Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-16-2018, 10:41 AM | #43 | |
I really don't look forward to rebuilding all these seals though. They are everywhere. Both pans, the timing cover and the valve covers. Not even sure how many tubes of 3bond I'm going to need. It also wants 3mm width here and 4mm width there but only 2.5 here. I'm going to need a bunch of tips cut to various sizes to build these seal to spec. I am curious, when you tore yours down, what rod was snapped? How did the other bearings look? Did you find any blockage anywhere? I saw in another thread that you changed your oil before and after a track day so I know your oil level was good. Any idea what your oil temps were when you threw the rod? Do you have a pressure gauge, if so, what was your pressure looking like around the time it threw? |
The Following User Says Thank You to ermax For This Useful Post: | Tcoat (05-16-2018) |
05-16-2018, 11:17 AM | #44 | |
BoostedBRZ
Drives: Turbo BRZ
05-16-2018, 11:49 AM | #45 | |
At some point I plan to connect the RPi to the reverse camera input on the head unit. Then I can rewire the reverse wire to my RPi so I can trigger the input to switch to the RPi whenever there is something urgent to display. Until then I will just strobe the oil dummy light when the oil pressure isn't right. |
05-16-2018, 11:54 AM | #46 | |
BoostedBRZ
Drives: Turbo BRZ
05-16-2018, 12:04 PM | #47 | |
In the future I want to use it for data logging and then automatically sync the data when I get to the office or my house so I don't have to move an SD card back and forth (Tactrix). |
05-16-2018, 12:42 PM | #48 |
Drives: 2013 FR-S, 2016 Miata Club
Interesting reading here. I’m in the process of rebuilding a motor I blew a few years ago. I have a new short block that I’m gonna toss some Manley rods in. Found a used head to replace my damaged one. Got some Kelford valve springs to toss in them. It was turbo’d when it blew. I was thinking I floated the valves on my 06/2012 motor. After reading this though I’m gonna check out the bearings in the damaged block. See if any of them spun and what kind of wear they had. Something I’ve been curious about. Just haven’t taken the time to inspect. I’ll post up my findings.
05-16-2018, 02:11 PM | #49 | |
Only users lose drugs.
Drives: All the time
That picture right there is what gives me the heebies about my own 50K mile 2013...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
05-18-2018, 10:18 AM | #50 |
Drives: gt-86
I spun a bearing in a 2013 only 120k km. Car had been tracked but modern engines should not be spinning bearings. It is an automatic NA and I have broken two factory flywheels. Once with the old engine and now with the repalcement?
The Following User Says Thank You to Totality For This Useful Post: | EddieZ2 (07-12-2018) |
07-12-2018, 08:35 AM | #51 |
Drives: 2013 FRS
You have a good point in people listing oil related problems. If the FRS/86 is killing bearings in numerous cases on stock and modded this is something that seriously needs to be addressed and not with Toyota just fixing it when it happens. From what I’m reading in various posts and forums, it appears as though the FA20 engine has a major flaw. Either port clogging, oil too thin because it runs too hot or whatever. An engine especially stock shouldn’t be crapping out after a few spirited jaunts. I’m thinking a major recall or buyback for the obvious issue. Granted it is a sports car but it should be built to at least be reliable beyond 100k especially if stock. Just my thoughts on it.
07-12-2018, 07:45 PM | #52 |
Drives: 2013 Asphalt FRS
Get online find a complete motor to drop in it. Build the blown motor as money permits.
Pm me I have a few motors laying around stock to built
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
10-07-2020, 01:49 AM | #53 |
Drives: GT86
FI?
10-07-2020, 05:58 AM | #54 |
Forced Induction. Like a supercharger or turbo.
10-08-2020, 10:14 PM | #55 |
Drives: GT86
10-10-2020, 09:57 AM | #56 |
Drives: 2017 Toyota 86
The Following 2 Users Say Thank You to pallen For This Useful Post: | MuseChaser (10-10-2020), Ultramaroon (10-11-2020) |
Tags |
engine, forged, frs, rebuild |
Similar Threads | ||||
Spun Bearings and now more Issues | Jay161 | Issues | Warranty | Recalls / TSB | 45 | 02-27-2019 11:08 AM |
Charging advice required | s2kbobby | Engine, Exhaust, Transmission | 35 | 10-24-2016 11:59 AM |
Spun out and hit a curb... | JohnAyySays | Issues | Warranty | Recalls / TSB | 54 | 12-09-2013 10:59 AM |
****ADvice REquired: Built/vs/Stock*** | killerkid08 | Forced Induction | 54 | 06-09-2013 04:57 PM |
Spun out now a CEL | Noob4Life | Issues | Warranty | Recalls / TSB | 10 | 03-30-2013 11:02 PM |
