Old 12-18-2018, 07:11 PM   #29
Mr_Eyo
Drives: 2017 Toyota 86
Originally Posted by Mr_Eyo View Post
Thanks for the comments. I Just checked my defs in RomRaider and found I had the wrong one at the top (ZA1JN10D, my car is ZA1JK00D and it was the next one down). I think these logging quirks started around the same time I downloaded that def. Could writing a tune with the following year's def cause this? AFAIK, the logger would be using the ZA1JK00D defs, right?
I'm not sure I'm understanding your linked forum post, so let me see if I have it right. If the correct cal ID doesn't fix this, you're saying I can set the limits for my AF #3 sensor to 0/0, even if my RomRaider def puts it in a different group ("ALPHA AF 3 (Rear O2 Sensor)", not "Fueling - AF Correction/Learning") from what was shown in your screen cap?
Correcting the Cal ID def didn't fix it. Now flashing a tune with the rear O2 corrections disabled.
Mr_Eyo is offline   Reply With Quote
Old 12-18-2018, 07:16 PM   #30
steve99
Drives: FT86
Grab the latest OFT V4 tunes for K00D that should sort your logging issue they will be based on K01I
correcting def calid wont help
you need the K01I based V4 tunes
https://support.openflashtablet.com/...7-us-6at-v4-03
the earlier V4 2017 plus tunes has logging issues
Old 12-18-2018, 07:41 PM   #31
Mr_Eyo
Zeroing the AF 3 sensor corrections didn't fix it either.
Old 12-18-2018, 07:42 PM   #32
Mr_Eyo
I got my OFT in September. Nothing new has been released for my Cal ID since July.
Old 12-18-2018, 08:17 PM   #33
steve99
Drives: FT86
check your K00D tune with hex editor
8000 ZA1JK00D
10000 ZA1JK00D
about 11000 ZA1JK01I
if its V4.03
Old 12-18-2018, 09:22 PM   #34
Mr_Eyo
8000 ZA1JK00D
10000 ZA1JK00D
if its V4.03
Found these:
ZA1JK00D @ 0x8000 & 0x100000
ZA1JK01I @ 0x11FE51
I'll re-download the latest files and see if they're different.
Old 12-18-2018, 09:28 PM   #35
Mr_Eyo
Found these:
ZA1JK01I @ 0x11FE51
Just did the same check on the latest files I just downloaded and got the same results.
Dash Command App and Oil Temp on iPhone and iPad nzer Scion FR-S / Toyota 86 GT86 General Forum 38 03-19-2017 12:33 PM
Dash command for BOOST Flat_4_Life Forced Induction 5 01-18-2016 12:13 PM
idle afr is 14.05? command and actual...what gives? Lytheum Issues | Warranty | Recalls / TSB 1 06-24-2013 01:21 PM
Voice or GUI command to pause guidance? Sovran Electronics | Audio | NAV | Infotainment 0 09-25-2012 02:21 PM
handsfree voice command help lbroskee Electronics | Audio | NAV | Infotainment 5 09-13-2012 04:51 PM
