05-18-2013, 11:26 AM | #57 |
Drives: Sterling BRZ Ltd
Are you guys on stock struts? I just reinstalled my warranty set along with Koni's and these are making noise again. I installed these with a wall mounted spring compressor.
I really want these to work I really like the idea of the parts. It seems putting a conical washer in would give a bit more clearance but it doesn't look like the Koni's have enought thread to make that safe.
The Following User Says Thank You to mrk1 For This Useful Post: | Calum (05-18-2013) |
05-19-2013, 09:34 PM | #58 | |
That Guy
Drives: 2013 asphalt FRS MT
Can you feel the noise in the steering wheel? |
05-19-2013, 09:41 PM | #59 |
Not in the wheel but thought the rest of the car yes. I'm going to pull them apart tomorrow and try again.
I use a wall mount spring compressor so I'm going to try really pulling the spring down to get everything up top snug.
05-19-2013, 11:16 PM | #60 |
That Guy
That was my problem aswell, I didn't compress the spring far enough and wasn't able to center everything during assembly. You could check it by lifting off the dust caps and checking to see if the nut is centered.
05-20-2013, 12:36 PM | #61 |
everything looks centered. I cant find my stupid wheel lock key had to order another, going to have to live with the noise till that comes in.
05-20-2013, 01:43 PM | #62 | |
That Guy
05-20-2013, 09:35 PM | #63 |
Thought about getting removers but a new key is cheaper, and if the remover doesn't work it leaves a mangled mess and then I would really be in a jam
The Following User Says Thank You to mrk1 For This Useful Post: | Calum (05-20-2013) |
05-26-2013, 09:37 AM | #64 |
Drives: Subaru BRZ Limited WRB Manual
UPDATE: Yesterday, I swapped the OEM tophats back on my Koni/RCE Yellows and the noise went away. I also noticed that the bearings on the Koyo-bearing COM-Cs will spin, but not smoothly, and they definitely don't spin nicely like the bearings on the OEM tophats. The clunking I had is also gone. I had the COM-Cs professionally installed a month or so ago, then reinstalled the OEM tophats yesterday using a spring compressor.
05-29-2013, 11:19 AM | #65 |
Drives: 2013 FRS Asphalt
so much for sending me a new set tomorrow. They were out of stock I guess still waiting on more to come in this week.
2013 Scion FR-S AT Picked up 5/30/2012
05-29-2013, 03:35 PM | #66 |
That Guy
Yup, mine are making the noise to. I'm gonna contact Whiteline when I get them off, hopefully this weekend.
05-29-2013, 04:31 PM | #67 | |
Contact Jan at @Whiteline they just got replacement sets in today. They sent me a email this morning letting me know a set is on the way.
05-29-2013, 05:07 PM | #68 | |
05-29-2013, 07:11 PM | #69 | |
AutoX-10/10ths every run
http://www.whiteline.com.au/contact.php 909 476 2860
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | enjoyminutemaid (05-30-2013) |
05-29-2013, 07:53 PM | #70 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
You can do it all by hand. Subaru uses only enough preload to keep the springs seated. It's even easier if you have a buddy. Get everything aligned, then one person pushes down on the tophat and the other gets the nut started. From there you can use hand tools. Hell, I'm 250lbs so I was able to do it myself. There's no need to do something silly like lowering a car onto a disassembled strut. |
Similar Threads | ||||
upgraded mounts? | 7thgear | Engine, Exhaust, Transmission | 19 | 01-11-2013 11:31 PM |
Buyer Beware: Motor Mounts | cobrabyte | Engine, Exhaust, Transmission | 5 | 01-04-2013 08:14 PM |
Autocross Camera Mounts? | fritzy | BRZ First-Gen (2012+) -- General Topics | 7 | 08-03-2012 10:48 PM |
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports | Font Motorsports | Interior Parts (Incl. Lighting) | 2 | 07-03-2012 06:43 PM |
Dash Mounts for gadgets | smbrm | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-28-2012 07:07 PM |
