Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Scion FR-S / Toyota 86 > Scion FR-S / Toyota 86 GT86 General Forum
Old 08-02-2018, 02:52 PM   #211
el-guapin
el-guapin's Avatar
Drives: 19 Bullitt
Originally Posted by nkobns View Post
Does anyone know if there are some drivers to make the cable work with win10 32bits ?
Thanks !
Not sure about 32bit but there is a hack for the W10 64bit. Thatís what Iím running. Search online you will find it.
el-guapin is offline   Reply With Quote
Old 08-02-2018, 03:09 PM   #212
misterfly
Drives: Scion FR-S 2015
Thanks !
I have bought one cable with techstream 13 and it's work on win 10 64 and 32
misterfly is offline   Reply With Quote
Old 08-02-2018, 04:19 PM   #213
ermax
ermax's Avatar
Drives: 2013 FR-S 6MT Raven
Thanks !
Why do you need it to work on Win10-32? It's not hard to get it working in Win10-64. What cable do you have? I had a cheap Mini VCI cable and with some registry changes (moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64. Now I have a Tactrix and the installer for it's drivers put the registry entries in the correct place so you don't have to mess around to get it to work.
Old 09-12-2018, 03:41 AM   #214
kiki2015
Drives: cool
Hello, where did you buy from? You mean VXDIAG NANO Toyota interface?
kiki2015 is offline   Reply With Quote
Old 03-07-2019, 06:03 PM   #215
misterfly
I bought it on amazon .com
it's a generic cable
Old 03-13-2019, 12:09 PM   #216
Gunman
Drives: 2019 Mazda Miata RF
Is this the latest version "available"? looking to pick up a cable soon.
Old 03-13-2019, 12:19 PM   #217
ermax
ermax's Avatar
13.30.018 is the latest
The Following User Says Thank You to ermax For This Useful Post:
Gunman (03-13-2019)
Old 03-13-2019, 04:16 PM   #218
Gunman
So, what's a good cable, since they are all clearly knockoffs from china?
Old 03-13-2019, 04:47 PM   #219
ermax
ermax's Avatar
I got a cheap one for $18 and it worked but later got a Tactrix because I wanted to be able to flash. If I did it all over I would skip right over the cheap one and go directly for a Tactrix.
https://www.tactrix.com/index.php?op...ed=1&Itemid=53
Gunman (03-13-2019)
Old 03-19-2019, 12:18 AM   #220
durtdonthurt
Drives: White series.blue / CWP tS
I need some help....I am trying to get this to work on my 2018 BRZ and I have tried installing version 13.00.022 on both my windows 10 x64 and windows 7 x64 using this method and continue to get the error code: "unable to connect to VIM"
I am using this cable and it is firmware ver. 1.4.1. When I run the Xhorse firmware update tool, I get the status as "connected"
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
When you say "moving some keys from \SOFTWARE to \SOFTWARE\WOW6432Node) it worked fine on Win10-64" What exactly are you doing with this? I made sure the registry file matched the one that was in the guide I was following, added it to the desktop and "merged" it successfully.
Thanks!!
durtdonthurt is offline   Reply With Quote
Old 03-25-2019, 12:48 PM   #221
ermax
ermax's Avatar
14.00.019 is the latest now.
You can always see what the latest version is by going here:
https://techinfo.toyota.com/techInfo..._features.html
Old 07-15-2019, 11:40 PM   #222
xkenx1995
Drives: 2013 Subaru BRZ
Any mirror links for the drivers and software? It seems dead.
xkenx1995 is offline   Reply With Quote
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-01-2012 03:16 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
