07-19-2019, 08:18 AM | #1 |
Drives: Crystal white brz
How to wire zeitronix?
I’ve looked around a bit, but don’t fully understand where the zeitronix unit or what gets wired into the ecu. If anyone could help me better understand I would greatly appreciate the help. My understanding this far is that the wiring loom is fed through the firewall. Once that is done I don’t fully understand the reason for the canbus. It looks like from the wiring loom you can wire directly into the ecu and then just tap into power from the fuse box and ground? Is this wrong please help!
Similar Threads | ||||
Zeitronix fittings? | Tal | DIY (Do-It-Yourself) Guides | 2 | 07-17-2019 08:51 PM |
handbrake wire and reverse wire location Australia gt86 | rsingh | Electronics | Audio | NAV | Infotainment | 0 | 01-16-2017 09:12 PM |
Zeitronix ECA errors | SillySaxon | Engine, Exhaust, Transmission | 37 | 02-29-2016 10:57 AM |
Help me identify this wire! Extra wire around battery after clutch job | YouShallKnow | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 12-09-2014 02:04 PM |
Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 10:22 AM |
