Old 06-18-2015, 01:07 AM   #15
D_Thissen
D_Thissen's Avatar
Subbed
Old 06-18-2015, 10:47 AM   #16
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by FRS Justin View Post
This is where you have to be careful!!!!!! Their is a major valve train change in FA20s from2013.5 and up!!!!!!! Below 2013.5 the FA20 has 2 different size rocker arms and valves. The valves are 100 thousandths longer on the right side than the left. NO ONE MAKES VALVES FOR THEM AT THIS TIME ITS A CUSTOM ORDER TO GET THEM TRUST ME I FOUND OUT THE HARD WAY AND HAD TOO WAIT A MONTH!!!!! They will be available soon thru Super Tech.. Just be careful when setting up your heads double check triple check if you have too...
Now this is worth knowing...thank you!
The Following User Says Thank You to Lonewolf For This Useful Post:
FRS Justin (06-18-2015)
Old 06-18-2015, 11:05 AM   #17
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
In for updates. Looks great!
DustinS is offline   Reply With Quote
The Following User Says Thank You to DustinS For This Useful Post:
Old 06-19-2015, 01:15 AM   #18
FRS Justin
Drives: 2013 Asphalt FRS
UPDATE!!!! SuperTech is now producing the valves they are available...... Check out their website and you can see the specs.
FRS Justin is offline   Reply With Quote
Old 06-19-2015, 01:21 AM   #19
FRS Justin
some more pics
enjoy
The Following 3 Users Say Thank You to FRS Justin For This Useful Post:
DAEMANO (08-08-2015), DustinS (06-19-2015), M1K3 (06-19-2015)
Old 06-19-2015, 10:53 AM   #20
FRS Justin
precision machine work and perfecting specs BY OUTFRONT MOTORSPORTS
Outfront Motorsports checking specs for perfection no settling or guess work is one of the reasons I could sleep well at night knowing its going to be alright.... lol
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
DAEMANO (08-08-2015), Kris86 (03-15-2016)
Old 06-19-2015, 11:03 AM   #21
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Did you get the oil pump gears coated with something from WPC?
Are you using stock cams?
NotSoJDM is offline   Reply With Quote
Old 06-19-2015, 11:16 AM   #22
FRS Justin
Sorry for dragging this out I have to resize every pic
IBill4You (07-05-2015), Kris86 (03-15-2016)
Old 06-19-2015, 11:25 AM   #23
FRS Justin
And basically this completes the build of the engine. I'm working on out sourcing a turbo kit and will start the Radium fuel system install next pics to come it's a pretty wild install lol
I will try to put the pics in some type order next time... Peace
DAEMANO (08-08-2015), raven1231 (06-22-2015)
Old 06-19-2015, 02:43 PM   #24
aagun
Drives: 86
Everyone knows you have to have a good piston to make power without having a huge meltdown.. For me it was JE pistons I've used them for years and they never let me down. Also as you can see they were WPC treated for friction and heat.
And if you decide to go big power get the heavy duty wrist pins so you don't crack a piston at high boost...
what cp has it ?
aagun is offline   Reply With Quote
Old 06-19-2015, 04:00 PM   #25
FRS Justin
Originally Posted by aagun View Post
what cp has it ?
10.5:1
Old 06-19-2015, 04:18 PM   #26
FRS Justin
This should hold
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (03-15-2016)
Old 06-19-2015, 07:29 PM   #27
Cop
Cop's Avatar
Drives: 2013 FRS
this is intense
Cop is offline   Reply With Quote
The Following User Says Thank You to Cop For This Useful Post:
FRS Justin (06-20-2015)
Old 06-19-2015, 08:14 PM   #28
aagun
Drives: 86
what about DI system its look like deleted
