Old 08-25-2016, 05:35 PM   #43
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Don't want to beat a dead horse but there is a lot of back and forth between threads.
Do the OEM washers, that come with car, for transmission and differential fluid need to be replaced? In other words, are they flat or crush?
From what I am reading they are flat so no they don't. But a lot of people seem to be buying them?
l0aded is offline   Reply With Quote
Old 09-14-2017, 08:47 AM   #44
maicolp
Drives: toyota gt86 1st edition
crush
maicolp is offline   Reply With Quote
Old 09-14-2017, 08:48 AM   #45
maicolp
and manual advide for changing them. but if you are in a hurry you can flip them (just one time)
Old 09-14-2017, 12:22 PM   #46
qqzj
Drives: MDX, Camry
transmission washers do not need to be replaced. differential washers do. they seem to be of one-time use to me.
qqzj is offline   Reply With Quote
Old 10-20-2017, 05:27 PM   #47
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
my subaru dealer is too far, ya'll think I can order these at the toyota dealer? lol
nova.86 is offline   Reply With Quote
Old 10-20-2017, 05:41 PM   #48
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
I think I got my last pair from Toyota on Amazon. Or if you want to upgrade to magnetic drain plugs from ft86speedfactory, they'll come with washers. But to answer your question, I'm sure a Toyota dealer would have them or have them ordered for you.
Beachin86 is offline   Reply With Quote
Old 10-23-2017, 02:45 AM   #49
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Yes. There are equivalent part numbers for each Brand.
Subaru
1215710010 Diff Drain Gasket
11126JB000 Diff Fill Gasket
17008AA050 Transmission Gaksets
803916010 Oil Drain Gasket
Toyota
TOY1215710010 Diff Drain Gasket
SU00300122 Diff Fill Gasket
SU00303626 Transmission Gaksets
SU00302159 Oil Drain Gasket
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
Bonburner (10-18-2018), RL_BRZ (08-08-2018)
Old 06-05-2018, 02:38 PM   #50
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by yomny View Post
The sizes are posted in the first couple of posts in this thread, some guy was cool enough to enlightened us..
Differential fill plug gasket: 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: - 24mm OD x 18mm IDx 2mm Crush
Transmission fill/drain plug gasket: - 24mm OD x 18mm ID x 2mm Flat
This is my order from belmtric.com which are the same dimensions and fit perfectly. I ordered extras. LEt me know if you need more help.
Here's the page
4 ea. GCA18X24 - Copper hollow crush gasket $2.88
4 ea. GA18X24T - Aluminum Gasket THICK $1.52
I know this thread is super old, but thanks for this post! I hadn't heard of Belmetric before, so I feel like I've been living under a rock. It's pretty awesome that they let you order any quantity of essentially any part, and shipping is only $7.99. Most online small parts stores either have huge quantity minimums or expensive shipping.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 07-25-2018, 03:50 PM   #51
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Originally Posted by developer View Post
So I just received my overpriced gaskets/washer for the transmission and the differential:
Differential fill plug gasket: SU00300122 - 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: TOY1215710010 - 24mm OD x 18mm IDx 2mm Crush
Transmission fill/drain plug gasket: SU00303626 - 24mm OD x 18mm ID x 2mm Flat
They all look to be aluminum but that is just a guess. All measurements were made with calipers.
Edit: The crush washers stuck to the magnet on the drain plug so I guess they are not aluminum
Left Image is the diff drain/fill gaskets and they look identical. They are the exact same outer/inner diameter and thickness. They are both crush type washer.
The right image is the transmission fill/drain plug gasket is the same size as the differential gasket but is a flat washer.
After I pull the transmission gasket I will compare the thickness of the used and the new gasket to see if the transmission flat washer did actually "crush".
Edit: The original flat washer was within a 1000th of an inch of the new flat washer so I would guess they are not meant to crush.
When I order the differential crush washers again I will just order two of the same part number instead of two different parts.
Check out this website
https://parts.westcoasttoyotalb.com/...u00300122.html
scion fr-s is offline   Reply With Quote
Old 10-17-2018, 04:25 PM   #52
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Here in the Toronto area we may as well just spend the money at the stealership. I visited at least 10 auto parts stores and found no metal "crush" washer/gaskets anywhere. Did get some 18mm fibre crush washers at PartSource in Markham eventually.
Edit: Broke down and visited Dixie Toyota in Mississauga today. Picked up two 18mm crush washers for CA$2.20 each. I should have called them first and saved much chasing around to parts stores.
Muskoka800 is offline   Reply With Quote
Old 08-23-2021, 02:37 PM   #53
daniloneil8
Drives: FRS
Dumb question, but does the MT6 gearbox use the same crush washer as the AT ?
17008AA050
daniloneil8 is offline   Reply With Quote
Old 08-23-2021, 03:10 PM   #54
daniloneil8
Drives: FRS
Here's the page
What year car?
It seems sizes and part numbers changed in 2017.
I need 2013 MT fill and drain plug washer
Old 08-23-2021, 04:30 PM   #55
daniloneil8
Drives: FRS
Got the size for the motor oil drain plug crush washer
Manufactured in Japan | Specification: 16.10mm Inside Diameter X 20.52mm Outside Diameter X 2.23mm Thick
OIL PAN
GCA16X21A - Hollow Aluminum Crush Gasket
https://www.belmetric.com/hollow-cru...et-p-8397.html
TRANNY
GA18X24X2.0 - Aluminum Gasket THICK
https://www.belmetric.com/aluminum-g...ck-p-3051.html
DIFF
https://www.belmetric.com/hollow-cru...et-p-6154.html
The Following 2 Users Say Thank You to daniloneil8 For This Useful Post:
nomtimesthree (03-23-2024), radroach (08-24-2021)
Old 08-30-2021, 02:21 AM   #56
jflogerzi
jflogerzi's Avatar
Originally Posted by daniloneil8 View Post
What year car?
I can confirm this what I use on my 2013. Order extra's so its 1 order and your done for a while.
2013 Series 10 FRS #553
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
Pressure Washer $60 at super store Aznek CANADA 6 09-10-2012 11:08 AM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 02:06 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 03:31 PM
