03-10-2017, 05:41 PM | #113 |
Drives: '16 FRS-MT Ablaze Red
Im putting on lcas is it okay to only jack from the rear? I'll support it with two jack stands at the rear jack points and choke the front wheels?
03-10-2017, 11:39 PM | #114 |
Not a troll
07-23-2017, 12:31 PM | #115 |
Drives: car
Car slipped of jack this morning and broke a bracket and bent the radiator. 0/10 would not do again.
07-23-2017, 01:53 PM | #116 |
Drives: Neptune GR86
The jack couldn't support the extra weight of the battery.
The Following User Says Thank You to Andrew025 For This Useful Post: | zc06_kisstherain (07-26-2017) |
07-23-2017, 04:01 PM | #117 |
Drives: car
Shut up douche
07-23-2017, 04:08 PM | #118 |
07-23-2017, 04:25 PM | #119 |
Drives: 2014 Subaru BRZ Limited 6MT SSM
What's are the recommended jacking points on the sides of the car when the front is too low to get a jack on under?
07-23-2017, 04:32 PM | #120 |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
I would just get a 1"thick or more board and drive up on it. Then slide a low profile jack under the front
The Following 2 Users Say Thank You to SuperTom For This Useful Post: | Tcoat (07-23-2017), zc06_kisstherain (07-26-2017) |
07-26-2017, 05:58 PM | #121 |
Drives: SWP BRZ
07-26-2017, 06:55 PM | #122 |
Drives: 2019 Mazda Miata RF
I made myself some ramps. Later I modified them, so I could remove the lower section, to allow the jack to get to the side jack points, or put jack stands under the car.
07-26-2017, 09:37 PM | #123 |
Brilliant!
07-27-2017, 09:40 AM | #124 |
Drives: 2014 Lightning Red Subaru BRZ
Foolishly bent my front jacking point by not using a wooden block. I've found the scissor jack with a proper crank is really fast to get the car up for oil changes or other header/exhaust work.
07-27-2017, 11:59 AM | #125 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Just keep in mind that the sicssor jack the car comes with is intended for emergency use (meaning infrequently, unless you're just the most unlucky guy on the road), not to get the car lifted to accomplish regular maintenance on a regular basis.
-O/D
2016 FR-S, Hot Lava Last edited by Overdrive; 07-27-2017 at 02:58 PM. |
The Following User Says Thank You to Overdrive For This Useful Post: | Tcoat (07-27-2017) |
07-27-2017, 12:32 PM | #126 | |
There are some places you just do not want to have to use a jack for any reason.
Similar Threads | ||||
Jacking up car - using garage jack | NYNOMAD | BRZ First-Gen (2012+) -- General Topics | 2 | 06-27-2012 08:36 AM |
Front jacking point | dsgerbc | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 05-30-2012 05:19 PM |
Supporting Mods | Double4Free | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-21-2012 05:33 PM |
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. | Mitch | Other Vehicles & General Automotive Discussions | 43 | 01-09-2012 08:07 AM |
