Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > FT86CLUB Shared Forum > Member's Car Journals
Old 07-24-2019, 10:04 AM   #15
ShibusaTouge
ShibusaTouge's Avatar
Drives: 2014 K24 swapped FRS
New video is up! Goes over why I chose the k24!
https://youtu.be/Ffxa3onVJ0E
ShibusaTouge is offline   Reply With Quote
The Following User Says Thank You to ShibusaTouge For This Useful Post:
MrSkubi (07-25-2019)
Old 07-28-2019, 08:59 PM   #16
ShibusaTouge
https://youtu.be/LbEjWLas_OU
Engine work has begun!
Old 08-10-2019, 07:47 PM   #17
ShibusaTouge
Another issue:
Power steering won't wire up to the kseriesparts harness, and when I've attempted to take the steering rack motor off, it's sealed on a bearing and won't move.
I'm going to make the rack manual and swap in a manual rack and adapt it to the u-joint towards the firewall
Old 08-12-2019, 04:54 PM   #18
ShibusaTouge
We got the engine apart!!!
https://youtu.be/vvr_0-s_I0k
Old 08-13-2019, 02:15 AM   #19
Zer0
Drives: 2015 frs
The rack in the car is already a manual rack. The power steering motor can just be removed from the equation.
Zer0 is offline   Reply With Quote
Old 08-13-2019, 09:29 AM   #20
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
It's been posted by people have raced/driven without the P/S that the manual rack is not setup to be driven manually and is too difficult to steer with.
The Following User Says Thank You to DustinS For This Useful Post:
ermax (08-14-2019)
Old 08-13-2019, 06:26 PM   #21
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
subscribed.
also what wheel and specs on this pic?
DuMa is offline   Reply With Quote
Old 08-14-2019, 04:54 AM   #22
Zer0
Drives: 2015 frs
Yeah the effort required would be a definite workout. It may be able to be used with a gear device like a quick steer coupler reversed to make more turns lock to lock. It would lighten effort needed at the wheel. Just a thought.
Old 08-14-2019, 06:52 AM   #23
ermax
ermax's Avatar
Drives: 2013 FR-S 6MT Raven
Yeah I ran with the fuse out once just to see how it was and it is incredibly difficult to drive. I driven plenty of PS cars with belts removed and they are fine once rolling but not the Twins. The ratio is way to high to go without PS.
Old 08-14-2019, 06:56 AM   #24
ermax
ermax's Avatar
K24, let's do this. TheVTEC86
Originally Posted by ShibusaTouge View Post
Another issue:
The motor is really easy to remove. My EPS coupler DIY explains how to remove the column which lets you drop/rotate the motor down so you can access the two bolts that hold it on.
http://www.ft86club.com/forums/showthread.php?t=133606
It will be impossible to drive without EPS though.
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
