09-13-2016, 08:29 PM | #225 |
Drives: 2016 FR-S
Could someone explain as to why? I installed the HKS filter recently, obviously I didn't think much of anything would happen, just figured it would be better for my FR-S instead of the paper/cardboard filter that was in there previously. I also had some trouble figuring out I had to take off the cover of the HKS filter for it fit, install took me about 20 mins longer than it should have, I still worry I put it in wrong, lol.
09-13-2016, 08:35 PM | #226 |
Drives: 13 frs red
Stock flash seems to dial back any artificial gains ie afr trickery etc.
The Following User Says Thank You to Lantana frs For This Useful Post: | funwheeldrive (12-23-2016) |
12-30-2016, 12:31 PM | #228 |
12-30-2016, 01:17 PM | #229 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Not that I have seen or experiance. Granted I also have swapped intakes quite a few times trying to diagnose some issues and tend to clean it after a couple swaps since its been pulled out and exposed to more elements. Probably not needed but figured why not since it was already out
12-30-2016, 02:34 PM | #230 |
Drives: 2013 Black FR-S
stay stock.
12-30-2016, 02:55 PM | #231 |
Anyone know the best place to buy OEM air filters?
12-30-2016, 05:04 PM | #232 |
Drives: 2014 GT86
Get part number of it and google out some online part shop. It might be cheaper then with dealership's premium costs added.
12-30-2016, 06:31 PM | #233 |
Drives: 13 frs red
12-30-2016, 06:42 PM | #234 |
Drives: Toyota 86 2017 TRD Modded
You could just look up the part number for it on a Web search or inquire about it to the parts department at a local dealership.
I would get the TRD drop-in filter if you wanted to stay with a dealer approved product and benefit from its better features. |
01-01-2017, 05:01 PM | #235 |
Drives: Moped
Has anyone heard of any aftermarket drop-in filters that fit the new airbox for the 2017 86/BRZ with the manual?
01-01-2017, 05:09 PM | #236 |
Drives: 2017 manual BRZ
Been asking for a while with no luck on the 2017 filter..
Sent from my Pixel XL using Tapatalk |
01-01-2017, 07:01 PM | #237 |
Drives: frs
01-01-2017, 07:34 PM | #238 |
They changed the filter in the new one, so I wouldn't assume it will have the same effect.
Similar Threads | ||||
AT/MT Dyno Results with/without Mods | blackfireball5 | Engine, Exhaust, Transmission | 0 | 07-04-2012 02:34 PM |
My Fr-s Dyno Results!! Surprising if you ask me | track_warrior | Engine, Exhaust, Transmission | 36 | 07-02-2012 10:15 PM |
K&N Drop-In Filter for BRZ/FR-S in stock! | Mach V Dan | Engine, Exhaust, Bolt-Ons | 0 | 06-27-2012 02:41 PM |
Dyno results for the Nameless Performance street package! | John@Nameless | Announcements, Contests, Giveaways | 31 | 06-26-2012 04:37 AM |
Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
