11-18-2021, 06:21 PM | #421 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
The Following User Says Thank You to Turdinator For This Useful Post: | J95 (11-19-2021) |
11-18-2021, 07:47 PM | #422 | |
Drives: MY14 BRZ, MY06 WRX
ACE are a bit different, in that the 'overpipe' is actually the last merge collector in the '4-2-1' series, so the 'merging' is done over a much longer pipe length overall. With the JDL, the merging is all done before the overpipe junction. All Wayno's EL tunes have zero per cylinder compensation, but his ACE maps run quite a bit more timing than his other EL maps. Really want to see you succeed, but we may all be hoping for too much from the JDL design, to expect it to run right on an off-the-shelf ACE tune. |
The Following User Says Thank You to SydBRZ For This Useful Post: | J95 (11-19-2021) |
11-18-2021, 09:17 PM | #423 |
Drives: Subaru BRZ 2016
Yes I have, but not on the dyno unfortunately. I did collect data during street pulls and the engine load or VE did show a similar waviness, so I assume that would be reflected on the torque curve too, even if it was shifted up a little.
My objective was to get a first experience with dyno testing, and some sort of a baseline of what my setup can achieve. To be honest the choice of rom between ACE and EL was a bit arbitrary. |
The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (11-19-2021) |
11-19-2021, 03:39 AM | #424 | |
However... why did you choose the ACE tune over the EL tune? Our JDL 4-2-1 is a short EL, not a long one like the ACE Edit: Oh ok! I did not see the last posts In my case, I will be purchasing the regular EL. The only difference should be the zero per cylinder compensation though |
11-19-2021, 03:46 AM | #425 |
Drives: brz 2017 hksv2
guys, both headers require more logging and retuning
anyone posting dyno or logs with wayno tunes and ace or JDL have subpar results compared to other well known ecutek tuner so it worth if you spend some time adjusting afr and increase timing to knock limit, don t just put OTS tunes and pretend they work ideally from the beginning |
11-19-2021, 08:02 AM | #426 |
Nobody is pretending it is ideal. I just did some testing for the sake of it and posted the results, thinking some may find it useful or at the very least somewhat interesting. That's all there is to it.
11-19-2021, 08:21 AM | #428 |
Ah ok, it does not say that on the website. I will order the EL soon considering the ACE is specific for the long length and then try to adjust AFR and timing as he describes and I guess that the most we can do with OFT tune...
11-24-2021, 11:20 AM | #429 |
In the final tune I settled on, which is based on the Wayne roms, I actually tuned out the torque bump I was getting at 4600 rpm to make it more constant across the rpm range. Some people may find that to be an odd decision!
11-24-2021, 01:08 PM | #430 |
What do you mean about tuning out, I mean what did you change?
11-24-2021, 03:53 PM | #431 |
I reduced the angles in the intake and exhaust AVCS tables on the 4600rpm row.
The Following User Says Thank You to NicFromTheNorth For This Useful Post: | J95 (01-28-2022) |
08-01-2022, 09:49 PM | #432 |
What have people been doing about the contact between the header and underbody shield? Cut to form? It seems to bow out a solid 1/4 to 1/2 inch on Perrin motor mounts.
08-01-2022, 10:14 PM | #433 |
Drives: frs
The Following User Says Thank You to Teseo For This Useful Post: | strat61caster (08-02-2022) |
08-31-2022, 11:51 AM | #434 |
Drives: 17 Asphalt 86
Put my order through this week.
Given a rough ETA of 4 weeks, they're prepping for the next batch of builds. |
Similar Threads | ||||
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
