04-15-2013, 01:30 AM | #29 |
GreddyBRZ meets GreddyFRS
Drives: SSM Limited BRZ
For BRZ owners, does this mean the side markers will only blink now and not remain on all the time?
CO>CA|Greddy Intake + EVO 3|Enkei Raijin|KW V3|BeatSonic
SoCal 86 OC Club Tuesday Night Irvine DJ Meet Thread Irvine FR-S & BRZ Car Meet(FaceBook) |
11-24-2013, 06:50 PM | #30 | |
Drives: Subaru BRZ SWP Limited
Any ideas or suggestions for brz owners? This would help a lot. As for the hyperblinking/flashing you can get an led flasher relay to prevent this. I suggest the TapTurn relay. It works great and it'll also solve the issue with the wigway (back and forth) blinking as well as the hyperblinking/flashing. Also someone mentioned if it would cause any problems if you install led bulbs instead of the stock ones, I think the TapTurn will resolve any issues with led lighting and will make sure the lighting is in sync. Hope this helps. http://www.ft86club.com/forums/showthread.php?t=35688 Last edited by tranat; 11-25-2013 at 05:33 AM. |
11-24-2013, 08:41 PM | #31 |
Drives: 2013 Scion FRS whiteout
I'm not sure how it works on the BRZ but the way the sidemarkers work with this mod goes like this:
1. Parking lights on, the side marker will stay on and alternate with the front blinkers. 2. Headlights on, same as #1. 3. All lights off, the side marker will not be on but will blink in sync with the front blinkers. Last edited by boonFRS; 11-24-2013 at 08:45 PM. Reason: Corrected some info |
11-25-2013, 05:27 AM | #32 |
11-25-2013, 05:29 AM | #33 | |
12-22-2013, 01:56 PM | #34 |
Drives: 2013 Limited BRZ
I am very interested in the BRZ solution noted above as well
12-22-2013, 02:01 PM | #35 |
01-25-2014, 07:21 PM | #36 |
there is a much easier way to perform this mod, i just did it 5 minutes ago.
No need to cut both wires from the side marker - black/white right side, black/red left side. also no need to cut the red (blinker) wire and the green (parking light power) wires from the parking lights. NOTE -The Below is FR-S Specific, as well I haven't tested this with LED bulbs, only incandescent. LED Bulbs in your blinkers WILL result in Hyperflash unless you have installed an LED safe flasher relay / Tapturn flasher. I'd recommend using a multimeter or a test light, to verify the wires if you have a BRZ or BRZ Limited. The same would hold true if you have a 10 Series or Monogram, the standard FR-S wiring is what the OP's Guide and my revision are based on. Here is what i did to achieve the same effect, took 5 min per side.. using the DIY in this post locate the red (blinker signal) wires coming from your parking lights and splice a jumper wire onto it, either by splice connection, solder, tape, wire nuts, whatever your preferred method is... do not cut the green wire or splice anything to it, the green wires are your constant power wires for the parking lights. next, locate the 2 wires coming from your side markers. i chose to get my wires before the harness going into the sidemarkers, whereas the OP chose to get them inside the sidemarkers themselves, do it my way, its better because you have more room and wire to work with and easier to return to stock...for your referance - right side will be black/white, left side will be black/red. The black wire on each side is the only wire that needs to be cut, NOT both wires going to the side marker. Again, for reference, the white wire on the right side, red wire on the left side is your constant power to the sidemarker, no need to cut or splice this one, leave it be. Yet i digress.. locate your black wires on each side of the sidemarkers, and cut the black wires. Take your jumper wire you spliced to the red blinker signal wire from the parking lights, and connect them to the sidemarker side of the black wires you just cut. tape off the remaining black wire ends that are leading to the engine side. if you ever want to reverse this mod, just splice the 2 ends of the black wires back together, and remove the splice connection to your red blinker wires. test and enjoy if something doesn't work, you either didn't make a good splice connection, or you ran your jumper to the end of the black wires that do not lead to the sidemarkers... no hyper flash, no warning lights, blown fuses, just like the OP method above this flashes and looks stock, the way the fr-s/brz should have come. 1. Parking lights on, the side marker will stay on and alternate with the front blinkers. 2. Headlights on, same as #1. 3. All lights off, the side marker will not be on but will blink in sync with the front blinkers.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? Last edited by Danklvr; 01-27-2014 at 09:57 PM. |
01-25-2014, 07:24 PM | #37 |
RED is the blink circuit
How ya gonna keep 'em down on the farm once they've seen Karl Hungus? |
01-25-2014, 11:34 PM | #38 | |
Drives: 2013 WR Blue Limited Manual BRZ
01-26-2014, 12:49 AM | #39 | |
Drives: frs
-Splice the red wire from the turn signal by using a splice connector -cut black wire on the side marker -connect the jumper wire from the red wire to the black that go to the marker |
01-26-2014, 01:35 AM | #40 |
That's what I got out of it, although I think I'll be soldering connections.
01-27-2014, 02:12 AM | #42 |
Drives: frs
Doesn't work with switch back led
-parking light on, only side marker on, white led off -headlight on, same -turn signal on, side marker flashes, amber led flashes as well but weird strobe put my stock bulb on and everything works perfectly take stock one out because I like the switchback. |
Similar Threads | ||||
clear side marker part number | NOBROWS | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 09-11-2017 09:12 PM |
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 10:24 AM |
Converting side marker to turn signals | ayau | Cosmetic Modification (Interior/Exterior/Lighting) | 30 | 12-13-2015 03:41 PM |
does your car come with side door marker light? | excited86 | CANADA | 12 | 08-02-2012 06:07 PM |
Raven blacked out side marker before and after | Roadstercycle | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-24-2012 10:52 PM |
