01-04-2013, 08:21 PM | #505 |
Drives: 2013 BRZ Limited
Both of my lights arrived at the dealership after 1 week. They are waiting on some sort of gaskets however. They seem to think that this is the source of the problem.
01-04-2013, 09:12 PM | #506 |
01-05-2013, 12:20 AM | #507 |
Drives: '13 DGM BRZ Limited
Just got the call Friday morning that both lights came in. Going tomorrow morning to get them swapped out.
01-05-2013, 01:13 AM | #508 |
Potato Farmer
Drives: #SLOBRZ
My back left one is looking a bit like a fish tank..
or a sauna.. or my balls in yesterdays 41deg Celsius (105.8F) heat :\
Something something butter..
www.vic86brzclub.com |
01-07-2013, 11:40 AM | #509 |
Drives: 2023 Toyota GR86 Premium
My FR-S has the condensation problems. I wanted a different set of tails anyway, so I order the Colin tails from japanparts. After installing them, even these aftermarket ones are having condensation issues. After further inspection, there really isn't a good enough seal between the taillight and the body panels. In fact, you can pretty much see daylight through the gap. Stock (from the factory, before ever touching it) and aftermarket, this persists as an issue. I might just dry them out, seal them up the best I can myself, and try to make some kind of a rubber seal myself.
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
01-07-2013, 11:45 AM | #510 |
I think this is the issue at the source. Even with aftermarket tails, they don't form a good enough seal to the body panels, even when tightened in the correct order and to torque specs. Keeping the water out of the trunk, and maybe covering the open side of the taillight (where the wires come out) with tape may actually cut down on the moisture and condensation issues.
01-07-2013, 11:58 AM | #511 | |
01-07-2013, 11:58 AM | #512 |
this is a great idea, and may be what needs to be done, have we been able to identify the location of water ingress? is slicone or grease an option at those points? I have a set on order...
01-07-2013, 12:41 PM | #513 | |
I'm going to reinstall the stock housings (now that they're nice and dried out) and see if there is the same gap. If so, it's a stupid design to allow water into the trunk, behind the interior panel. I'm definitely going to tape up the housings either way.
01-07-2013, 12:51 PM | #514 |
tape itself presents a host of other water harboring concerns tho...
prepsol and windsheild sealant is my friend tho |
01-07-2013, 12:54 PM | #515 |
Agreed, just for a test. I'd want to use a better sealing method for a "final fix." If the tail light housings have condensation or not, I'm still concerned with the water coming into the trunk.
01-07-2013, 01:15 PM | #516 |
what about that sticky stuff thats used inside doors for that vapor barrier? sticky silly putty looking shit? sometimes its yellow...easy to remove and its waterphobic/waterproof
01-07-2013, 01:37 PM | #517 |
Drives: 2013 HotLava FRS, 2005 Legacy
My right one used to have the condensation fairly often, now it does not and my left one does it once in a while. ><
HotLava FRS MT |
01-07-2013, 03:14 PM | #518 |
Over lunch hour I took the Colin tail lights out and noticed the gaskets from the stockers didn't stay put, which is more than likely why I had water in my trunk and condensation in the aftermarket tail lights. I reapplied them, but not before tracing some templates so I can make my own out of a better (and slightly thicker) silicone or neoprene foam. The stock gaskets are about $11 each, but I venture to say that even new, fresh stock ones would suck.
Similar Threads | ||||
Red tail light photoshops | OwenK | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 68 | 02-06-2013 03:48 PM |
HKS head and tail lamps | DIG1992 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 05-19-2012 01:04 PM |
Tail of the Dragon | Tomcat9700 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 02-10-2012 02:30 PM |
headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 02:24 AM |
Optional coloured tail lights? | m_life | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-30-2011 06:20 PM |
