06-20-2015, 03:08 AM | #29 |
Drives: 2013 Asphalt FRS
Oh no I won't get rid of DI!!!! It just wasn't installed yet
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
06-22-2015, 04:22 AM | #30 |
started the engine and trans swap
started the engine and clutch swap
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 07-05-2015 at 04:50 AM. |
06-22-2015, 11:11 AM | #31 | |
Yes the pump gears are WPC treated so are the rings, bearings, crank, and pistons. WPC is not a coating it's a surface treatment that reduces friction. Kind of like a glass beading check out the you tube [ame="https://www.youtube.com/watch?v=jSiC7D8patU"]WPC Metal Surface Treatment Demo #1 of 2 - YouTube[/ame] [ame="https://www.youtube.com/watch?v=VvKH-BYQcoM"]WPC Metal Surface Treatment Demo #2 of 2 - YouTube[/ame] The cams are stock in this one I want to see how much we can push out of this configuration.
The Following 4 Users Say Thank You to FRS Justin For This Useful Post: |
06-22-2015, 05:34 PM | #32 |
Vacuum manifold
Look what Spencer Fabrication built just for us, the most AWESOME vacuum block!!!!!
06-24-2015, 11:06 AM | #33 |
Drives: 2013 RB Turbo FRS, 2013 N/A FRS
Nice! Build!
Subscribed! |
The Following 3 Users Say Thank You to Fiebruz Motorsports For This Useful Post: |
07-03-2015, 03:02 PM | #34 | |
Yes stock cams and yes the pump gears are treated with WPC
07-04-2015, 10:19 AM | #35 |
Drives: 400whp Scion tC
What trans did you swap in?
07-04-2015, 10:37 AM | #36 |
Panda Trueno
Drives: No twin now.
Wow, now THIS is a build thread!
The Following 3 Users Say Thank You to Summerwolf For This Useful Post: |
07-05-2015, 04:45 AM | #37 |
Its the factory trans looking at other options undecided at this time
The Following User Says Thank You to FRS Justin For This Useful Post: | SnapOv3st3r (07-27-2015) |
07-28-2015, 10:07 PM | #38 |
Drives: 2013 SCION FR-S FIRESTORM RED
i need more lol
07-29-2015, 05:00 AM | #39 |
Drives: Toyota GT86
Very nice build mate! definitely keeping track of this build and taking notes on how you built your motor.
subscribed!
07-29-2015, 06:55 AM | #40 |
Looking forward to seeing updates! Love the build
08-05-2015, 11:55 AM | #42 |
Drives: 2013 fr-s firestorm red
Yep, I'm Jealous... Just sayin... Great build so far! Hope to see more progress soon! Oh, if you go into the stock transmission and brace up the gear rail bosses around the bearing plates the transmission should hold significantly more power. This is how we made our Getrag 6spd Transmissions in the 3000GT VR4's hold 900+ horse power. Kept the gears from separating the transmission halves... Found this out after I destroyed my first transmission on a hard launch at 28lbs on twin 19t turbos... $400 worth of bracing the internals would have saved me a $5800 transmission... SMH!
