08-07-2015, 08:52 PM | #99 |
UCSB!!!
Drives: 2017 GTI sport
Hey I'm having some difficulty getting the pin out. Does anyone have any tips? Also im pushing the pin from left to right correct? so the the pliers are on the opposite side of the e clip?
08-07-2015, 10:20 PM | #100 |
Ex-MR2 owner
Drives: Scion FRS
I used a pick/pocket screw driver to get the pin out on mine
08-08-2015, 05:48 AM | #101 |
That Guy
Drives: 2013 asphalt FRS MT
08-10-2015, 04:36 PM | #102 |
Drives: Ultramarine toyobaru
Did this mod now my girlfriend says she can't drive my car, clutch too stiff...
The Following 4 Users Say Thank You to headlikeahole For This Useful Post: |
08-12-2015, 01:36 PM | #103 |
Drives: 2013 Firestorm Frs
I'm planning on doing this when I get home. When I first drove the FRS I thought the clutch was insanely light.... Either I haven't been skipping leg day, or the cars I used to drive had heavy clutches. I'm thinking its the first one XD BUT SERIOUSLY, OEM CLUTCH FEEL IS SO BAD. Thanks for the write up, looks like the mod is an overall success and I will like it before I have even done the mod XD
08-13-2015, 09:20 PM | #104 |
Drives: brz
Thanks! I just did this as well. Taking it off took no more than 10 mins by following your write up. However, putting back the pieces onto the pedal without the spring took forever and ended up losing the E clip. I'll buy another Clip if the pin ends up sliding out.
08-13-2015, 10:10 PM | #105 | |
義理チョコ
08-13-2015, 10:17 PM | #106 |
Everyone once in awhile.. whether in Portland OR or Seattle WA... I'll get stuck in some bad stop and go traffic.... and I'm thankful for that little spring!!
2013 Asphalt / MT
Olympia, Washington |
The Following User Says Thank You to PNW FRS For This Useful Post: | Tcoat (08-17-2015) |
08-14-2015, 01:05 AM | #107 |
Drives: Supra, 2014 BRZ
Glad i saw this, just ran out in the dark and did this. Took all of 4 minutes and 2 of that was trying to get the damn clip back in.
To people having issues getting the pin out, after the clip is removed tap the pin a couple times with the needle nose then pull the pin out from the back instead of trying to push it through. To get the spring perch off easier press in the clutch pedal and just hold the spring perch toward the firewall with pliers or screwdriver and let the pedal come back. Watch out for flying parts. Can't wait to drive it tomorrow, this clutch has bugged me since day 1. |
08-14-2015, 10:03 AM | #108 |
Had the mod in for 2 days now and the difference is night and day. Would definitely say that I was getting used to the old clutch, but this was such a much bigger improvement. All my shifts are smooth and accurate. This is a top notch mod, the hard part for me was getting the pin out of the clutch. I had to depress the clutch in and use some leverage from one of the metal bars before I could pull the pin out from the other side. Once that was done it was pretty straight forward and easy. Getting the E clip back on is kinda tricky. I put the clip entrance pointing up and used some needle nose pliers to squeeze the pin and clip together.
08-14-2015, 07:52 PM | #109 |
Drives: Asphalt FR-S
This was a total PITA but damn if it's not like a completely different car afterwards.
08-17-2015, 10:56 AM | #110 |
Hail Magnet
Took off the spring and left the other hardware in, took me a little longer than 15 minutes, but it was relatively easy. Totally feel the "slop" at the top, but its not too much to deal with. I am still a little worried about it sitting on the clutch spring alone, but the feel of the clutch is a bit more meaty and easy to read.
08-18-2015, 10:26 PM | #111 | |
Drives: '14 Monogram 6MT FR-S - Hot Lava
Clutches have been relying on the master cylinder to hold them up for the better part of a century at this point with no discernible ill effects.
The Following 2 Users Say Thank You to Slysdexia For This Useful Post: | HunterGreene (08-19-2015), Ultramaroon (08-19-2015) |
08-19-2015, 12:11 AM | #112 |
Drives: '13 SSM BRZ Limited 6MT
What does it mean to go back to stock by using zip ties? I haven't tackled this yet, but I want to make sure it's completely reversible without looking tacky.
Similar Threads | ||||
Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 12:40 PM |
Car dies after 15-20 minutes? | PolishFrs13 | Issues | Warranty | Recalls / TSB | 28 | 10-08-2015 04:28 PM |
Toyota 86 in 10 minutes. | KKaWing | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 03-28-2013 09:06 PM |
32 Hours 7 Minutes | Wes B. | Other Vehicles & General Automotive Discussions | 11 | 12-26-2012 09:10 AM |
How to hack a BMW and steal it in 3 minutes | Dadhawk | Other Vehicles & General Automotive Discussions | 9 | 07-11-2012 12:11 PM |
