07-05-2013, 10:38 AM | #603 |
Drives: VW
Toma and Fenton, thanks for all the work and feedback. Bu-Tang was @ the dyno as well, we were all pretty excited to see the 200 HP line eclipsed @ 6500 rpm. Toma made a safe quick tune to get us going and really pioneered some 'out of the box' thinking. The end goal is to make a simple tune to maximize this application, but it does work on the stock tune with some mindfulness below 3000 rpm (same as a Nitrous system).
To summarize the present results: 168 hp @ 7100 rpm to 205.7 hp @ 6750 rpm +22.4% 131 ft-lbs @ 4800 rpm to 185 ft-lbs @ 4400 rpm + 41.2% Best gains: +65 hp @ 4600 rpm (76%!) and +80 ft-lbs @ 4600 rpm (76%!). All this with ~3.2 kW of power, no physical alterations to car, engine or alternator, $90 worth of SLA batteries for the discharge pack, and a ~20% useable duty cycle. |
07-05-2013, 10:41 AM | #604 |
We have 94 with 0% ethanol in Vancouver. In fact that's all my car has ever seen.
07-05-2013, 10:42 AM | #605 |
Oh yeah and chevron doesn't have 93 in Vancouver. Only 91 with 10% and the 94
07-05-2013, 10:50 AM | #606 |
Drives: 2013 FR-S whiteout
I wish these bad boys could work in this system:
http://www.batteryspace.com/Powerize...B-and-LED.aspx |
07-05-2013, 11:09 AM | #607 | |
Drives: VW
Why? The PCB limits the charge/discharge, going to a 200 amp PCB = more$$$$. I would like to see the discharge graph @ 0 Celsius SLA's $90. for 2. |
07-05-2013, 11:09 AM | #608 | ||
If we have data on how much torque is required to drive the compressor wheel at 50,000rpm then the motor choice could definitely be sized better. This is a good thing because it shows that there is so much potential in this setup in the future. That previous comment was in reference to your proposed charging circuit supplying that much current at 56 volts. Their current methodology of the isolation switch in WOT makes much better sense instead of redoing the charging/protection circuit. Last edited by s2d4; 07-05-2013 at 11:20 AM. |
The Following User Says Thank You to s2d4 For This Useful Post: | Robftss (07-05-2013) |
07-05-2013, 11:17 AM | #609 |
Drives: Raven Black
07-05-2013, 11:32 AM | #610 |
Drives: VW
For the past week Fenton has been driving with the stock tune, being mindful of not going WOT below 3K, it trips a limit in the ECU and CEL comes on. There are previous posts regard this, as well as the stock tune with FTS dyno showing AFR results.
07-05-2013, 11:40 AM | #611 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
Calgary 94 with "upto" 10 percent ethanol is the best we get, our shell 91 however has no ethanol and is actually very good has just not as high but no crickets. I wish we had e85.
Sent from my SGH-I727R using Tapatalk 2 |
07-05-2013, 11:46 AM | #612 | |
Reverse Burnouts
Drives: 2013 Argento FRS
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
07-05-2013, 11:49 AM | #613 |
Reverse Burnouts
its simple problem solving really, you have multiple tanks of similar design under a charge station, they build up power when not charging a vehicle and deliver the power instantly when needed and wouldnt need large demands from the powergrid all the time but a slow charge rate that is sufficient for operation...
07-05-2013, 12:01 PM | #614 |
Drives: FR-S 10 #103 AT
What is the proper way to limit the output of this motor?
I mean the one on the electrocharger, not the engine in the car. We know it can be done because it turns on at low speed whenever there is an unacceptable pressure differential in the intake system.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." Last edited by mid_life_crisis; 07-05-2013 at 04:17 PM. Reason: Took out stupid question. |
07-05-2013, 12:06 PM | #615 | |
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
07-05-2013, 12:44 PM | #616 | |
Drives: Raven Black
ya I think I read something about that - the computer reads that there is over 5psi or something and throws a CEL? |
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
