Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
04-21-2019, 03:35 AM | #1 |
Drives: BRZ limited
Should I consider battery corrosion protection on the brand new car?
Hi guys,
Is it a good idea to use battery terminal protectors (ie NOCO https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER) and corrosion spray (ie NOCO https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER for a brand new car and battery? Thanks |
04-21-2019, 03:50 AM | #2 |
[insert cool phrase here]
Drives: BRZ Premium
Those felt rings are more than enough in all honesty.
Even if you do get a bit of corrosion on the terminals a little bit of water, baking soda, and a brush can clean that up in no time. Then again.... a bit of battery corrosion is the lest of your problems. Also FYI $9 for those rings? Lol don't be a chump. Those are $3 max at any auto parts store.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
04-21-2019, 04:42 AM | #3 |
Drives: BRZ 2018
Marine waterproof grease may be?
04-21-2019, 09:50 AM | #4 |
Rust bucket enthusiast
I worked for AAA and got tingly when I saw the signature red spray on terminals. It meant I wasn't about to replace their hardware and could do my job effectively.
Please just spray them if you will never check your battery. I'm in Vermont and had plenty of MA cars that were corroded with the connection hardware itself rusting apart. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | Busybee (04-21-2019) |
04-21-2019, 10:07 AM | #5 |
Drives: 2017 BRZ w/PP
why would you spend 30$ on stuff when 30 seconds with a wire brush fixes it? Plus the oem batter will shit the bed before that 30$ is worth it
04-21-2019, 11:40 AM | #6 |
The real issue is the connection hardware rusting. When it does, you can't just unbolt the connectors and put them back on. You have to cut the connection ends off and add new hardware, since you can't re-tighten the bolts to get a snug fit onto the terminal
04-21-2019, 05:01 PM | #7 |
ProCrastinationConsultant
this is what i install on all my cars. it's an all-in-one kit that includes the felt rings, and then a small squeeze thing of dielectric grease that i coat the terminals with. it's worked well so far
https://shop.advanceautoparts.com/p/...inal+protector way better than opening up the hood on a bad day and finding a furry friend eating my battery!
The Following User Says Thank You to soundman98 For This Useful Post: | Busybee (04-21-2019) |
04-22-2019, 06:40 PM | #8 |
Or you could just keep your engine compartment and battery clean!
04-26-2019, 10:59 PM | #9 |
Drives: BRZ limited
I know this will be a very basic question. Is there anything that I have to be careful about taking out the battery wire when I put the protective pads? I mean Is there a possibility that It can I can get an alert on my screen ? Is it just fine to release the cables put the pads, spray the the protectant and assemble back.
Thanks Sent from my iPhone using Tapatalk |
04-26-2019, 11:53 PM | #10 | |
Drives: BRZ Premium
Also do not attempt to do this with your bear hand. Use protective gloves (oven mitts ok) head gear with full face guards, thick rubber apron, a grounding wire and protective foot wear. Also let your neighbors know your attempting to battery work. And for shits and giggles call the fire department just so they can be on stand by. I'm sure @humfrz would agree
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged Last edited by Mr.ac; 04-27-2019 at 01:25 AM. |
04-27-2019, 12:03 AM | #11 |
Drives: BRZ limited
04-27-2019, 12:36 AM | #12 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Just get the spray and give the terminals a spray once in a while. No need to take anything apart.
The Following User Says Thank You to Sapphireho For This Useful Post: | Busybee (04-27-2019) |
04-27-2019, 01:24 AM | #13 |
Drives: BRZ Premium
How dare you give him a logical simple answer.
The Following User Says Thank You to Mr.ac For This Useful Post: | DarkPira7e (04-27-2019) |
04-27-2019, 01:27 AM | #14 |
¯\_(ツ)_/¯
The Following User Says Thank You to Sapphireho For This Useful Post: | DarkPira7e (04-27-2019) |
Similar Threads | ||||
Anti-Corrosion (ACF-50 vs Corrosion Block) | nico_rsx | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 12-02-2017 02:57 PM |
Master Battery Cutoff Kill Switch Safety Alternator Protection Racing Shutoff | hirollaz | Engine, Exhaust, Bolt-Ons | 1 | 09-05-2017 01:47 PM |
STI Battery Tie Down - Brand new | wrb | Interior Parts (Incl. Lighting) | 4 | 06-03-2014 04:42 PM |
BLACK PERRIN PULLEY AND LIMITED GRIMMSPEED BATTERY TIE DOWN BRAND NEW IN BOX | genometuning | Engine, Exhaust, Bolt-Ons | 0 | 09-26-2013 09:49 PM |
FS: Brand New Braille B2015 Battery | kanundrum | Mechanical Maintenance and Tools | 7 | 01-20-2013 01:35 AM |
