Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-24-2015, 10:27 AM | #29 |
Drives: 2015 FRS
This could certainly help. A block heater like mentioned above may also be useful.
2015 FRS Ultramarine.
09-29-2015, 06:50 PM | #30 |
Bump.
10-01-2015, 11:41 PM | #31 |
11-09-2015, 09:04 PM | #32 |
Bump
08-06-2016, 11:29 PM | #33 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Sorry to bump, but....
How does this oil cooler compare to the Cusco version? As well, I daily my car, and currently have the Perrin oil cooler, so that may be overkill. I'm considering this as an alternative honestly. I don't track the car, just drive it hard on back roads occasionally.
08-07-2016, 01:19 AM | #34 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | weederr33 (08-07-2016) |
08-07-2016, 11:31 AM | #35 |
Drives: 2013 Subaru BRZ Limited (WRB)
Interesting, but hardly seems worth the trouble. There is hardly a decrease in oil temp worth mentioning. Definitely not adequate if you actually plan on tracking the car.
It's neat, and the write-up is appreciated as always, but I definitely can't understand why anyone would bother paying the money for this and go through the effort for hardly any gain whatsoever. |
08-07-2016, 05:28 PM | #36 | |
True if your boosted hard core track person its not suffient. However its way cheaper that a radiator type oil cooler. you dont have high pressure oil lines and fittings to leak or have to worry about rocks or something holing the oil radiator. This thing is super simple and reliable and you can fit it in an hour or less. few guys on here have leaks blown hoses fittings and even under bonnet fires with radiator types. It will warm oil faster in cold climates, wont overcool you oil, and will take 10-15 degrees off your track oil temps on na cars this is usually arround 230-240 unless your doing extended sessions works well. returns oil temps to normal very quickly on cooldown lap. |
The Following 4 Users Say Thank You to steve99 For This Useful Post: |
10-27-2016, 10:28 PM | #37 |
Drives: GT86 GTS
Anyone running this setup with a beefier rad?
10-28-2016, 01:25 AM | #38 |
I dont think the bigger radiator will help, i never see coolant temps over about 93 C, but the oil temps will climb to 115 or so after 10 minutes or so of hard use, down about 10-15c with no cooler.
This indicates the radiator is suffient, but the oil cooler cannot disipate head quickly enough to coolant. If i saw the coolant temps climbing then a radiator would help. What might help, and ive not tested is lower temp thermostat as this would increase the temp differrential between oil and coolant and aid heat transfer. Assuming that the radiator was suffient to hold the lower thermostat temp. However, i would say if your exceeding the capacity of this oem cooler, just get a radiator style oil cooler, its the best option. The oem coolers are only good for hard street and low level track driving |
10-28-2016, 01:34 AM | #39 |
Drives: GT86 GTS
Thanks, I use good oil so 110's to 120's oil temps is fine, as long as it does't go past 130 i'm quite happy
10-28-2016, 03:41 PM | #40 | |
Drives: Subaru BRZ
i was thinking about it too, but i'm not sure the kit can be improved with a low temp thermostat if you use the car for both street and track To me, the reason why i've installed the heat exchanger is to reduce oil temperature differential between street and track usage, so that i can choose the right oil for both (can't do that on a completely stock car). A lower temp thermostat will likely lower max oil temperature at the track, but i'm afraid oil temperature differential between street and track will be the same, so you'll end up with the same "problem" in oil selection |
10-28-2016, 04:32 PM | #41 | |
10-28-2016, 06:45 PM | #42 | |
Drives: 2005 Toyota Camry
Cusco cooler will be more effective, because it takes cooled water after the radiator outlet and plumbs it into sandwich adapter, the outlet is plumbed into the radiator inlet (upper) hose. The only problem is you have to cut up radiator hoses, and the price is quite high. -alex |
Similar Threads | ||||
Perrin Oil Cooler Kit Installation and Review!!! | Sony | Engine, Exhaust, Transmission | 29 | 03-27-2017 02:03 PM |
Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! | GSpeed | Southwest | 0 | 07-30-2015 02:47 PM |
Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! | GSpeed | Engine, Exhaust, Bolt-Ons | 0 | 07-30-2015 02:44 PM |
Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 05:46 PM |
Oil Cooler usability: Changing oil, installation, etc | post_break | Engine, Exhaust, Transmission | 20 | 06-12-2013 02:36 AM |
