Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-23-2023, 09:19 PM | #1 |
Drives: 2015 FRS
Rally Build Help
Hey y'all,
Kinda a different side of the capabilities of the FRS. Looking to get some Sparco Terra Rally wheels on my FRS for the rally build. One thing I've read is they won't fit because of the tie rod (15-inch wheels). So my question is how did the Hoonigans do it this weekend at the 100 Acre Woods Rally and how did Dirt Fish do it on their BRZ? They keep mentioning moving the steering in further but do not mention how they do it at all. Dirt Fish Article: https://dirtfish.com/cars/dirtfish-b...wn-subaru-brz/ What I'm quoting is the second paragraph of the Brakes, wheels, and suspension section. Thank y'all for anything and everything! |
03-23-2023, 11:12 PM | #2 |
ProCrastinationConsultant
something tells me it involves a drill, sawzall, and large drill bits...
03-24-2023, 09:57 AM | #3 | |
https://www.ft86club.com/forums/showthread.php?t=105692 Most 15s don't fit because of the tie rod. I've heard the mounting point can be modified but I have not seen it done first hand. Wheel spacers can be used but you might end up with an offset that isn't ideal. I use the Enkei RC-G5 wheel in 15x6.5 with 35mm offset which I had to import from Japan. It is specifically designed for this car and does not require any tie rod modification. If using wheel weights you do have to be careful though because clearance is so tight. So...use a tire shop that can work with you and not be big babies about the whole thing. A 16 inch wheel is much easier, the 15s just open up the world of rally tires (which you should not drive on the street with). Most people are rallycrossing on snow tires anyway...and that's what I have on my 15s for now. But yeah, the 15s are pretty cool looking! - Andrew |
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | bcj (03-25-2023), JD001 (04-05-2023), Jdmjunkie (03-24-2023), soundman98 (03-25-2023), whataboutbob (03-25-2023) |
03-25-2023, 11:23 AM | #4 |
Drives: 2023 GR86
These work too:
https://get-primitive.com/wheels-ral...-brz-gr86.html Dirtfish re-drills the tie rod inboard by about an inch or so. I can confirm this also clears "normal" subaru spec 5x100 rally wheels with this steering kit. It's still tight, but doable. https://us.gktech.com/fr-s-brz-bolt-...man-adjustment |
The Following 3 Users Say Thank You to MConte05 For This Useful Post: |
04-03-2023, 05:37 PM | #5 |
Drives: 2015 FRS
The Following User Says Thank You to banzai-88 For This Useful Post: | soundman98 (04-03-2023) |
04-03-2023, 05:39 PM | #6 | |
Drives: 2015 FRS
04-03-2023, 05:41 PM | #7 | |
Drives: 2015 FRS
04-04-2023, 11:46 AM | #8 | |
https://irs.co.jp/eng/ - Andrew |
04-04-2023, 12:45 PM | #9 | |
Proud of BOXER
Drives: Subaru Boxer
Rishie at AutoRnD (www.autornd.com) may also be able to help. OG Enkei dealer.
04-05-2023, 12:44 AM | #10 | |
Drives: 2023 GR86
I can confirm that standard Subaru 5x100 15” wheels clear the relocated tie rod using the GKTech kit. I’ve made some suggestions to them to increase the clearance further on future iterations they make. I’ve got a couple pallets of 5x100 Subaru speedlines that I’m happy I can put on in a pinch if I need to now. |
The Following 2 Users Say Thank You to MConte05 For This Useful Post: | bcj (04-05-2023), Racecomp Engineering (04-05-2023) |
04-05-2023, 06:03 PM | #11 | |
Drives: 2015 FRS
04-06-2023, 08:15 PM | #12 | |
Drives: 2023 GR86
Just know that the clearance is still verryyyyyyyyyy tight with the subaru 15" wheels, but for rally on a RWD car it should be okay. If they do redesign the bracket to bring some meat more inboard it should gain another 4-5mm of clearance. |
04-06-2023, 11:45 PM | #13 |
Drives: 2015 FRS
I gotchu, I think that's the route we are going to go for now, and if it doesn't work then I'll just drill out another hole for the tierod +/- an inch inward, I'll try and post some more photos for everyone since there are quite a few people asking about 15's
Tags |
lift, rally, small wheel, tie rod |
Similar Threads | ||||
Rally GT86 - The Little Car That Could - Lots of rally video and photos! | Circuit Motorsports | Tracking / Autocross / HPDE / Drifting | 48 | 10-12-2020 03:32 PM |
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
#GravelMachineGun - BRZ Stage Rally Build | Jkosmo | Member's Car Journals | 13 | 08-28-2019 07:49 AM |
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
Street/Rally Build | z3ro | Member's Car Journals | 3 | 06-07-2014 06:21 AM |
