Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
go_a_way1, MisterSheep
Old 07-19-2019, 08:17 PM   #21029
Ashikabi
Ashikabi's Avatar
Originally Posted by Decep View Post
New TOB, verus forged clutch fork, new clutch/flywheel. Also the perrin rear shifter bushing. That bushing is great, transmission feel is so solid now.
But holy crap the increase in vibration can be intense in certain situations.
*edit* could actually be the new clutch breaking in too.
Obviously too late for you but maybe someone else can use it... I saw a hydraulic slave/throw out bearing combo(one unit) for the ft86 chassis somewhere. It was expensive but eliminates the clutch fork entirely. Would replace your slave and throw out bearing. This was functionally identical to those used on LS engines/transmissions
The Following User Says Thank You to Ashikabi For This Useful Post:
MJones_RB (07-20-2019)
Old 07-19-2019, 10:53 PM   #21030
jflogerzi
jflogerzi's Avatar
Bet it's the clutch. I had the same problem with light load and 2 high of gear.
2013 Series 10 FRS #553
JDL 4-2-1 EL, Stock FP with Vibrant LN RES, MXP SP CB
Koing Hypergram 17x8 ET40 SX2 GTs 245/40/17
Sprintek 210+69mm+FF+Tuned by Mike@Xero Limit
Old 07-19-2019, 11:19 PM   #21031
Decep
Drives: 2013 FR-S Series 10
thats actually when i hear and feel it. little bit heavier load, low rpm in the next gear. like getting out of 1st gear @ 10 mph and trying to accelerate a bit too much in 2nd. im assuming it should go away as everything wears in
Old 07-19-2019, 11:20 PM   #21032
Decep
i remember that thread, pretty cool.
Old 07-19-2019, 11:50 PM   #21033
jflogerzi
jflogerzi's Avatar
I think it does. I am about at 2000 miles on my new clutch. I will test and report back
Old 07-20-2019, 01:21 AM   #21034
Steveiam
Drives: 86
Car got hit by a wood panel that fell off a truck in front of me going 70 on the highway. Didn't want to brake and get rear ended so the front bumper took the hit. Luckily, the only damage was loose grille and a few barely noticeable scratches.
Got home and clipped the grille back on and good as new! Kind of bummed out as I've only had the car for about 3 weeks. On the other hand, the wood piece didn't fly through the windshield.
Steveiam is offline   Reply With Quote
The Following 3 Users Say Thank You to Steveiam For This Useful Post:
Feistyfrog (07-20-2019), humfrz (07-20-2019), MJones_RB (07-20-2019)
Old 07-20-2019, 02:04 AM   #21035
humfrz
Glad you are OK!
That was a close call -
humfrz
Old 07-20-2019, 10:44 AM   #21036
Ashikabi
Ashikabi's Avatar
Investigated AC leak.
This means the compressor is bad right?
Old 07-20-2019, 02:36 PM   #21037
Ultramaroon
fun police
Ultramaroon's Avatar
Investigated AC leak. This means the compressor is bad right?
Yeah. That's a bummer.
Old 07-20-2019, 03:05 PM   #21038
Ashikabi
Ashikabi's Avatar
Right? Just can't stop spending money on this thing...
Old 07-20-2019, 03:42 PM   #21039
Ashikabi
Ashikabi's Avatar
Well, since I have to wait on a compressor now, night as well finish my Radium single catch can install
Ultramaroon (07-20-2019)
Old 07-20-2019, 03:54 PM   #21040
humfrz
Just for my own education, how do you know the compressor is bad from looking at that picture?
humfrz
Old 07-20-2019, 04:01 PM   #21041
Ashikabi
Ashikabi's Avatar
humfrz
Refrigerant is leaking from the compressors casing. A seal (or something) has ruptured internally. Was slowly blowing bubbles in that picture
humfrz (07-20-2019)
Old 07-20-2019, 04:22 PM   #21042
Decep
How many miles, and do you run the AC regularly?
Search this Thread:
Advanced Search
Got my VIN today... Enemies Subaru BRZ General Forum 63 04-12-2012 10:19 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
