Tracking / Autocross / HPDE / Drifting What these cars were built for! |
11-15-2012, 02:22 AM | #29 |
Drives: '13 BRZ Ltd WRB
I'm glad I stumbled onto this thread. Tonight I picked up a pair of 14mm Eibach eccentric bolts from a friend for cheap. This gives me the option to use crash bolts up top if I really want later on. But I'm happy to hear that toe change is so minimal when adjusting camber as much as you guys are.
Could someone clarify for me that since I'm installing in the lower hole (instructions are for upper...but different car), I will orient the tab opposite the instructions? i.e. tab out for negative camber. I'm sure it'll make more sense when I get in there, just like to know ahead of time.
11-15-2012, 07:13 AM | #30 | |
Drives: '13 BRZ / '11 Outback / '06 Tundra
The Following User Says Thank You to celica73 For This Useful Post: | 2point0 (11-15-2012) |
05-26-2013, 12:50 PM | #31 |
Drives: ex500r
Can anyone give me the part number for oem crashbolt? This is only for the front right?
I'm not sure if I will need them. Since I got the full ground control kit with camber plates and etc. |
05-26-2013, 01:09 PM | #32 |
Not sure of the number, but the "crash bolt" is the lower 14mm strut bolt placed in the upper 16mm hole. With camber plates, the little gain you get from the bolt is likely to be useless.
11-30-2013, 05:49 PM | #33 |
Drives: 2013 Subaru BRZ SWP 6MT
do the crash bolts come stock with the BRZ? If so are they pre-installed or would they come in a plastic package along with the car?
2013 Subaru BRZ - SWP - 6MT |
11-30-2013, 07:47 PM | #34 |
Not included.
The Following User Says Thank You to celica73 For This Useful Post: | ShoGun (12-01-2013) |
03-14-2014, 02:44 PM | #35 |
Drives: 2014 BRZ Limited, 2013 Focus ST
Just to make sure, are these the correct bolts needed to add camber?
And yeah, it's an old thread and stuff. |
03-14-2014, 03:15 PM | #36 |
Looks right, but I don't know the actual part number offhand. I'm sure there's a thread on here with the service manual page.
But the diameter is right. Use that 14mm bolt in the upper 16mm hole and now there's wiggle room to adjust. If you're doing this for stock autocross classing, right on. If not, take those back and just get a set of actual camber bolts (eccentric bolts). They will provide more range to adjust and be easier for a shop to set to a certain spec. I put mine in the lower hole so that I'd be pushing inwards slightly less and not worry as much about hitting the spring perch. Of course, now I'm on spacers so it's a moot point.
The Following User Says Thank You to 2point0 For This Useful Post: | Caspeed (04-17-2015) |
03-14-2014, 03:29 PM | #37 | |
The Following User Says Thank You to Thrustin For This Useful Post: | 2point0 (03-14-2014) |
03-24-2014, 05:04 PM | #38 |
Drives: 2013 Subaru BRZ Limited (WRB)
I've never changed alignment specs with a car before.
After installing these bolts, what do you tell the service shop when you bring the car in for alignment? Run as much negative camber as you can get out of the front and align the rear to OEM specs? Anything else? |
03-24-2014, 05:12 PM | #39 | |
Drives: MT WRB BRZ Limited, 2007 911s
03-24-2014, 05:45 PM | #40 | |
What kind of increased wear have you seen with the Toe Out adjustments?
I read this on Tire Rack: Quote:
Similar Threads | ||||
Alignment Specs? | 86_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-10-2013 06:30 PM |
RTR Wheel Alignment | simpleisbest | Tracking / Autocross / HPDE / Drifting | 61 | 11-07-2012 07:48 PM |
where to get alignment? | FML | Hawaii | 2 | 08-08-2012 01:36 AM |
replace front crash bolts to add camber? | Matt Andrews | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 06-15-2012 10:05 AM |
is the alignment on the FRS/BRZ adjustable? | neveronlinefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-05-2012 03:58 PM |
