Old 02-25-2013, 10:39 AM   #29
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
The part of the car that you drilling the hole, is that plastic or metal? if it's metal, would it start to rust in a couple of years?
chenshuo is offline   Reply With Quote
Old 02-25-2013, 11:22 AM   #30
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
Plastic. It's just the wheel well liner.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 03-10-2013, 07:47 AM   #31
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
If you don't want to remove the rear wheels, use Vise-grips to hold a short 5/16" diameter piece of round-bar (or an old 5/16" drill bit of proper length) and heat it with a torch. Use it instead of a drill to make the last hole in the plastic liners, just use a steady hand so as not to contact the tab or hole on the mud guards. Only takes a second to melt through the liner and makes a nice clean hole. Did my entire install with no lift, no jack and no wheel removal. Took longer to remove the original fittings and clean the areas than to install the guards.
Oh, and I did lay a wet towel over the rear of the tires just in case of inadvertent contact. It's close but not bad if you're careful and use a short enough piece of round bar or bit.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
DrDuquette (08-25-2013)
Old 03-10-2013, 09:36 AM   #32
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
I'm thinking of getting a set for my BRZ. I do have some concern about the spring clips. I'm thinking that as the spring clips are pushed in place the paint would be scatched and be a possible rust issue down the road.
Now I realize this is only for the front as the rear is all plastic.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 03-10-2013, 11:52 AM   #33
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
I did my install last week and initially i had the same concern as you. What i did was to drench the clips in WD-40 and spray the painted area with WD-40 as well so when you slide into place it'll be easier. After the clip is in place i spray that whole part again with WD-40.
Also, as long as you clip it lightly it won't scratch off the paint to the base metal. I put the clip on and took it off the first time and touched the area by hand, the painted area was fine.
The Following User Says Thank You to chenshuo For This Useful Post:
Old 03-10-2013, 12:49 PM   #34
BMWDavid
Thank you! Looks like I'll have to order these. Now I just need to find a vendor to order from.
Thanks again for your reply!
2005 Honda XR650L
2006 VW GTI/DSG
Old 05-02-2013, 10:11 AM   #35
dirtbike250x
dirtbike250x's Avatar
Drives: '13 FR-S Ultramarine
Thanks for the write-up I did mine yesterday, and it was the first "mod" to the car.
2013 FR-S Ultramarine
-TRD Catback, UEL Header and Tune, Blitz Drop in Filter, Mishimoto Silicone Intake tube, Mishimoto Oil Cooler, 17x9 w/245/40/17 PSS, RS*R Coilovers custom track alignment, Check out my YouTube for more track videos https://www.youtube.com/channel/UCA9...O1T2Q3xu4m4bYQ
dirtbike250x is offline   Reply With Quote
Old 08-24-2013, 06:04 AM   #36
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Thanks for posting. I went a different route:
  1. Ordered online from a forum sponsor.
  2. Put in trunk of car and drove to dealer for first Scion Boost service.
  3. Mentioned "hey I got these but we never got them installed can you do it when you rotate the tires?"
  4. Drive off later with them installed.
Brilliant! :happy0180:
AG3NT_5CARFAC3 is offline   Reply With Quote
The Following User Says Thank You to AG3NT_5CARFAC3 For This Useful Post:
Dadhawk (08-24-2013)
Old 08-25-2013, 10:22 AM   #37
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Excellent write up. Did mine. I had the concern about paint too. But they actually slip on well without scratching. Where I live nothing seems to rust, but I know other parts of the country and Canada need to worry.. Did anybody put side skirts on with the mud flaps? Thinking that it won't fit together.
DrDuquette is offline   Reply With Quote
Old 08-25-2013, 04:14 PM   #38
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
The OEM mud guard won't be for with any side skirt. If you want side skirt install you need the Rallu Amour mud guard.
The Following User Says Thank You to Lverasky For This Useful Post:
Old 09-01-2013, 06:08 PM   #39
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Weird. Mine came with these stock. Am I missing somethng here?
hmong337 is offline   Reply With Quote
Old 09-05-2013, 08:45 PM   #40
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thank you for the excellent DIY!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-06-2013, 07:07 PM   #41
Suberman
Drives: Subaru BRZ Sport Tech Satin White
All Canadian stock FRS come with "splash guards" installed. The only exception would be if a dealer installs a body kit as that uses the same pre drilled holes.
No BRZ comes with splash guards and Subaru dealers have no part number for them! Now that is weird in Canada given Subaru's tough guy reputation.
Our friendly Canadian Scion dealers will supply a set of Scion splash guards complete with hardware and printed instructions for CDN$62.50 plus tax for you to fit to or have fitted to your BRZ. They have to order them in from Vancouver warehouse because they don't need to stock any!
BTW, you only need to clean the fender and fender liner area to allow for a close and tidy fit. All the body contact areas are plastic so future corrosion cannot be an issue. No need to spray anything onto the car body before you fit the splash guards.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
hmong337 (09-07-2013)
Old 09-06-2013, 07:09 PM   #42
Suberman
The only contact points are plastic to plastic so no corrosion risk at all.
The body kit uses the same holes so, no. Won't fit both but with the body kit you won't need splash guards anyway.
DrDuquette (09-06-2013)
flaps, guard, mud, mudflaps, rally armor
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
Mud Guard Question geb2391 BRZ First-Gen (2012+) -- General Topics 36 03-01-2013 06:37 PM
Opti guard in or near oklahoma? Flako Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 10-22-2012 07:00 PM
Opti Guard ExWhyZer0 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 10-10-2012 03:22 PM
'13 BRZ | Opti-Guard fun! michakaveli Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-02-2012 05:50 PM
