Old 08-08-2014, 06:06 PM   #57
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
To support the discussion, I had this issue (ABS and traction indicators on) today.
The drive was 15 mins of highway, then 30 mins of stop-and-go traffic. My lights came on halfway through the stop-and-go traffic.
My 86 has no powertrain or brake mods. Wheels and tires only.
I'll check the brake switch, since that was probably running at 90% duty cycle during the stop-and-go. Much easier to fix than a wheel speed sensor.
Thanks for the detective work, guys/girls.
Edit: Aaaaaand it's gone. No clue, but I'll update if/when it comes back.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 08-11-2014, 04:47 AM   #58
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by #87 View Post
No, if there is an issue the lights are on in the dash because the ECU turns them off...... Because it does that...
Sorry, I couldn't help it . . . .
ZZT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ZZT86 For This Useful Post:
GabeoHuncho (03-04-2022), pushrod (11-03-2014)
Old 08-15-2014, 12:14 AM   #59
Toyota GT 86
Toyota GT 86's Avatar
Drives: Toyota GT 86
How did u fix it? Is there any solution ? I have TOMS tailights almost 1 year and necer had this problem until now, i dont now what to do.
Toyota GT 86 is offline   Reply With Quote
Old 08-15-2014, 01:02 PM   #60
Shankenstein
Frosty Carrot
I went out to the car after typing that message... jiggled the brake pedal, and watched to see if the brake lights were coming on (they did)... drove around the block and the lights haven't come on since.
My guess is that it went into a "protect" mode. It could be any number of things: brake fluid got hot, stray air bubble, gunk on the wheel speed sensor, brake pedal sensor stuck, or something shorted out momentarily.
I'm writing it off as gremlins for now, but I'm not happy with that explanation for the long-term.
Old 09-17-2014, 05:58 PM   #61
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
Had my ABS and Trac light come on today. Picked the car up from the body shop, I have a modded rear fog light and clear Tom's USDM as well. I'm thinking something wasn't done properly when they put the rear bumper back on. Can someone tell me if this brake switch fuse is a separate fuse that is not located in the fuse box underneath the steering column. I checked all those and they are fine.
Bg8780 is offline   Reply With Quote
Old 11-03-2014, 09:10 PM   #62
kylethomas23
kylethomas23's Avatar
Drives: 2014 brz
Same lights came on my car. Only come on after the car starts moving slowly. I also have aftermarket tails and bumper light. I have an appointment with the dealer tomorrow morning and will update with the outcome!
kylethomas23 is offline   Reply With Quote
Old 03-23-2015, 09:40 PM   #63
brad ram
Drives: GT86
I had the same issue last week I replaced my lower control arm since it was warped and got a alignment done and both lights turned off and car is back to running great.
brad ram is offline   Reply With Quote
Old 05-30-2015, 08:36 PM   #64
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I just had this happen this afternoon, after several hard stoppings (bedding in brake pads), I noticed the light come on going down the freeway just out of the blue. Recent mods, Valenti Tails, BB kits, Coilovers just done a few days ago. Will be investigating further and will have Dealership check it out since it has to go in anyway.
F1fletch is offline   Reply With Quote
Old 06-05-2015, 10:17 PM   #65
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Update: Toyota tech adjusted brake switch and cleared code (related to Brake switch ). So far so good.....if it occurs again I am sure we will have to replace switch. Since I am starting at Livermore Toyota Monday it should not be too much hassle to get this addressed.
The Following User Says Thank You to F1fletch For This Useful Post:
Teseo (02-17-2024)
Old 07-08-2015, 10:41 PM   #66
phoenixrage
just had this issue on my drive home on the highway, ABS & traction lights came on, but also, my 3rd brake light was constantly on (lights thinking my brake is on.)
I got home, and restarted the car after checking my wiring for the 4th brake light mod (nsidius kit) and that seemed ok, so I restarted the car, and the problem cleared itself out.
Since I work at a car dealer, (non subaru/toyota), i'll plug in the scanner to see if there's any issues and check the brake pedal as well.
phoenixrage is offline   Reply With Quote
Old 08-10-2015, 03:30 PM   #67
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
This ABS Traction Control problem just came up with my vehicle when I had the dealer replace my steering wheel under warranty. Happened immediately when they fired it up after the wheel replacement. They couldn't figure out what happened. Ordered some sensor - so I'll have to go back in a week and have them install that part!
I'll have to check the fuses and the brake light controller to see if that is where the problem is.
You'd think that a steering wheel replacement would be straight forward!
czechm8 is offline   Reply With Quote
Old 08-10-2015, 03:48 PM   #68
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Your problem has nothing to do with the the brake sensor. The tech who replaced your steering wheel is an idiot and damaged your clock spring. You can read a lot about it via the aftermarket steering wheel diy.
Old 08-10-2015, 09:52 PM   #69
czechm8
520
czechm8's Avatar
Makes sense. They are on the hook for it so I'll stay after them.
Sent from my Nexus 9 using Tapatalk
Old 08-10-2015, 11:39 PM   #70
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Mind me asking why they replaced it?
Maybe tell them ? Hahah you have to put your tires perfectly straight and leave the clock spring in the exact same position and remove it very carefully.
Traction/VSC Setting Preference ashtray BRZ First-Gen (2012+) -- General Topics 27 08-24-2018 03:39 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) -- General Topics 40 04-25-2012 11:20 AM
