Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-12-2019, 04:33 PM | #1 |
Drives: 2017 Subaru BRZ
help... think i blew a strut or shock
I hit a big bump in the highway where they paved new section next to the old. The tarmac was offset probably 6" or so and I hit it at 70mph. I bent three rims as a result. So I replaced the three rims but I'm getting quite a bit more nvh in the cabin/seat/everything than I did before.
Whats the best way to tell if a blew one of my struts or shocks? I have the '17 PP Sachs with roughly 19k miles on them. Is there anything else I should check? |
08-12-2019, 04:50 PM | #2 |
Drives: 2014 Subaru Forester
Did you have the alignment checked? How about any of the other suspension components? That was a considerable hit to cause that much damage to the wheels.
08-12-2019, 09:12 PM | #3 |
ProCrastinationConsultant
if you're still getting vibrations, i would check the axles for all the wheels
The Following User Says Thank You to soundman98 For This Useful Post: | BRZ FTW (08-13-2019) |
08-12-2019, 09:48 PM | #4 |
Had an alignment done. Pretty sure that made it worse. I think they went really aggressive with the toe and now its super twitchy at highway speeds. Of course their printer wasn't working so I don't know what the final numbers where. Thinking about taking it to a speed shop to check it out and dial it in once more.
08-12-2019, 09:49 PM | #5 |
08-12-2019, 10:33 PM | #6 |
義理チョコ
At that speed, and with three bent wheels, I'd go over ALL of it with great care. Peened wheel bearings may take a while before they start to growl. Or they may already be the source of the NVH.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
08-12-2019, 10:37 PM | #7 |
specifically for bent axles. i would put it on a lift and spin the wheels, checking them for run out--it ought to be zero.
The Following 3 Users Say Thank You to soundman98 For This Useful Post: |
08-12-2019, 11:33 PM | #8 |
義理チョコ
The axles, or as the service manual refers to them, axle hubs, are replaceable assemblies. They also house the wheel bearings.
08-13-2019, 12:07 AM | #9 | |
You're in San Antonio just like I am, so you can go to Turner's DIY and get on a lift for $20/hr with access to air tools. If you want my assistance just send me a PM and I will work it into my schedule to come help you out. I always try to help out any local owners (I've done plenty of exhaust and suspension upgrades . Also, out of curiosity where did you hit this spot so I know to avoid it |
The Following 4 Users Say Thank You to Tristor For This Useful Post: | BRZ FTW (08-13-2019), Phuviano (08-13-2019), Racecomp Engineering (08-13-2019), Ultramaroon (08-13-2019) |
08-13-2019, 03:46 PM | #10 |
Thanks all!
I'm taking it to Soul Speed in Austin this Friday to get a proper alignment and once over on the suspension. Hopefully nothing needs replacing. |
The Following User Says Thank You to BRZ FTW For This Useful Post: | Ultramaroon (08-13-2019) |
08-13-2019, 05:19 PM | #11 | |
That's a great place to take it, Jaime does a good job and Soulspeed is well acquainted with all the intricacies of suspension work. That's who I had do my initial coilover install + corner weighting. That said, going all the way to Austin is a bit of a drive. Like I said, if you want we can probably find out everything wrong with it on a lift at Turner's DIY, and you can learn how to fix it yourself. |
The Following 3 Users Say Thank You to Tristor For This Useful Post: |
08-13-2019, 10:42 PM | #12 |
if it don't drive right, i'm only hoping you find all the components that need to be replaced in the first shot.
The Following User Says Thank You to soundman98 For This Useful Post: | Tristor (08-15-2019) |
08-15-2019, 10:11 PM | #13 |
Drives: 2013 FR-S Series 10
post your alignment numbers?
The Following User Says Thank You to Decep For This Useful Post: | BRZ FTW (08-17-2019) |
08-16-2019, 09:28 PM | #14 | |
Any other damage or just an alignment? |
The Following User Says Thank You to Tristor For This Useful Post: | BRZ FTW (08-17-2019) |
Similar Threads | ||||
Blown Shock / Strut Club - Original,OEM units | exE36M3 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-29-2015 05:54 AM |
FS factory strut/shock/mount | JMoore412 | Brakes, Suspension, Chassis | 0 | 06-23-2014 02:41 PM |
Rebuilding strut/shock dampers to be firmer than spring rates? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-16-2014 12:23 AM |
shock/strut replacement | sinigang_guy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 03-19-2013 09:15 PM |
