you logging with EcuTek? If the MAF is staying closed at idle now, then it is something else and could be your tune.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
12-23-2015, 09:28 AM | #27 |
Drives: 2013 BRZ black
12-23-2015, 10:47 AM | #28 | |
Drives: 2013 Asphalt FRS
First off you need to fix the BOV it should only be open when relieving boost. Change the spring until it remains closed at idle. Under boost it will remain closed from the boost pressure on top of the spring, when you left off the gas it will open because the pressure will be greater on the other side of the BOV. That has to be done first, to fix idle quality. Then hook up the catch can as the instructions say on the passenger side. On the drivers side let the catch can vent to atmosphere. If you try to use the turbo inlet as a source of vacuum it will pull oil out of the motor and into the turbo. PM me if you have further questions. I use dual Radium Catch cans. Where is your BOV getting its vacuum source from?
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-23-2015 at 11:03 AM. |
The Following User Says Thank You to FRS Justin For This Useful Post: | Kris86 (08-30-2016) |
Similar Threads | ||||
Radium Engineering Catch Cans | FRS2000 | Engine, Exhaust, Transmission | 111 | 03-02-2016 12:49 AM |
FS: Radium Universal Catch Can - BRZ/FR-S Setup | F1point4 | Engine, Exhaust, Bolt-Ons | 8 | 04-09-2015 01:08 PM |
Radium Catch Can - $150 - SOLD | TemeCal | Engine, Exhaust, Bolt-Ons | 2 | 02-04-2015 09:59 PM |
Parting out car - Radium Catch Can, XM Receiver and more | TemeCal | Engine, Exhaust, Bolt-Ons | 59 | 01-28-2015 04:49 PM |
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? | OICU812 | Forced Induction | 7 | 10-14-2014 12:36 AM |
